Volvo S70 Starting Problems
I tried to start my 1999 Volvo S70 AWD Turbo. It acted real rough, kept stalling and black smoke came form the exhaust. I was able to limp it home but it will not even start now. I know I have a bad downstream O2 sensor, but I don't think that would cause all of these problems. Any ideas?
I live in central Alabama, and I am hoping there might be someone on this forum who can give me some maintenance info and costs for the area.
Most of all, and I guess this is a question for you gentlemen on the forum, would you feel comfortable putting your wife, sister, mother or daughter in such a car for such a long commute (in the wee hours of the morning, by the way)? And, considering that money is a huge issue here, what kind of upkeep am I possibly looking at?
Also, what are the questions you would ask if you were considering purchasing it?
Thanks very much for your advice and help!
Model: S70, 1998, 2.4 engine.
Situation: Will not start (crank but not run), when cold
plus cooling fan runs after cranking engine.
Repair items which made no difference:
new fuel filter - located by passengers rear tire = $30.
new spark plugs - located engine center under top cover plate (Bosch +4) = $35.
new battery = $65. - love that squeeze type connector.
sensor MAF mass air flow:
located in top corner of intake air filter box.
yes engine will stall when repluging in connector - shows it is working..
Repair items which solved the problem:
sensor water coolant temperature: (eEuroparts.com $30)
plug located by thermostat just under top radiator hose.
unplugged sensor = cold 5.00 K ohms, = hot .36 K ohms.
other side of plug to ECU = cold 5.56 K ohms, = hot 5.59 K ohms.
yes if you run engine with this unplugged check engine light will need resetting.
reset using DTC plug with ODB reader with reset - or Volvo dealer.
plug located in arm rest by drivers seat.
Summary:
Engine would not start when cold because Electronic Control Unit, (ECU) viewed the engine as warm. This was indicated by the cooling fan running after the no start cranking.
No there was no DTC codes showing.
No check engine light was not showing
No the fan relay was not defective.
No the fuel filter was not clogged.
No the fuel pump and check valve was not defective.
No there was good spark to the ignition.
No the key switch was good.
The water coolant temperature sensor seemed ok, did not check to be bad.
How to get running even with this no cold start situation.
(1st way) Open up air intake by loosing hose clamp on rubber flex hose, slide hose back,
Add 3 or 4 tablespoons of raw gasoline.
Start the engine, with full throttle peddle.
This will provide enough fuel to start the cold engine.
The engine will run because there is nothing wrong.
(2nd way) Unplug water temperature sensor
(slide connector off tab holder, squeeze the lock, unplug the two wire connector)
Start the engine. Proves this to be problem.
The problem is the ECU does not provide more fuel for the cold start up because it considers the engine as warm.
Solution: Unplugging the water temperature sensor, this allows the engine to start on a cold 40 degree morning. During this situation of running engine with everything cold and the sensor unplugged apparently the ECU reset itself. After this I simply repluged the water sensor and problem was gone, with exception of check engine light. However this only lasted 2 days then problem reappeared. Then would start only if you turned the key 2 times. Then would not start at all. I then unplugged the temperature sensor and instant start, (rough running until warmed).
I installed new water temperature sensors, problem solved, very easy to do. You don't even have to drain water from radiator (will be a small fluid spill). Remove thermostat cover (Torx screws) unscrew coolant sensor, screw in new one, reinstall thermostat cover, connect wire for sensor, job done, add a little coolant.
He was driving down the road few months later when the oil light came on. He put some oil in it, but it took a while to crank it to start. That lasted for a week until it died whle driving down the road. Then it still took a while to try to crank but never quite turned over, and the battery would drain before it would turn over. so now we have checked the filters and injectors ant they all look fine. the coils all have cracks in them, could the be shorting out through the head and not be getting any spark to the plugs or is it somthing different? We are going to do a compression test soon and i will let you know what the results are.
I know problems like this are hard to describe over the internet so if you have any questions, i will do my best to answer them, any help that you could provide would be very useful. Thank you in advance!!!!!
-jensen
Rich
richsls@shaw.ca
