Subaru Forester (up to 2005)
18889919394344
    burnsmr4: I hadn't heard complaints about that until just now, but NHTSA does allow you to register safety concerns on-line, quickly and easily. If they get enough, that's when they open an investigation and look into a TSB or recall.
    -juice
  • subearusubearu Member Posts: 3,613
    remember, there's at least 2 Brian's on these boards now.
    btw, here's the post: subearu "Subaru Crew: Photo Gallery" Feb 17, 2002 7:11pm
    -Brian
  • vonnyvoncevonnyvonce Member Posts: 129
    Like usual having trouble making car buying decision and now might wait for 2003 Forester. Might the 2003 have a timing chain and does anyone have experience with the auto hvac in the Outbacks and could you give a review of climate control performance.
  • armac13armac13 Member Posts: 1,129
    Nope, it'll have a belt. It gets the Phase II engine. Change interval is a whopping 105k miles, though, so it shouldn't be too big of a concern.
    One dealership is spreading a rumor of a turbo with 238hp for 2004, and if that's true, I'll own 2 Foresters.
    I have tinted windows, 35% on 7 of them, but the A/C is bone-chilling cold. I put the vent on "1" and still have to cycle the A/C on and off manually or it's too cold.
    -juice
    I wonder if that bulb in the top, outer corner of the headlights is the DRL. Fogs look better up close.
    Sweet! We basically get WRX seats, with even more bolstering, and the ratchet type height adjustment. Plus side air bags even on S models. That may appease the folks that wanted a higher seating position.
    Dash looks to have higher quality plastics, and the overall looks resembles the Acura RL (I just read that review). HVAC buttons are inside the circular knobs, neat. I also like the little storage net in the passenger foot well.
    The underside looks the same as the current one. I see the fuel vapor canister I had to move to install the hitch. Diffy looks the same, even the exhaust has a kink in the same place. I'd call that a 13mm sway bar, maybe 15mm. My 18mm upgrade is thicker.
    The rear seat does not look much bigger. I wonder if the front seat has more travel than before, that's what Subaru claimed. Did you sit in it, to see if there is more room front and rear combined?
    The cargo area may be slightly bigger, it's hard to tell. Those nets are cool, though.
    Way to go on the pix, you are da man! :-)
    -juice
  • ffsteveffsteve Member Posts: 243
    vonnyvonce, the Auto HVAC works great! After enjoying its benefits in my last 3 cars, I am loath to go back to the manual variety.
    I just leave it on in the Bean all the time. If I don't feel AC is necessary, I just push the button to disable it. Otherwise I have not found it necessary to use any of the other manual controls - oh, other than the "Recirculate" button, which gets hit whenever I get a hint of diesel exhaust.
    The system maintains a constant temperature and the AC is able to keep the car cooled to the set temperature even in desert conditions (108F) even before window tinting was applied.
    Go for it,
    Steve
    Yeah, I sat in the front and back seats of the Forester at the show. The only problem was I didn't have anything to compare it to (haven't sat in an 'old' Forester). It seemed about as roomy as our Outback, but that's subjective.
    The HVAC controls are neat. If that corner bulb isn't the DRL, then I don't know what it could be. (see picture #46) Unfortunately, I couldn't turn the lights on (need the key). Like the fogs w/o the grill on 'em.
    -Brian
  • artdechoartdecho Member Posts: 337
    check this link for more 2003 info....mainly jdm
    http://www.auto-asia.com/viewcontent.asp?pk=6792
    does appear that seating position is higher and range of height adjustment is double what it was before......also says more space between front & rear seats and a new front seatback design for even more kneeroom......time will tell.
    That's good, though. The '99 Outback was little roomier than the Forester, but the 2000 and later models are a lot roomier. If the new one is close to your OB, they added more space than I thought.
    You can pop the grille guards off the current models by just twisting it, I've heard.
    -juice
    OK, for the first time they mention the rear strut suspension, so we officially are not getting the rear multilink setup from the Outback. :-(
    In Japan, a rear LSD is standard? Wow.
    What are rebound springs? I don't get how they are different than now.
    Front and rear stabilizers, they mean anti-sway bars, enlarged. The photos looks like 15mm or so, it was 13mm before.
    $20-25k prices are where they are now. Hope so.
    They mention space is expanded between the front and rear seats, but how much? Is it just the 1/2" from the longer wheelbase?
    AT models get throttle-by-wire, that's interesting.
    Length is about the same, as is width. But height is lower - my guess is that's because they don't get cross bars in Japan. It's probably the same.
    -juice
  • scirocco22scirocco22 Member Posts: 721
    michael-- Thanx for posting that link. Some points that I found interesting:
    Lower (?) ground clearance than the old model (but higher seating position to enhance field of view).
    Lower rolling resistance with new tires for possibly better gas mileage rating.
    Braking system much improved (I'm unimpressed with my brakes).
    Rear luggage space has been enlarged by reducing the projection of the rear strut suspension brace as juice was hoping would happen.
    "N-control" function in automatic transmission models.
    Oh, and yes, the fog light grills do pop off easily ...I've taken mine off several time for cleaning purposes.
    btw, a friend of mine has a new Civic and they have similar "tiny" bulbs in the headlamp cluster. Although the Civic doesn't have DRLs, those lights serve as running lamps and are pretty "cheesy" looking(very low amp) according to my friend so hopefully they alone won't be exclusively DRLs.
    --'rocco
  • goldencouple1goldencouple1 Member Posts: 209
    I think that 200mm ground clearance is actually more than we currently have. 200mm works out to about eight inches. I think the old spec was 190mm. Perhaps it is an issue of the place from which it is being measured.
    re: ground clearance --In the text of the article it implies 200mm but down in the specification section at the bottom, it states 190mm.*shrugs shoulders*
    --'rocco
  • danjaecksdanjaecks Member Posts: 54
    caperosier: Thanks for your review of the Mich Sym. That is one of the tires I've thought about to replace the slippery Yokohamas that came with this car. Did you think they were significantly better on ice than the Duelers? I see the new Forester has a different tire model. If they are better than the current tires, that may be the most important improvement they made. (If.)
    Re: Cel's, gas caps, fuel tanks not filling etc. Some people seem to be trying to blame these things on the consumer or the government. In my opinion, if consumers are having unusual problems with their cars it's the manufacturers fault and the problem should be fixed free and as fast as possible. Nobody is purposely trying to make the CEL come on, etc. and if these parts are failing then it is the result of an inadequate (i.e. cheap) design on the manufacturers part. This is like Toyota trying to blame it's customers for their engines sludging up! (Like a bunch of evil consumers all of a sudden banded together to buy Toyotas and give them a bad name or something.) Everybody and every company makes mistakes, but having taken the money, the manufacturer has a responsibility to fix any design problems that crop up.
  • kenskens Member Posts: 5,869
    I think the ground clearance comment is a typo. On the SOJ website, it shows the same amount of ground clearance. That's also echoed in the US press release.
    Looks like they've tweaked the 4EAT again. How about a 5EAT?
    Did anyone notice the caption under the second photo mentioning that North America is the most important market for the Forester?
    BTW, I've also removed the grilles on my fog lights. It's easy. Just pull the bottom down and out and it should pop right off. I think having them off gives the Forester a cleaner look. Plus, those grilles are only good for really big rocks. If I ever came across those on the highway, my fogs would be the least of my concerns.
    Ken
  • p0926p0926 Member Posts: 4,423
    Burnsmr4- Sorry to hear about your gas tank problem and yes, anyone would be disappointed to have to put their brand new vehicle back in the shop. Still I think you need a little perspective, this doesn't strike me as a safety issue. At least not from what you've described and my understanding of the way the fuel system works. From your symptoms, it does indeed sound like you have a plugged gas vent tube. This tube is used to equalize the air pressure within the tank when filling. When plugged, the pressure builds up; the gas pump (which has a pressure sensor) detects the increase and assumes the tank is full and shuts-off automatically. Modern gas pumps are intentionally designed this way to avoid a fuel spill (which would be a safety issue). FYI: Had you had a gas can handy, you could have filled the tank with it since the flow of fuel from the gas can isn't as great as that from the pump, thereby letting the vapors escape thru the neck of the tank.
    -Frank P.
  • tincup47tincup47 Member Posts: 1,508
    The gas cap issue is a customer problem. If you follow the recommendations of tightening until it clicks several times it shouldn't happen. If it is a defective fuel cap you would have the problem happening every time you fill up. In that case it is a manufacturers defect. Unfortunately there is no reliable way for the manufacturer to make sure that the consumer tightens his gas cap sufficiently, so unless they had full serve pumps at the dealerships I don't see how they can be held responsible. The light is mandated to come on by the government if the cap is loose.
    ffsteve Thanks for the info regarding climate control. Like that you can default the ac to off, sometimes these systems are too smart for thier own good. Hope the Forester's hvac is similar.
    Juice, If it's too cold in the Forester with ac and tint why not add a touch of heat, easier than ac on and off. BTW juice, Teixiera I assume of Portuguese descent, Medeiros here in Massachusetts.
    The article probably meant lower step-in height. The ground clearance is still listed at 190mm, or 7.5".
    Tires for the US will be Yokohamas, 215/60R16. But I think it's a different tire than the current one.
    Yes, Teixeira is a Portuguese name. My family is from Brazil, but I've traced them to Portugal and Spain.
    -juice
  • lark6lark6 Member Posts: 2,565
    The "black Forester S with fog light grilles removed" club, that is. My primary reason for removing was ease of cleaning, but as you probably caught here, I did install 3M Stongard (a/k/a "clearbra") on the lights. The grilles will clip back on over the Stongard but it's not as easy to get them back on as before.
    Ed
    I remember seeing a photo on the Japanese site thst showed clearly 200mm from ground to...whatever they were measuring to. I remember, the "just height" tab showed that photo.
    Ed,
    Actually, you were the one who inspired me to remove the grilles, well sort of. I think way back I saw a photo of your S and thought, "hey, it looks good without the grille covers" but never got around to doing it.
    Well, a few months after that, I had my little fender-bender incident up in Yosemite in the snow. The impact to the snow bank popped off the left fog light grille and instead of popping if back on, I simply removed the right one to match.
    Looks much better. Anyone else care to join the club? ;-)
    Ken
    can silver guys join the club? :p
    --'rocco
    I'll let Ed decide that since he's the founder. I'm sure he can make exceptions. ;-)
    Ken
  • logtraillogtrail Member Posts: 74
    After over a year of having a problem with my 99s
    cutting out suddenly and more recently stalling or not starting and having it in the shop numerous times, the last time I had it in it would not start for the area rep who was at the dealer. Horray. Diagnosed as a faulty fuel pump relay. Car has been ok for a week. For those of you having similar problem this might be the cure.
    U.S. Subaru customer service was very helpful. (Fortunately since I was reaching the end of my patience.)
    For those of you who haven't seen this article posted by Paul over on the i-club board, its author sounds as if he's sure the 2.0 turbo will be here (U.S.) in early 2003 (next spring?). It's an article written, I guess, for the Australian market but notice the title. (?)
    http://www.apexjapan.com/news/forester_02/forester_02.html
    --'rocco
    p.s. Now that I think of it, a silver with grill-less fogs won't look half as sharp as black ...but I think I'll apply for membership anyway. :-)
    I don't think the '03 Forester's wheelbase is any longer than the current model. I found the metric wheelbase listing a few days ago, and did the inch conversion, and it came out to 99.4", which is the same as the current model.
    Bob
    I guess this has been discussed before so disregard the article I posted above.
    ...apologies
    --'rocco
    Maybe clearance is better, then? That works out to about 8".
    Does that mean I have to paint my Forester black before I remove my fog grilles? ;-)
    Paul: glad to hear it's working. Keep us posted, please.
    The article says legroom is improved "only slightly".
    -juice
  • mainemojomainemojo Member Posts: 16
    First, a few words of thanks to folks on this board and at SOA (Patti and associates) for helping out when our new platinum silver S+ turned lemon-yellow. After four attempts in the first month of ownership to remedy CEL warnings, including replacing the O2 sensor and the fuel pressure regulator, the dealer and SOA stepped up and offered us a new car -- no Lemon Law intervention needed -- which was delivered to our home last week. The entire process, from picking up No. 1 to delivery of No. 2, took six weeks. We drove loaners for a total of about three weeks, and my wife lost her patience with an ignorant finance guy at the dealership at the end of the process, but all told it was handled well and much faster, I'm told, than most other car companies.
    Now, the question: Subaru recommends not driving long distances at constant speeds for the first 1,000 miles. So, what's long -- 50, 100, 250? And doesn't that suggest avoiding interstate highways?
    Mo
    Mo-- Nah, not at all ...just vary your speed on the interstate is all. If it's necessary to go on, say, a 250 mile non-stop jaunt for instance, just vary your speed now and then. Example, don't keep it at a constant 70 mph for prolonged periods ...drive 60 for a brief time then kick it back up to 75, etc. In-other-words, keep both the rpms and road speed varied on the interstate during that "break-in" period. However, try not to rev it over 4,000 rpm unless for an emergency purpose until after reaching the 1,000 mile mark.
    Good to hear that you finally got a resolution to your problem. And it's good to hear that SoA and Patti worked with and for you! You're right, IMO, most other manufacturers probably wouldn't have been as accommodating as SoA. I've really heard some horror stories from owners of other brands of vehicles.
    Continued good luck!
    --'rocco
    Mo: there is a bad apple in every batch, even for the tastiest apples. I'm happy to hear SoA took care of you, and you persisted, well done.
    For the break-in, use freeways, just don't use cruise control. If you notice you're at the same speed for a long period, just slow down or speed up a few mph. Generally I'd say take it easy on the brakes and tranny, too, when possible.
    -juice
  • rictomrictom Member Posts: 89
    Patti: my inlaws just had their 99 forester engine blow--due to no oil, just after they had it to a dealer for routine maintenance. I dont' know all the details, but if they have a case and want to start a case with SOA and ask for you, is Patti enough? or do they need a last name?
    Rick- Has the dealership already denied responsibility? If not, then I think your in-laws should work with them first. Although I'm sure she doesn't mind, I don't think we should take advantage of Patti's presence here until other avenues of recourse have been exhausted.
    Just my .02,
    -Frank P.
    Mo -- That's great news. I'm glad everything turned out right. A little patience goes a long way.
    rictom -- Ouch! That sounds like the dealer messed up somehow. Have your inlaws contacted the dealer? I'd try contacting the dealer first to see what they say.
    In any event, you can set up a case without even mentioning Patti's name. Just call 1-800-SUBARU3, request a case # and explain what happened. Having the case # established makes it easier for Patti to track in case things get complicated.
    Ken
  • bsvollerbsvoller Member Posts: 528
    While we're on the topic of dealer experiences, I related a problem a while back we had with our bug shield coming loose and destroying the paint on our hood, and how the dealer stepped up and offered to paint the whole hood and both fenders no questions asked.
    Well, unfortunately, that wasn't the end of the story... When I went to get the car, I discovered that not only was the paint job sub-par with lots of bubbles and hairs in the paint, but they also had cracked my windshield.
    Once again they stepped up and offered to make it right, although at this point I was getting pretty exasperated. To add insult to injury, I got a flat on the loaner they gave me, and it shifted really rough ('99 Outback, but a bit beat up).
    So yesterday I picked up my car for the third time in 4 weeks (7 trips in all to the dealer). They had indeed replaced the windshield (I have an '01 S+ with the heating element in it -> $), and the paint job is first class.
    Driving home I discovered that the service manager had taken it upon himself to adjust my parking brake and firm up the pedal, remembering that I had discussed a soft pedal a month earlier when this all started. I had not specifically asked them to do this, thinking that the brakes probably were just softer than I like, i.e. that there wasn't much they could do.
    I'm still planning on trying steel brake lines when we hit 30k later this year, but we're definately getting more bite than we did and the pedal's firmer.
    I must say that their extra effort to satisfy me really made a bad situation a lot more tolerable.
    Kudos to Flatirons Subaru in Boulder, CO. Now if they could just get things right the first time...
    Glad to hear that things are being sorted out. "Better late than never" ... but much better if not late. I must say that I have been rather surprised at the "lack of bite" comments about the brakes on the S. The brakes on Rufus (MY 2001 S) are by far the best I've ever had. I find them very easily modulated, the stopping distance is very short, they are wearing *extremely* well compared to the MT Golf Rufus replaced, they are silent and they produce very little dust. For me, the brakes have been one of the best features on an excellent car. They do say, however, that "your mileage may vary".
    Ross
    Transmission question. I'm asking for a coworker. She's got a 2002 Forester L with an automatic transmission. Only 5K on it so far. Here's the problem:
    When she comes to a full stop, with the engine idling, she "feels" a grinding or low clunking noise. It's an intermittent sound. So far, she has not heard it while in park, only while in drive. Once she starts driving forward, the noise stops. It doesn't matter if the car has had a chance to warm up.
    Any suggestions?
    All: My inlaws are dealing with the dealer at the moment, but it's not going well. Lots of denials and the latest I believe is the dealer quoted them about 5k for a new engine--I dont' know if the dealer will pay some/all, if this is high or low. They also said the car is worth 8k--with or without an engine? It's a little hard to look up a price on kbb, they don't have a 'no engine' option, but assuming it had an engine the lowest kbb price for the model/options/mileage they have is still 10k.
    I'm getting this third hand; from my sister in law to my wife to me, and my brother in law who's dealing with the whole thing is trying to do this while also trying to do his job, which involves traveling so that makes it tougher.
    We'll wait to see what the dealer does before he opens a case. Thanks everyone.
    Varmint: the auto trannies have been pretty good, so it's not anything I've specifically heard of before.
    I would have the dealer check the ATF, maybe even flush it while she's at it. Have her dealer look at it, though, before it becomes more serious.
    If they can't (or won't) help, have her call 800-SUBARU3 to open up a case number. We'll put her in touch with Patti Mickel of SoA. She's our rep from Subaru, and pretty much wear a costume with a big "S" on the front, if you know what I mean. Though I doubt she'll get a hard time because it only has 5k miles.
    If you don't mind, please keep us posted.
    -juice
  • davidwattsdavidwatts Member Posts: 3
    Hello. I am brand new to this board so forgive me for being green.
    I can't seem to find a SEARCH function for all past posts on this board. I am trying to find out how many others have had premature rear wheel bearing failure with the Forester.
    I recently had to replace both rear bearing and hubs at a cost of almost $1,000 (1998 Forester 70K No Warrantee) and I am not a happy camper...... Especially since the small amount of research I have done on the Net reveals that I am far from being the only one. It seems that this can happen more than once and at these prices I am quite freaked about it
    FYI this link was interesting
    http://www.raindrop.com/subaru/wheelbearings.html
    If anyone has anymore on this subject like more links, possible recalls in the making, or any other help I would greatly appreciate it. Thank You.
    Thanks Juice. I don't think it'll need to be taken up with SoA. She seems patient and doesn't mind getting the car fixed as long as it's done under warranty and she doesn't have to bring it back six times.
    Cool, if she does get hassled, let her know we can pull strings for her.
    Jim: it's not rare, but I wouldn't call it common, either. But at that mileage, it could have been from normal wear and tear.
    It happened to our Mazda 626, with 71k miles, and I paid about $900 for just one hub/bearing replacement. Subaru's parts must be a lot cheaper than Mazda's, because you did two sides for about the same cost.
    You could call 800-SUBARU3 and bring up the article. I'd be very surprised, but maybe they'll offer a partial reimbursement? I doubt it, but it's worth a shot.
    The good news is that the 2002 Impreza went to a new hub design that is less susceptible to improper installation. I'd be willing to bet that the 2003 Forester gets the same new hub design.
    -juice
    Welcome. While most of us here like our Foresters not all of us have had completely happy experiences with them. I had the rear wheel bearings fail on my 2000 Forester at 8K miles, which were repaired under warranty. They failed again at 13K miles. Upon further investigation it was determined that the bearings were improperly installed by the service technician; specifically they were overtorqued. There is a Subaru technical service bulletin on this subject. I had the bearing replaced, again under warranty and under the supervision of SoA (I opened a case with them). I currently have 35,200 miles on the car and the bearings have not failed again...yet.
    The wheel bearing problem has also struck owners of the last-generation (pre-2002) Imprezas, including the 2.5RS and Outback Sport. It is possible that the problem is inherent in the design of the bearings themselves. I cannot confirm if it's an authorized practice, but I have read of Impreza owners having those bearings replaced with Legacy bearings, which are of a different design. At any rate it is a known problem, and I'd recommend that you bring it SoA's attention if you haven't already.
    Fortunately there is an SoA representative (Patti) who frequents the Subaru Crew boards and who has proven helpful to many of us, myself included. While you have already incurred out-of-pocket expenses it may still be possible to get some sort of resolution to the matter. (Edit: I see juice beat me to the punch, and much more informally ;-) .)
    Good luck,
    Ed
  • burnsmr4burnsmr4 Member Posts: 318
    I got my car back after three days with only a few minor "shop grime" spots on the interior of the rear passenger-side door frame. I wish they'd Armor All or something if they get the interior trim dirty.
    The problem was a faulty vent valve that goofed up the air pressure in the gas tank. Kept making the pump and the tank thinking the car was full of gas. The service director drove the car himself and paid cash out of pocket to fill up the car at a nearby station. Went full tilt on the pump handle without a hitch.
    I'm gonna try putting in a little gas myself tomorrow -- haven't been able to because the tank is full. Pray for me.
    I think my experience at the dealership was great. They were very nice, thorough, and didn't charge me a dime except for the gas I used in the rental. That was Enterprise, though. Nothing I could do about that.
    I'm back in my nearly 2-week-old Forester S and ready for tomorrow evening's road trip. Wish me luck!
    Glad to hear that.
    Coincidentally, I read that Hyundai had a recall for the same problem you had. You may want to report it to NHTSA just in case, so they have records.
    -juice
    Welcome to the Town Hall! You've already made your first post so you're about a third of the way to becoming a pro!
    Our search function is basically broken. I am assured by Edmund's management that it will be fixed only I can't give you a date for that.
    In the meantime, we're looking forward to hearing a lot more from you!
    tidester
    SUVs
    I wouldn't say my brakes are awful - I've driven far worse - just not up to my standards. Ironically, we've had a Nissan and a Toyota, both entry-level vehicles, with much better brakes. That's the frustration.
    OTOH, my old Plymouth Sundance was so bad, you practically had to throw an anchor out the window to stop in a hurry... absolutely awful pedal.
    Someone made the point recently that too grabby is a bad thing as well, which is well taken, but I do prefer a firm pedal and plenty of initial bite, which I then modulate of course. Just me I guess...
    I'm much pleased with the change. They didn't give me details, but apparently they went over the car and "serviced" it. It was due for the 22500 service. I suspect they found the pads glazed.
  • declansdaddeclansdad Member Posts: 120
    ritcom: I too had this happen many years ago...I took my 1990 Storm GSi in for service and the dealer forgot to put oil back in the engine.
    Lost cyl. #4 and the engine locked up. I had a huge battle with Jeff Legum Chevy (no longer here in MD) and they were no help. Service manager told me "get a lawyer, you can't prove a thing."
    My $.02, contact SOA and have your in-laws write a letter. Also have them send copies of all services performed on the car.
    My situation turned out OK...I was a huge pain in the @ss and GM covered everything under their "Goodwill Assistance Program."
    Best of luck!
    Michael
