Subaru Forester (up to 2005)
The car has gone through the recommended intervals on rotations and has had a wheel alignment, even though the alignment was within specs. The dealer is calling this "NORMAL wear".
Has anyone had the same experience or know why this is happening?
If this continues to happen, I am thinking about selling the car and buying a different make.
Mark
If the outsides are wearing, the tire pressure may be low. Make sure you have at least 26psi, and really I would recommend 29psi or higher.
At that mileage you could even complain to Yokohama and get a partial reimbursement. The tires carry a seperate warranty.
Another thought - you should replace all four tires at the same time. Uneven wear could make the AWD system think one axle is slipping. If so, the tires would have to scrub off any difference in diameter, and they sure wouldn't last very long. That may explain your 2nd set lasting only 9k miles.
Bob: does this link work for you? If so I'll just share URLs so all can see them:
http://www.imagestation.com/picture/sraid18/pfd5b46f8a703c9ee7ea0a8311f7b74d2/fdcfb348.jpg
-juice
Something sounds amiss. I went for 45K miles on my Geolandars with my 98 Forester before I replaced them. The tires were not bald at 45K either -- just down to the wear indicators. My wear was fairly even with just a hint of more wear on the outside edges.
I've been to a very reputable alignment shop and the tech adjusted the alignment just a bit (but still within spec) to help counter some of the outside edge wear. My second set of Geolandars that I'm on (25K now) have been wearing perfectly even.
I have a hunch that the outer edges on the tires wear out due to a couple factors:
- Recommended tire pressures are low -- I use 34psi front, 32 psi back on a light load
- The Forester is relatively tall for a wagon and will roll a little more on cornering. If you do drive aggressively, this would speed up wear on the outer edge.
- Some new Subarus have come with the alignment off. Go to a good alignment shop to have them done right -- dealers don't always get their alignment right. A friend of mine who owns a 2000 Forester S was also getting the outside edge wear. He kept going back to the dealer and the dealer kept telling him that there was no problem with the alignment. He finally took my advice and went to an alignment specialty shop -- it turned out that the dealer's alignment machine was off and the toe setting on all four of his tires were off by an equal amount!
Ken
Bob
Ron
It could be the resolution perhaps? Doesn't AOL do some funky compression on images - that could affect it, no? At least you can get to the http: link.
-Brian
Bob
Now that we can all see that photo, ground clearance appears to be about...8 feet! Is that enough for ya? ;-)
-juice
http://www.subaru-global.com/about/history/
Check it out - September 1972 the 4WD Leone was introduced. Look at the photo of the wagon kicking up that sand and you'll see it actually was a spiritual predecessor to the Outback.
-juice
So Subaru is entirely responsible for the existence of the I don't like SUVs, why do you? board. I just may have to have a little talk with Patti :-)
Steve
That's a pretty serious charge! We might want to reconsider this before Subaru's lawyers contact us! ;-)
tidester
SUVs
Steve
Yeah, what tincup said!
-juice
Enough of this! Juice, please get us straying hosts back on Foresters :-)
Steve
We found the car to be comfortable and without a problem. The cruise control worked just fine and lessoned the work load. Hiway mileage was as advertised, 28.6mpg and we had no problem keeping up with traffic when I wanted to. With 2716 miles on the car I'd say we're off to a good start.
Paul
(Get to the point!) OK; what we found was that the Forester is a good half-way house for recovering van-a-holics. The high seat position and the outstanding field of view made us feel right at home. The first time you zip into a "too small" parking space, with room to spare, will make any longing for the old van evaporate in short order. No twelve-point program needed...just buy the Forester!
Patty: I had my windows tinted with aftermarket SolarGard film. It was $170 for 7 windows, and still looks great about 4 years later. We also tinted my wife's sedan for $140 (5 windows), and it too looks great.
I'm now guessing the 2003 models will have only a tiny price increase. We've spotted 3 things that fell victim to cost cutting, so I'm hoping that's enough to keep prices flat. We'll see.
-juice
My two cents.
burnsmr4
If a dent is bugging you and it's not major try a paintless dent removal service. I can't speak from experience, b/c we had a dent in our 2-month old Forester last year and it's still there (there goes any possible OCD membership). But I've heard they do a really great job for roughly $50-75, and they will even come to you in most cases.
Steve
You should spring for an S, because the heated seats will likely come in handy on long trips and in that cold.
Good? Absolutely. Reliable? Currently they sit at the #1 spot above the RAV4, see last month's Consumer Reports. Comfortable? The front seats, yes, especially when heated. They are firm but on a long trip that's probably what you want.
The catch? The rear seat is a bit tight, OK for kids but not for 5 adults across the country.
-juice
Two maintenance tips:
- Have alignment checked by a top suspension shop. Dealers do not always catch alignment problems, resulting in uneven/early tire wear.
- Avoid getting brake rotors turned. Sacrifice an extra set or 2 of pads before replacing rotors. The dealer turned mine at around 55K and they immediately warped. I did the whole thing over again within 10K at an independent shop.
Few complaints for a reliable, comfortable, practical vehicle that has character. Go for it.
John
Plus-- a couple of weeks ago, took car to dealer for oil change and loud aircraft noise from the rear--service person replaced left rear wheel bearing under warranty. Noise stopped.
We also asked dealer to rotate the tires. Next day on the interstate, huge vibration--steering wheel and vehicle at speeds over 55-60--took car to tire shop, had tires balanced--vibration stopped.
Any recommendations on what else to check or do?
Tires? Hmm, that's a 205/70R15 size. I had trouble finding one I liked and went with new 16" rims. But I would not recommend my tires for snow (Nitto NT460).
-juice
Paintless dent removal works great. I had one big fat nagging ding taken out from my door panel.
I'm convinced that alignments are something that anyone can do, but few can do right. When in doubt, go to a specialty shop.
Ken
This is only the second MPG i've figured since I've owned the car. The first was 2 weeks after I bought it with 100% around town driving the mileage was 22 per US gallon.
This tank full consisted of about 80% hiway driving, and even some of that was speed up+slow down, speed up+slow down as we drove through the New York City area. So I figure that the 28.6 miles per US gallon was pretty good.
Paul
Good to go.
-juice
We do have oxygenated fuels here in the winter, but I've never really noticed a big difference in fuel economy.
Best tank was 30.4 coming back from a camping trip in the mountains, loaded to the gills with a Rocketbox on top - go figure !
I've also noticed mileage dives at 80+ on those cross-country trips (no Rocketbox either). We get more like 24 mpg cross-country... oh well, guess you can't have everything, heh ?
-mike
As far as the gas pedal is concerned, I've either got used to it, or its become less "tense" with time. The only thing that is distracting is the drivetrain lash. This may also magnify the surge feeling.
Two days of ninety degrees brings up again an awareness of a slight issue I have with the air conditioner in my 2001 Forester S. Its cooling effieciency is barely adequate. I can get almost comfortable with it churning away loudly on high (inside only circulation set), but can never reach that satisfying point of having to "back off" the controls to continue in peace and contentment.
The dealer's service department checked it out and said it is fine, and that the 2001 AC unit just isn't as good as in the one used in previous model years. What is the experience of you others on this? Is there any tricks or super coolants I can employ as a remedy? Thank you.
Joe
Bob
I did the opposite with my Miata (removed slack), and went too far. The idle was a tad high and the throttle becamse like a pistol (on/off). I let some slack out and it's better.
My A/C cranks, but my windows are tinted. I usually have the vent set to "1" and still have to cycle the A/C on and off to prevent icicles on my nose.
Maybe you're parking in the baking hot sun? I go from a car port to a garage, so my starting temps are cooler. Try a sun shade, and close the moonroof liner.
-juice
-juice
Tire pressure - That's really interesting. The general consensus seems to be that 32# give or take on all corners is just right. Better gas mileage, better handling and more even tire wear. Maybe Subaru has been quietly stealing our secrets ! lol
Pedal - Haven't noticed anything unusual with my gas pedal. I'd have it adjusted per juice's suggestion.
-juice
Ken
