Subaru Forester (up to 2005)
It does take a while to order Foresters, since they are made in Japan.
Craig
Last week, I brought the car in to the dealership for a maintenance item, and was talking with the service writer about this. He said that I should have the oil changed every 3000 mi, regardless of what the manual says. He said that more frequent changes are needed because of the oil breaking down....not because of the car's capabilities.
So....what is the truth here? I must admit that when I hear different stories from within the same organization, it challenges my already shaky faith in the automotive profession.
-Frank P.
-Frank P.
tidester
SUVs
I think the main reason I had to wait so long is that the dealer stated they had trouble finding a S model with a 5-speed in the Silverthorne color. Also, the time frame in which I bought the car was nearing the end of production for the 2000 models and beginning the 2001s. I believe the dealer did install the options that I requested. Looking back, it was worth the wait (small lesson in patience).
Michael
-Frank P.
-Frank P.
-mike
Frank
I'm also concerned about the next generation gaining weight. I hope it's not more than 100 lbs or so heavier than the current models, 150 tops.
The hitch - there are 7 bolts. You do need to lower the muffler. There are rubber "hooks" that you can slide off, my hint is to get them wet to make this easier.
You have to remove two tow hooks first, one on each side. Those same bolts can be used to secure the hitch. I do not recall removing any bumper mounting bolts, at least on my 1998.
You do have to remove the vapor canister (holds fuel system vapors) and some tubing that connects them, and then re-install it after the hitch is in place. It's easier than this sounds. Forget a tube and you'll get a CEL, most likely.
I had torque specs on my installation sheet, I believe.
I will e-mail you the photos I have, since homepage.com and PhotoPoint both went under, and took my sites with them! :-(
-juice
The dealer I purchased it at told me it was the tire pressure. They let out some air and it did nothing. I went back and this time they said they definitely would do an alignment. It seemed better but only for a short while.
I took it to another dealership and they said it was pulling left and a rotation of the tires would fix it. Now it's pulling to the right and when they removed the back left wheel they scraped up all around the lugs and also portions of the wheel now show black where it was silver before. Can the scraped up wheel be made to look right again I was about to call the dealer and complain.
One more thing - you have to remove one of the exhaust hangers, and reinstall it below the hitch. I damaged mine slightly while doing this, but managed to twist it back into shape.
-juice
Your tires may be out of round, or worn unevenly, if it was driven with bad alignment for 6700 miles.
-juice
A friend of mine had his alignment done at a local Subaru dealer despite my warnings. Several thousand miles later, he began noticing uneven wear on his brand new tires. He finally took it in to the shop I recommended and it turned out that the dealers alignment equipment were not calibrated properly resulting in all four tires to be consistently off.
Ken
If you (or anyone else) can get the torque ratings on the bolts, it'd be appreciated.
Joe
p.s. I do remember the old forum search from a couple years ago. I tried to do that again, but found that I couldn't.
John
-juice
This is sort of like rebooting your PC!!!
Anybody else experienced any problem like this?
Any ideas why this may be happening?
-juice
Have you tried downshifting in slow traffic?
tidester
SUVs
No - I haven't. I have an automatic and I just leave that in drive?
Hope this helps,
-bv
Sil
Our engines are not as demanding and can get by just fine with regular oil. It's probably overkill to use synthetic but you can expect:
- slightly better gas milage ~1mpg
- quieter cold startups
At least that's been my experience.
As for the change intervals, yes, you should be able to go longer with synthetic. The exact amount depends on your driving conditions, but it's not uncommon to go 5-7K miles between changes without problems.
Ken
Last I read the dealer was trying to get him to pay for installing the cdplayer.
-Frank P.
I called SOA on Wednesday of last week and dealt with Judy (instead of Patti?). She had a few days off at the end of the week, though, so I didn't hear back from her until yesteday.
After she looked at my faxed purchase copy, she said that I'd be getting the CD player and installation for free. She couldn't promise that the dealer would pay for those up front, but she did say that SOA would cut me a check to reimburse anything I had to spend.
She was going to try to contact the manager yesterday (good luck!) and said that she'd get back to me with the final details as soon as she could.
Cheers to SOA!
Jeers to the Dean Team dealership (somebody had asked which dealership it was) in St. Louis!
Thanks again for all the concern and thoughtful advice,
Paul
Paul -- Glad to hear that everything seems to be working out. It's true -- SOA does care about us.
Ken
Patti
Patti
Patti
This morning when I went to start my baby she started right up but stalled immediately, after about the 3rd time I gave her a little gas and she stayed running. This is the first time I've had this happen but it's also the coldest morning we've had (single digits) all season.
My husband had a remote start installed for me for Christmas (gotta love that guy!)but I don't think that's it since it's worked flawlessly for 2 months now. (I highly recommend them to anyone living in snow belt!)
I'm taking her in for an oil change next week so I figure I'll have the dealer look at it, just thought if anyone had a similar problem, I'd know what to look for.
Thanks for your help!
Barb
Bob
http://www.media.subaru.com/
In-window antenna. No HID :-(
Looking at the foglights, I wonder if it is detachable?
And, 2.5XS... what would that be?
-Dave
tidester
SUVs
Back lid says 2.5 XS...?????
Anyways thanks for the good link and an early peek at the new Forester.
ie: 180+HP, higher torque, better power & torque curves, better mileage etc etc.
And let's hope the 2.5XS means there will be a 3.0XS as well
Also looks to have some nice ground clearance.
-mike
They managed to take most of the "awkwardness" out of the previous design.
Much more attractive for me anyway.
And, we have yet to hear how they have improved the mechanicals and ergonomics etc.
I think what you see is basically what you get for the next 4 or 5 years.
Except maybe a Turbo in 2004.
Otherwise "GREAT JOB SUBARU!"
Can't wait for more pics and info!
Seems to me that the outside mirrors are smaller than my 2000's...maybe to cut out wind noise?
Michael
I like it.
I do like the way it looks overall. Not a huge change but enough to keep it interesting. I've noticed there is more consistency with the current product line -- corner lights and fog lights are more Legacy-like. The back is kinda strange on the photos, though.
Don't forget that even though the sheetmetal changes aren't that big, the chassis has completely changed over to the new Impreza.
Ken
Ken
But seriously, is your husband more concerned with the car's performance, or whether or not the ol' testosterone count is goign to go down. I'd recommend 2 things:
1. Buy the Forester
2. Buy some viagra just in case...
I hope he doesn't choose an inferior product because of marketing. A car is a car - if it sucks it sucks. The Forester happens NOT to suck, so who gives if most of the people purchasing it are women?
...just one man's opinion. And yes, I'll be purchasing a Subaru Forester - I think it accentuates my feminine side, and I hear that's REALLY good for picking up babes...
d
-mike
