Nissan Quest/Mercury Villager Timing Belt
I am approaching 105K on my 99 Quest. I know the manual calls for a timing belt change at this interval. Some have recommended changing the water pump at the same time. Was wondering what to expect to pay for this job. I guess I will have the plugs changed also..hope they can get them out.
The Edmunds Maintenance Guide will estimate what it should cost in your zip code.
SUVs and Speed Shop
motonation, "Nissan Quest/Mercury Villager problems" #2441, 28 Jul 2006 7:09 pm
More searching would probably turn up some more hints for a fix.
SUVs and Speed Shop
What is you opinion...is the 3.3 an interference engine or not? this has been a question on this forum for years.
Let me search around and see if I can find a thread with more info and I'll try to edit this within the 30 minute window.
[edit] Ok, the rotten hose I keep thinking about is the BPT hose connected to the EGR and that'll flip the CEL on but doesn't cause a coolant smell.
These two posts talk about leaking coolant hoses and clamps (and the first one segues into timing belts, conveniently enough :shades: ).
motonation, "Nissan Quest/Mercury Villager problems" #2158, 22 Nov 2005 6:18 pm
kymike, "Nissan Quest/Mercury Villager problems" #1656, 6 Dec 2004 10:32 am
SUVs & Speed Shop
how do I line the timming mark.thanx J
For my '99, the manual says:
The printed arrow on the belts should be pointing away from the engine. The belt should have 3 white timing marks on it. Each white timing mark will be aligned with the corresponding camshaft and crankshaft timing mark on the sprocket.
You'll have 40 teeth between the timing marks between the LF and RH camshaft sprockets and 43 teeth between the LH camshaft sprocket and the crankshaft timing sprocket.
Here's a pic.
SUVs and Speed Shop
They have complete repair info for most recent makes and model cars.
SUVs & Speed Shop
SUVs & Speed Shop
thanx J
Try one of the discussions in the Voyager/Caravan group for help with the Caravan timing. There's also alldatadiy.com and the Auto Repair Reference Center you can try (many local libraries subscribe to one or the other, and many let you log in from home with a library card number to download schematics and tech info).
SUVs and Speed Shop
I have a 99 Villager that threw the timing belt while I was trying to start it in my driveway. I had the timing belt replaced ($500 - included all the recommended replacements like the water pump) and then tried to have the car inspected. It passed the Mechanical Inspection but failed the emissions due to two codes. The Knock Sensor and the Cam Sensor. I don't believe there is anything wrong with the sensors. This car just passed emissions only 7 months ago. I'm convinced something happened with the timing belt. Is it possible that the garage didn't dial in the timing correctly causing misfiring or inefficient firing because the fire point is not hitting the precise time?
Anyone have something like this happen?
Jim
I could look up the marks in my manual but I wouldn't trust the info for your '95, plus I can do brakes and minor stuff, but don't think I'm ready to tackle a timing belt. So I'm not much help.
Can you access some of the links in the Online Repair Manuals Guide? They may approach the issue from a different angle that whatever resource you are now using to replace the belt.
Anyone else?
Steve, visiting host
