Nissan Frontier Engine Questions
Good Morning. Recently purchased a 1999 Nissan Frontier 4 x 4 for work/off-roading. Since I have gotten it, I have noticed that after turning the engine off that the engine will let off steam. (Almost like the radiator is over-heating)
I have checked all fluids,hoses or belts that I can see, but nothing seems out of place. Any suggestions or ideas would be greatly appreciated.
Riot1
Riot1
Thanks for the great insight! I will check that out!
Looks like there might be a very, very small power steering leak. Is that a major repair? Appreciate any advice!
Riot1
PS i will be pulling a 6X12 trailer pretty often for my lawn mowing service, but it will weighs 1500 pounds max and it will only be short distances at low speeds. I'm pretty sure the 2.4 could handle it, but what do you guys think?
Is the 2.5 underpowered enough that it affects fuel economy during everyday driving? In the real world, is there that much difference between MPGs of the two engines due to low power in the L4? I do want fairly good mileage b/c this would be my first car (don't got a lot of money for gas). Thanks for your input
so far replaced the speed sensor and have now found out that the thac is out about 600rpm and scoping the codes shows speed sensor have had the senor tested and there is no falut at that point
nissan told me that the tach now has to be replaced the truck is a 1997se
any way around the tach with out replacing?
:confuse:
any ideas would help thanks
Intermittent problems make us all crazy. Good luck with finding a fix.
When I say, "performs", I mean which has better acceleration, which does better carrying a full load and how is the real world gas mileage?
Thanks to all!
