Chevrolet Suburban and Tahoe Towing Questions
I have a 1999 two wheel drive Tahoe. It has a towing package and fingertip steering, its loaded. I have had the allignment checked by four garages. Everything checks out great, no problems, I put on new tires, brakes, greased bearings,new rearend,new shocks. I can not tow anything over 60 miles per hour , 3000# trailer or a 500# trailer. If I go faster than 60 I start weaving all over the road. Truck had 55k when purchased, now 120k. Any thoughts?
However, some towing basics to be aware of are:
1) Keep your tires inflated to maximum cold PSI when towing. A good set of LT tires as oppsed to pasenger tires makes a huge difference, as you can inflate LT tires up to 80 PSI if needed.
2) Tongue weight of the trailer relative to the trailer weight should be 10%, excessively "light" or "heavy" tongue weight will cause the trailer to fish tail at high speeds.
3) A good Equalizer hitch with anti-sway can make all the difference.
4) Remember your Tahoe rear suspension is tuned for a comfortable ride for the occupants, (ie softer rear suspension). This means it is easier to overload the rear suspension, and create towing headaches. (unlikely to be your prob with a 500# trailer).
Also can you disable the "Fingertip steering", if so try towing without it and see what happens.
I have experienced a problem like this when a trailer had too high negative tongue weight, i.e. the hitch was lifted up too much with the trailer.
This could happen if the tongue weight is very small to start with and you drive fast. The wind resistance of the trailer exponentially increases with the speed. Force from the wind resistance tries to tilt the trailer backwards and causes lift on the hitch.
You said you pulled the same trailer with a Suburban without any problems. Well, Suburban is about a foot and a half longer so it has some extra weight compared to Tahoe.
The issue with too much negative tongue weight is easy to check. Just load your Tahoe with few hundred pounds of extra weight right at the rear end of the cargo hold and take it for a test drive.
Too much negative tongue weight causes your rear tires to loose grip and back of the truck starts sliding sideways.
The same issue, of course, can be caused by just too much negative tongue weight. Poorly loaded light weight trailer can create too much negative tongue weight and lead to the problem.
Then there is this little more uncommon explanation. Your truck and trailer form a "vibration system", which has a joint at the hitch. Under certain conditions the back of your truck can start pumping up and down as the trailer tilts backward and forward.
This problem you could also help with some extra weight in the cargo hold as the weight changes the natural frequency of this "vibration system". Another thing that changes the natural frequency is the springs. Your springs could be too soft or too hard for pulling your trailer but this explanation could be a bit too far fetch for this problem.
May I ask what kind of a trailer are you trying to pull?
Arrie
The car is a daily driver for my family of 6 which typically extends to 8 with extra kids around. Aside from that use I pruchased the vehicle in hopes that I could also tow my 97 Jeep Wrangler on a car hauler behind it.
I recently towed a trailer and was somewhat disappointed in it's performance. It could be that I had unreasonable expectations but I have no idea.
The trailer was a 16 foot car hauler with a steel bed. I'm assuming the trailer was relatively heavy. Loaded on the trailer were the following: two quads (2wd 150cc), four large coolers, 10 bikes a barbeque and miscellaneous camping gear. I can't imagine that the total weight of the gear and the trailer was more than 4500 pounds probably less than that.
The terrain was the Sierra mountains in California about 5000-7000 ft in elevation and hilly. My experience was the following:
On hills the vehicle couldn't seem to maintain 55mph. Whether in or out of tow/haul mode or manually shifting or leaving it in drive. I would slow down from 60mph at the beginning of the hill to about 38mph at which point the transmission would let me downshift but it would be around 3500rpm. At that point it would have the power to accelerate up to maybe 50mph but of course the engine would be at high RPMs if it upshifted I would, of course, lose all my power and slow back down to 38ish mph and it would downshift again. Maybe I just need to expect to drive 40mph up inclines but I thought it should perform a bit better than that.
Can anyone confirm if this is normal or not?
I have an '04 2500 trk w/ 410 gears. i pull a 8100# (dry) toy hauler, loaded I'm guessing 10 or 11,000 lb with some downshifting on inclines, more with hills and lots with wind and hills. it really does struggle with strong wind & bigger hills. i do have k&n intake with flowmaster exaust to try & help with towing & milage also, but feel the truck does well driving in 55 zones vs. 70 zones. I try to stay in overdrive by speeding up for hills(when traffic allows) and just slowing down on some of the hills. burbon should be in tow/haul and if shifting too often stay in 3rd vs overdrive.
Look on the tag on the drivers side door jamb, and it will tell you the Gross Vehicle weight you can haul (including the weight of the suburban). Then look in your owners manual under towing, and you should have a chart which you look up your model and rearend ratio.
GT4 = 3.73 GEARS GT5 = 4.10 . IF YOU HAVE FULL CAR OF PEOPLE , THIS CUTS INTO # YOU CAN PULL.1200 IN SUV , 4500 TRAILER = 5700 SO FAR. W/ GT4 + MOUNTAINS/ HIGH 7+ GRADES YOU WILL NOT HAVE HIGH ROAD SPEEDS. DO YOU HAVE A TRANS COOLER ? VERY SMALL RADIATOR IN FRONT 6" x 16" ? BEHIND FRONT BUMPER/FASCIA TRIM IN FRONT LOW POSITION.
This was our first time with an RV, and we loved it. It was a rental, and we'll definitely rent again, and probably go for something slightly larger. I suspect a pop-up camper would give much better fuel economy as it's obviously the wind resistance more than the weight. The guy actually has a very nice 31 footer that he said we could easily handle with the weight distributing hitch he supplies with it. It's about 5500 empty, 7100 max, which is near the stated max capacity of our truck. I'm willing to give it a try. So nice to just park and plug in and have a nice kitchen and bathroom and real beds to enjoy at the end of the day.
I'd get a towing package (transmission cooler), if you were towing a large trailer long distances....where the added weight and windage would cause the transmission to overheat.
Chevy engines dont like backpressure like some other brands' V8's do, so increasing the pipe diameter a little bit could be useful too.
Hope that helps ya!
I think you would have insurace and liability issues if you exceed the towing limits even with those mods.
SUVs and Smart Shopper
Twenty five (ish) years ago when I had a large trailer and was concerned about this myself, if I remember correctly in a GMC p/u I had to go to a 3/4 ton and the main difference was the rear axle strength, the size of the brakes all around, the rear spring #leafs/strength, the wheelrim strength and number of lugnuts, and the tire size and rating.
I know I also ordered it w/transmission cooler, but I don't think that was 'required' for the GVW.
I have no idea what the current models differences would be, but it should be easy enough to research for new sales.
Got tired of this so bought a 2003 K2500 with the 8.1 motor which will pull a house
but mileage doesn't suffer badly as it has a 3.73 gear VS my old 4.10 gear. And I don't use any stabilizers or sway controls, just put it on the 2 5/8" ball and go!
My old 99 K2500 has a rear track 4" narrower than the front so I have 2" spacer/adapters on the rear for a wider stance and stability which helped. BTW, my 99 K2500 is now for sale, black/gray, 121k, SLT for $7500 and in NC.
1) 2007 3/4 Suburban (6.0L, 4 speed trans) with 4.1 rear end?
2) 2009 3/4 Suburban (6.0L, 6 speed trans) with 3.73 rear end?
I know everyone will say to go to a P/U but not an option ... wondering if one direction is better than another ...
Any thoughts or experience appreciated.
I have two trailers, both with new wiring harnesses and light assemblies.
ALL Tahoe lights work fine without a trailer connected.
Trailers have good grounds.
The Tahoe plug at the back tests “good” on all connections UNTIL the trailer is plugged in. Then the lights go crazy.
The Tahoe ground then tests “hot”
Tahoe lights: none on trailer
Brakes lights: none on trailer
Left Directional: good on trailer and Tahoe
Right Directional: none on trailer; Tahoe works, but both tail lights come on
Brake & left directional: Trailer has left directional; no brakes; Tahoe ok
Brake & right directional: Trailer has LEFT directional; no brakes; Tahoe ok
Lights & left directional: Trailer has left directional; no tail lights; Tahoe ok
Lights & right directional: Trailer has no lights; Tahoe has tail lights, but right directional stays on and does not blink
Both trailers have the same performance.
The Tahoe wiring has never been damaged or under water, and has worked fine for five years.
Can it be the right tail light module on the Tahoe? Wiring harness?
First, I would eliminate any trailer issues (mis-wiring, bulbs, or grounds) as possibly being the problem. To do this, you need to have a separate source of power to manually test it out (don't use the Tahoe trailer connector). You can use either a standalong battery, or build yourself a test power source with a cigarette lighter plug, some wire, and a couple alligator clips.
Powering from the cigarette lighter, connect to the different wires of the trailer and verify that each one is working exactly as it is supposed to. Verify that the correct filament of the bulbs (if you have the assemblies which use dual filaments) are lighting. The bright filament when a brake/turn is powered, the dim filament when the running lights are on. Verify also that you don't have any bulbs where the filaments are broken and crossed over onto the other filament. This will also verify that you ground back to the bulbs is good as well. Only after you are absolutely certain that the trailer is wired and working correctly, do I plug into the back trailer connector.
It is much easier to troubleshoot trailer wiring issues this way. In the first steps you eliminate the truck from being the source of any problems, until you absolutely are sure the trailer is correct. This then eliminates the trailer from being the source of the problem when you eventually connect them together...proving that you have a tahoe problem or not.
Testing this can be a headache and time consuming and many times due to a bad ground if it occurs on most lights.
Kiawah above has posted the best manner to find the faults.
McGyver
I now have a 2009 2500 LT 4X4 (6L, 6 speed, and 3.73 rear end, and trans-cooler, etc.) and tow approx 9K - 10K lbs back and forth from OH to FL with no issues. Used trailer mode. Run in the 75mph range at approx 2200 RPM range and averaged just shy of 10 MPG. Trans temp never was above 150.
Looked at 2007 2500 with 4.1 rear end - gas milage was terrible all the time, and RPM towing was back over 3000 RPM.
If you are only pulling 4K lbs - you should not be having any issues ...
Very happy with my '09 2500 towing ability ...
I think i'm just going to rent a 25ft trailer and get a feel for it and then i'll probably end up sticking to a 4000lb-4500lb target weight for a trailer. I think i'll be within my range for sure. Thx again for your response.
We have a 2008 Tahoe LT (4x4) with the 3:73 gears and the 5.3Lt. It also has the tow package. We pull a 29ft (33ft front to back) Keystone Passport 290bh which is 5,100lbs dry and has a 500lb hitch weight. Our hitch is a Reese with the weight bars and a slide sway bar. I have left the sway bar off at times and i know its not there, but nothing that would scare my wife or I.
I have pulled this camper 70+ mph down the highway, but usually run around 65. Put the vehicle in 3 and press the tow/haul button and the vehicle will pull this camper great. I am actually looking at a bigger one weight wise. I don't dont know why yours would sway that bad? Is it possible that you are loading all your gear in the front or back and not distributing the weight in the trailer? Wish i could help, but mine seems to do the job very good.
My plan is to buy a travel trailer and see the country with the wife and three kids. I was told the same thing about getting a P/U but like you, it was not an option.
I would also like to know about increasing gas mileage. Should I put a new exhaust or air flow system on it?
Any suggestions would be appreciated.
