Saturn S-Series Starting Problems
I have a 95 Saturn s-series with trouble starting when cold. Sometimes it take 5-10 minutes to get it started. When it does start it is all you can do to keep it running. I have had it to 2 different repair shops spending way too much to not have the problem fixed. No one seems to kow what to do or look for now. Help.
The battery in my 1996 SL2 discharged because the car was sitting for several months unused (I know, I know -- I should have disconnected the battery!).
So I recharged it (pretty sure, anyway). Now the lights come on, etc. but when I turn the ignition the car cranks for about 1 second then stops cranking and there is a loud rapid clicking noise.
I've seen this symptom before in other cars but I can't remember what they mean. Can anyone help?
Thanks very much,
Tony
Help!!!!!!
Yesterday I was 95 miles from home and I had a transmission leak from the filter.
I lost 3 qts of oil. I replaced the filter and put 3 qts back . The reason I looked under the hood was 2 fold. I kept stalling at my destination and the ABS light was on. The engine would stall only if I applied the brake pedal.
Six hrs later in panic mode ,having to drive 85 miles back home I found 1 solution.
Remove fuse from brake and I made it home. If I but the fuse back in and press the brake pedal the engine will die .
Okay my transmission was soaked with oil. I cleaned off all oil. I checked the wiring harness and it was clean .
**In front of transmission are 2 sensors or switches.
If I look at wiring diagram it shows Brake transmission safety interlock ,Brake sense switch and stop light switch all in series. Could one of these be my problem?
Another thing when I step on brake pedal the dash board left and right signals light up dimly .
Please let me know what you think. Thanks
Whether you jump started it or popped the clutch is inconsequential. What it needed both times is just a little time to cool down. The CKP sometimes overheats as it ages but its rare and tech's just haven't come across it. As it heats up the electrical properties change. The Impedance, measured in ohms, changes too much beyond tolerances to operate.
Many messages in this string are, I believe, the same problem.
I know, I had the same problem. Even had one tech tell me he thought it was the automatic transmission. :shades:
1- if the starter cranks but the engine won't start ( and then sometimes does) its not the starter.
2- once the engine finally starts and then runs fine, its not the fuel pump, or ignition.
I determined the most likely cause was something keeping fuel from reaching the engine to start it. And so it became an electrical switching type problem, and as mentioned previously, once started it runs fine, so not something that would keep it from running altogether, like a bad fuel pump.
My hat is off to kday for finding a fix that involves not spending ANY $$$ to repair.
okay have 1993 saturn sl1 recently engine light comes on but goes off after a few seconds then car stalled while in an intersection tried to start back up wouldnt start so i left and let it sit for a few hours came back car started with no problem drove is 15 minutes down the road stopped to get a bit to eat thinking it was a fluke went to start it suprise suprise wont start had to get a jump which took 10 minutes to do next day started it in drive way started right up but i was afraid of driving it for fear of being stranded again... any one have any ideas?????? :confuse:
Through the warm months the car was dead a few times usually in the morning. She would have it jumped and then it would be OK. Through the winter months it's a daily occurrence. It's been in and out of the shop. Besides the new battery it's had a new starter, alternator and radiator but no one can seem to figure out what this problem is.
The only other thing when it sat in my driveway the roof actually leaked( I had it sealed) water definitely got down the doors into the window mechnisms. The rear motor never worked.
Any input would be greatly appreciated.
I just happened by the library today and found one of those huge Motor Repair Manuals ( like 5 inches thick) for GM 99-01. There was an 8 part section on
Engine Crank- No Start. problem= intermittent start
connect to OBD and check malfunction history
check circuit 402.
ALSO, it said that when you turn the key to ON (not to start) the fuel pump should run for 2 seconds (every time) This I knew and when I go to start mine I have the radio off so I can listen for it- weirdly though, sometimes mine would start without hearing the FP make a sound. I would wait for the stupid chime to stop (5 dings) and then it would start most times.
I am still looking for a way to turn off the annoying chime, but don't pull the chime fuse, it kills the whole ignition sysytem.
So, I had surmised I had a problem with the fuel pump and/or filter, and I was going to take the car into the dealer and see if they can pull up the 'malfunction history'
and tell me what the 402 thing is, along with checking fuel pump and fuel pressure.
On the way home, as I got off the freeway and came to a stoplight, it now developed the infamous CHUGGLE at idle. Jeez, you had to keep the thing at 2500 RPM to keep it from stalling. Since then I went out to the garage twice and started it, but it needs to rev at least 2500 rpm to keep from stalling. That's where I am now.
I got a can of CRC carburetor cleaner (use some good stuff, not a cheapie so it can blast) and removed the throttle body and sprayed it out and the idle air sensor screw. Then I re-removed the EGR and sprayed it out also. Upon removal of the EGR , I found a little chunk of carbon deposit stuck in its needle valve, which turns out was the culprit. I had previously cleaned out the EGR with a toothbrush and this must have dislodged the chunk.
Even though I am still chasing the starting problem, since cleaning out the throttle body the car runs like it has a new engine. and the weirdness continues....
Code 336- CKP sensor fault code signal intermittent.
So I went to AutoZone and picked up one SU-185, only $13.99. This repair will be around $200 if you have a shop do it.
Now I am 2 weeks out of knee surgery with a knee immobilzer on, and I crawled under that car and did it in 2 hours, WITHOUT removing the starter.
NOTE: The bolt that holds it into the engine block was so loose I unscrewed it with my fingers. This most likely contributed to the failure of the CKP.
If anyone out there wants to do this themself and need more info email me I can tell you how I did it w/o removing starter. Also, I got great info from a Youtube video. There is a guy that has over 120 Youtube vids on saturn repairs of all types, and he is very good.
my email : racermouse@hotmail.com
repair vids> http://www.youtube.com/profile_videos?p=r&user=richpin06a&page=1
I have noticed that it seems to be related to the temperature. It only seems to happen on warm days. I've taken it in to be looked at by both the dealer and a private mechanic. They all seem to think it's the starter, but I don't agree. The car starts just fine most of the time.
Anyone else have this experience or have any insight?
Good luck!!
The ECTS on these cars has been blamed for everything...is it your problem...I'm not sure.
Is your check engine light on? Or has it come on recently?
Are you saying that you have to floor it to start it or to keep it running? Your throttle body might need to be cleaned, they're known to get funky from all of the oil mist flying around in the PCV system...just a thought...but first:
Any suggestions? :confuse:
