Chevrolet Blazer Heating and Air Conditioning
Just changed the water pump and the thermostat. Did step by step in accordance with a Chiltons back yard mechanic book. Got all put back together (with no spare parts) was connecting the negative battery cable back up and there was much clicking coming from the passenger side firewall area. Started the vehicle, let it warm up, put the air on max hot and fan speed hi, checked for leaks (none noted) and took it for a test drive. Air exiting the ventilation got extremely hot. Turned the climate control down to 66 (external ambient air temp was 53) and there was no change in ventilation air. Cycled the air positions (floor/dash vents, floor/defrost, floor, dash vents etc.) and cycled the fan speed. No change in temperature. Returned to house, left engine running, checked for leaks (none noted) and turned off the engine. Left it off for 5 minutes, started it back up, turned on ventilation and extremely hot air again, then it went to a cooler temp and right back to desert hot again. There is a clicking or popping type noise behind the dash somewhere. Any suggestions to what the problem may be? Is this a dealer service only fix? In advance thanks for any posts. 4.3 liter 4WD 121000 Miles, 24000 miles with brand new GM motor.
It's pretty cold here in Iowa and we could use some heat blowing on our feet. Any help would be great.
I'm not for sure if there is a switch or a lever that moves the door that directs the air flow. I'm guessing that I have to take the dash apart to fix this - Is that something that is somewhat easy to do? Or is this going to cost me alot to have some shop fix it.
The car blows cold air until the temperature gauge gets up around 260, then suddenly drops down below 200.
Would my next step be to flush the cooling system? I don't see why it would be running hot though.
Matt
Thanks for the help.
mine is a 2001 Blazer and recently it started blowing a smell of coolant into the cab. worse than that - more like CROTCH and coolant. its disgusting. later it started blowing really humid, damp air into the cab - so much so that i could hardly see out of REALLY foggy windows. its winter, so i'm using the heat. but get this, the heat works. very well in fact. if i turn it over to a cooler temperature, mist starts coming out of the vents.
just to get around, i'm riding with all windows cracked to keep the humidity in the cab down.
everyone i've talked to says its the heater core. just got back from a dealership who ran diagnostics and gave me an estimate. it says that an intake gasket leaking coolant is causing heater core failure. calls for intake gasket replacement (59.83 parts and 492.00 labor), heater core replacement (137.03 parts and 492.00 labor).
my thing is (and i'm probably really mistaken here) that the heater core is obviously working if i'm getting heat. so why does the core have to be replaced? fix the leak, replace the intake gaskets really should be all thats needed here, right?
If it drops and the hoses/water pump do not leak, and lifters tap on startup, most likely the lower intake and again thats the current rate.
Dex cool requires changing 3/36 and the GM BS of 5/100 causes this. Air in the system creates a mess and the wrong mix (50% correct) causes a voltage diff that eats the core. The GM cap was crap design also so get a Stant plus change the thermostat at the same time. Hope the waterpump doesn't start to leak soon too as all the crap in the system often gets in the seals and bearing.
I have a 1999 Blazer, Trail Blazer pacakge with auto climate control.
The system will blow cold, then I'll hear something squeak in the dash and all of a sudden it blows hot. Every 10-15 iseconds t switches, hot to cold. The cycle repeats when the engine is running, regardless of what position the temperature selector is at.
Is that flapper box bad? Or could it be the control unit? Any advice?
Try rotating the knobs to see if the contacts are dirty and this may clean them and see if running at all cold or hot stops the cycling. I never use that auto fan position cause I hate it ramping up and down.
replaced actuator because it was clicking and new climate control but did not work.
I talked to dealer and they said they haven't heard of this which I don't believe,if anyone can help Id appreciate it.
hot air unless I manually turn the door to cold.
exposed can i get to the door near the steering column to repair it without removing the the entire
heating unit. Any make do fixes that can be done without complete disassembly of the air handler??
I would welcome a manual wire. My disabled expert
says the vacum motor is working and he can see it
move but the door just springs back. The vacum motors behind the glove compartment are ok.
Obviously i am looking at big bucks that i cannot afford. Any help or suggestions appreciated.
sc
Found some info on another forum and summerized below:
Remove the vac line that enters and then move the the vac assembly. Remove the electrical connector that feeds the Actuator. With a 7/32" remove the two (2) mounting screws. There is no screw on the back mounting post, just a pin that holds it steady. Pry the Actuator up off the blend door with a screwdriver. Install new one.
Could it be the temperature dial? I'm not thinking so, but I don't know what voltages to look for to see if its working right.
I expect it is the temperature (air blend door) actuator, and I *think* I can see where it is. If I understand what it looks like, then if I open the glovebox and move the vacuum controlled actuator I see there, (I believe this one's for the footwell?) then I can look up behind there and see it.
Is there a way to test the air blend door actuator? Is there a way to get it out without removing the whole dash?
First: when I connect the remote control to open doors then the car open the 4 doors not only one.
Two: when I connect the lights of the car, the central control of the doors sound like I try to open the doors and is the only way to move the electric mirrors (at the door) to see the sides of the car.
Three: every time I put the ventilation system in my Blazer LT 2000 the air is very hot, even with air conditioning (probably I need to check this system too).
Any suggestions... Thanks in advance.
Also.... last Sunday the drivers windshield wiper seemed to go "off track" - it is "spastic" in its actions. the passenger one works just dandy- however they are crossing over and getting stuck on each other- Manual only shows how to change wiper blades. Do the wipers have little teeth that could be eroded like starter teeth and that is making it just not catch all the time- how do I get the wiper assembly off to check? and then what do I do with it?
Thanks so much.
Dean Arzberger
I just had mine fixed at the dealer (see message #52) as I found out that we DID have a 90 day 3000 mile warranty. It was a spring inside the radiator that regulated the water flow- it would work sometimes and sometimes not- so as we did not fix it ourselves I canot tell you the absolute specific details of the particular spring- I am sure we could have never figured that one out- we thought it was the select heatt/cool knob at first that controlled the baffle that opens the heat. Good Luck.
:} Anna
toolzz
The spring was in the main radiator. The heater core was fine.
Anna
