Isuzu Trooper: Engine Oil Leaks
                    Hi, My husband and I have a 1995 Trooper with two leaks; one in the valve cover gasket and one in the seal. I got an estimate to repair these for around $300. My husband is leary because he thinks that once we replace engine parts the car may be damaged or other things may go wrong.  Aside from the fact that I mentioned to mechanic that we didn't want to spend alot of money, since our neighbor has agreed to buy it as long as we repair the oil leaks.  Does anyone have any knowledge of whether it's okay to replace these parts?
I include the manual directions for removing the LH and RH, in that order, valve covers.
Hope this helps, good luck.
SERVICE INFORMATION
Some affected vehicles may experience oil accumulation in the spark plug tubes due to oil seepage at the spark plug tube-to-cylinder head interface.
To seal off the seepage, replace the original spark plug wire set with a new, improved spark plug wire set (see Parts Information section) using the procedure described in this Service Bulletin. The new spark plug wire set has an improved bushing design that controls oil seepage at the spark plug tube-to-cylinder interface.
SERVICE PROCEDURE
When servicing affected vehicles experiencing oil accumulation in the spark plug tubes due to oil seepage at the spark plug tube-to-cylinder head interface, be sure to refer only to Service Bulletin SB96-01-L005, issued 9/96.
The authorized repair for affected vehicles experiencing this condition, is to replace the original spark plug wire set with a new type wire set which features an improved bushing designed to control oil seepage at the spark plug tube-to-cylinder head interface. SB96-01-L005 describes this authorized repair.
1995 Isuzu Truck Trooper (4 Door) V6-3165cc 3.2L SOHC (6VD1)
Vehicle Level Technical Service Bulletins All Technical Service Bulletins Cylinder Head Cover - Installation Precautions
BULLETIN NUMBER
SB94-01-003
ISSUE DATE
DECEMBER 1994
GROUP
ENGINE
TROOPER (UX) AND RODEO (UC) CYLINDER HEAD COVER DAMAGE
AFFECTED VEHICLES
Trooper (UX) and Rodeo (UC) models equipped with 6VDl engine.
SERVICE INFORMATION
When installing cylinder head covers on affected vehicles, care must be taken to ensure that the head cover bolts are properly tightened. Use only a good quality torque wrench and tighten only to the specifications listed in the appropriate Workshop Manual. Do not use air impact wrenches to tighten cylinder head cover bolts. Air wrenches tighten the bolt until the corner tab on the cylinder head cover either cracks or breaks (Figure 1). Once the tab is damaged, an oil leak will result. This damage can be incorrectly diagnosed as a leaking head gasket or a rear main oil seal. Cracked or broken cylinder head covers due to over tightening are not covered under warranty.
Vehicle Level Engine, Cooling and Exhaust Engine Valve Cover Gasket Parts Information
Parts Information
Part OEM Part Price
4 - Valve Cover Gasket 8971395690 $38.05
REMOVAL
Preparation: Remove battery ground cable
Ignition wire
Disconnect from spark plug side.
Positive Crankcase Ventilation hose
Disconnect from common chamber.
Disconnect vacuum hose from throttle body.
Engine harness bracket
Remove fixing bolts on cylinder head cover.
Exhaust Gas Recirculation (EGR) pipe
Remove two fixing bolts on exhaust manifold.
Remove two valve fixing bolts on common chamber.
Cylinder head cover
Remove 11 fixing bolts then the cylinder head cover.
INSTALLATION
Fig. 6A1-3
Cylinder head cover
Clean the sealing surface of cylinder head and cylinder head cover to remove oil and sealing materials completely. Apply sealant (TB-1207b or equivalent) of bead diameter 2- 3 mm at four places of arched area of cam- shaft brackets on front and rear sides.
Tighten cylinder head cover bolts to the specified torque above.
Tighten valve fixing bolts to the specified torque above.
Exhaust Gas Recirculation (EGR) pipe. Tighten each fixing bolt to the specified torque above.
Positive Crankcase Ventilation hose and vacuum hose
Ignition wire
RH Side
REMOVAL
Preparation: Remove battery ground Gable
Common chamber See: Intake Manifold\Service and Repair
Ventilation hose
Disconnect from cylinder head cover.
Fuel hose
Disconnect feed and return hoses from fuel pipes.
Remove two fuel hose fixing bolts on the cylinder head cover.
Engine hanger
Remove heat protector on exhaust manifold.
Remove bolts and nuts that secure the hanger to the exhaust manifold and cylinder head.
Heater pipe
Remove heater pipe fixing bolts from the bracket.
Cylinder head cover
Remove 11 fixing bolts, then the cylinder head cover.
INSTALLATION
Cylinder head cover
Clean the sealing surface of cylinder head and cylinder head cover to remove oil and sealing materials completely. Apply sealant (TB-12O7B or equivalent) of bead diameter 2- 3 mm to four places of arched area of camshaft brackets on front and rear sides.
Tighten Cylinder head cover bolts to torque of N.m (lb.in) 8 (69)
Heater pipe
Bolt Torque
Tighten bolts and nuts to the specified torque above.
Fuel hose
Ventilation hose
Common chamber
http://www.carspace.com/atfdmike/Albums/trooper/90 isuzu.gif/page/photo.html#p- ic
You may just have a rocker cover gasket leak. If you have adjusted the timing by rotating the distributor, the gasket there may be bad(cracked,leaking) Pretty common problems.
good luck
2.8 v6 1990
I have a oil leak that is on the drivers side of the engine near the front..I cannot find its location of the leak It is Not valvecover, not oil pan.not oil filter .it begins to drip once the car is started for a few moments..i have read it could be the oil cooler hoses? where are they located? it is hard to determine the location. Is their a diagram of the cooler hoses? any other possibilities?any suggestions would be helpful
Thanks everyone
Roelof
I once had a hose chaff on metal and busted draining almost all the engine oil.
I just happened to notice smoke which was burning on the exhaust to stop in time.
The two hoses run from the side of an adapted oil filter housing connected to aluminum fittings which are routed through the oil cooler in the grill to the drivers side. It is very hard to get to the connections at the oil filter housing with limited view. Remove the left front tire,unbolt and move power streeing pump out of the way to gain access.
Use a good drop light to see your work. I removed my hoses and brought them to Napa Auto store to repair them. $34.00 a piece to fix.
Hope this helps! Good luck!
