Honda Pilot Lights
How do you take off the interior plastic case of the interior dome lights? 2005
Chris
Odie
Odie's Carspace
The 2006/2007 Pilots have projector lamps, so you'll get a very distinct cutoff. If you believe the lights are adjusted to low, have a dealer set them to the correct height. If you want brighter lights, don't waste you money on any of the hyped up blue bulbs. There may be a bulb or two that are a bit brighter, but the only way to get a decent increase in brightness through a bulb change is to go with an over-watted bulb (i.e. 80W low beam). Those types of bulbs typically do not last long, and I know of no information on whether it will not adversely affect the electrical system. The best way to get brightness, but at a bit of a cost, is to go HID. It's $250, but you will immediately notice a significant difference.
David
Projector style (with convex lens) headlights, regardless HID or Hologen based, are generally considered better than reflector style headlights that you are used to, since they output the light evenly to the ground with distinctive cutoff (where the low beams end) to protect the oncoming traffice from glare. The reflector style headlights, however, have hot spots and leak some light beyond where it should end, giving you the impression they light up the road better. Sometimes you can see higher signs better with reflector style headlights. It is a preference thing I guess.
I found the headlights on my 07 pilot more than adequate for most situations except when going toward the beginning of an uphill or the end of the downhill since the distance of the lighted area is shortened due to the curvature of the road. I suspect that your headlight might not been adjusted well. Please bring your car to the dealer or adjust the headlight by yourself using the guideline in the following link.
http://www.danielsternlighting.com/images/Aim.pdf
Hope that helps..
Most people have said they added brighter lights or adjusted their's upward to compensate for the stock lighting problems. All you're doing is undoing any good Honda was trying to achieve when designing the Pilot. Unlike may other auto makers, Honda actually thinks about the other guys out there on the road. Just my $0.02 on the matter. Am I right or am I full of it?
Is this a problem with a 2003 Honda Pilot or is there soemthing I should be looking for ?
I replace them with the Silver Star bulbs @ a price of $ 22.00 +/- each
Thank You
Odie
