Jeep Cherokee, Grand Cherokee Cruise Control Problems
My cruise control started acting weird awhile back, it would cut off when ever it wanted too and wouldn't even come on at all sometimes now it dosnt
work. It says in the haynes manual that it is controlled by vaccum but dosnt really help much it terms of where to inspect. So does anyone know where i should start looking?
Any ideas, before I take it to a dealer for service?
Still haven't gotten this solved. System keeps a vacuum with no problem, throttle cable not binding, etc.
Next step is to try and replace the switch on the steering column. Haven't gotten there yet. Too many other things floating around.
3rdjeepowner. :confuse:
I started on page one, and have been reading the many Jeep questions. I finally found an answer to a post that was made Aug 29th,'05. It seems OEM not available, and after markets unsure of effect on a Jeep computer.
I like thank both Steve and Tidester for such a vast array of info that covers Cherokees from bumper to bumper.
This forum has taught me so much in so short a time how to properly care and maintain my Cherokee for years to come.
For all the regulars who contribute their knowledge on various subjects, I also would give thanks to them.
I'm only half way through 2200 plus questions and comments, but I look forward to reading them all.
Rog
Read it carefully - there's going to be a quiz on it!
Seriously, thanks for the kind words and we're gratified that you find the Forums so helpful.
SUVs and Smart Shopper
Cruise control only comes on for a second and then shuts off and will not respond until iginition is shut off and restarted. just started happening. what switch is involved is it the breake switch? Are there any relays envloved and were are they?
bheiar
could it be a burned fuse? - thanks
I will try to help you out as best I can.
Readers of this Forum would likely be interested in that information also.
First remove battery. Then remove pan, you'll need a deep socket 10mm with extentions to get at one mounting nut. Remove two nuts holding cable to fuse/relay box attached to pan. Move pan out of way. The hose that's causing all the problems is about 6" long going to servo. Replaced hose ($.77) and it took care of both problems. Total job took about 1 hour. From what I have been reading this is the hose that's causing everyone problems.
I've read the other blogs about hoses etc. How likely is it that this costly computer needs to be replaced?
I had cruise control added after-market to my 94 Jeep Cherokee Sport at the dealership a few years after purchase. It looks just like the one in the manual. It was working perfectly until a year or so age, now I'm trying to get it repaired. A different Jeep dealership says it needs a new powertrain module control - I've left a post about that.
Thanks for help
