Mercury Grand Marquis Water Leaks
in Mercury
I have a 2002 Mercury Grand Marquis that leaks water on the driver's side whenever it rains. I have spoke with several mechanics and took it to the auto shop but no one can find where it comes in. I have sprayed water on the windshield and still couldn't find the leak. Has anyone else had this problem???
Your dealer will know what to do as they have had plenty of Crown vics, Merc Marquis and Lincoln Town Cars that leaked1
Water runs through the bad seal, then down under the front carpet and then to the back carpet. The first time I noticed it the front didn't seem as wet as the back, but found out it depends on which way the car is sitting as the next time it leaked in both front and back A LOT! Bill E
Water runs through the bad seal, then down under the front carpet and then to the back carpet. The first time I noticed it the front didn't seem as wet as the back, but found out it depends on which way the car is sitting as the next time it leaked in both front and back A LOT! Your Ford dealer has probably had dozens of these, so they will know of the fix. Bill Eaton
Thank you so much for your reply. I'll take the car to the dealer...hopefully the repair won't be expensive! I'll post the outcome.
Best regards, Leo
See my previous posts: the dealer has had dozens of these so he will know what to do. My 2001 Town car did this and the dealer said 'that's a common problem'. Cost fixing it was a little less than $200. That was in January and it hasn't leaked since. Bill Eaton
Our Merc Marq leaks on the drivers side. It has been to two different dealers and so far it has been a BIG waste of money at both places and we still have the leak. We are in Winston Salem, NC. Our windshield was replaced, rubber in side windows have been replaced, Seals have been replaced, black plastic tray around windshield wipers have been cleaned out. Love the car but ready to throw up hands. Did you get yours fixed and what was the problem????? Thank you.
Basicly....there is a gasket that is behind that plastic tray under the windshield wipers. That gasket goes bad and when it pours rain.... it leakes. It may leak more one time than another as it depends on how the car is sitting.
Dealer replaced that gasket with silicone seal and it has not leaked yet. Dealer says it's a common problem. Cost was about $190 which included the dealer keeping the car for three days and drying out the carpets. Bill E
The page links on the gray bar above (and also below) the list of messages will help display the previous messages within a discussion. And the keyword search on the left side of the page will help find other discussions and messages. Hope this helps!
far right side of the gasket to cover every gap, and still it leaks when I put the hose like you said on the roof towards the right side of the windshield. My idea is if there is a gasket right at the firewall were it meets the
plenum inside the car, how can I replace this without messing to much withtall that plastic, my Grand Marquis is a 92 and after all those years things can get pretty brittle.Thanks for your help.
Mike
I think Ford Motor Co should have had a recall on all these Ford Crown Vic, Mercury Marq, and Lincoln town cars to fix this problem but they have not! Bill Eaton
After my first posting, I did called the local Ford dealer in which I have a friend working at the parts dept., and asked him if he had heard of that problem, he said no but in fact he has a 92 Marquis as well and it leaks at exactly
the same place, but he did not mind as long as it drives good. After checking for the gasket he said the same thing mentioned here, they sell the entire plenun for $65.98. So
I will start today by taking that air intake out and prepare the gasket myself with plummers putty, and observe
how it behave before closing that area again. I will also look for a drain tube that should be somewere around the A/C plenum at the engine side firewall to see if it is clogged., By the way do you know were it might be?. Thanks.
Mike
housing. I did find the weep hole and make sure was not clogged because I swished the area with the cable tie.
After checking the gasket I've decided it was deformed mainly flattened, so I removed it and applied a thick bead of silicone and tight everything back. I haven't tested out yet, and it's sunny today, so later on today I'll spray some water on that area to see if it made a difference.
Will post result, but still can't understand (as vernes97
mentioned on previous post) if nothing is clogged and water
runs free on that area why water sips thru there and ends up
inside?.
One thing I didn't mention about the crown vic is that I drilled a small hole just to the right and of that weep hole after all the water drained out in the plastic tray as insurance. The hole was in the side rather than the base of the tray. My carpet has stayed dry after numerous heavy rains.
Good luck and best wishes.
I still have the carpet to one side to allow more time to dry since it was pretty wet before I worked on it. Hopefully it will stay that way. Thanks for the good advice.
see if it really stops the water. Once I'm sure I will prepare a rubber foam gasket of a template I've made from the plastic cover. So far with the hose it doesn't leak, but nothing like a good'ol Florida rain. Will keep all posted.
The whole thing looks like a case of bad design with the crown vics and GMC's-sorta like having to close the barn door after the horse is loose.
Really it has been an excellent car and still is, I just didn't wanted to give up on him.
I had left the carpet lifted since this all started and did not put it back together, I had it lifted off with some pieces of wood strategically placed to keep it off the floor. Well the main leak is sealed because this days are raining constantly and at one point I stayed inside the car while it was raining and saw water coming thru the side corner right at the end of the relay panel, but very slow so I'm puzzled by this new one. Like you did I 've tried the undercoating stuff but then again the water was not coming in thru there. I will wait till Saturday and try to
check behind that fender liner to see if there is another opening that I can cover with silicone. Strange thing is
I replace a broken electric antenna 4 month ago, maybe that had something to do with this, although I 've checked all
wiring entrances into the cabin.
Another way to find the leak is to shine a very bright light in the firewall area and look from inside fo the light with carpeting removed.
Good luck I stopped mine.
GOOD LUCK
I found that the pass.side floor is wet, so I thought they had cleaned the car before selling it to me and this part was still wet so I dried it by putting clothes under the mat and I would change to a dry clothe every couple of days.
So far It's drying up, but I'm afraid It's a start leak even though it rained lightly for a whole 2 days and It's only damp a bit.
It took a whole gallon of a premixed coolant before it stopped losing some (Level).
Other than that I'm very much enjoying my new ride.
Sam,
I pulled out the carpet and loosened the sound deadner on the firewall and had the wife start running the hose. I found the leak on the drivers side was coming from the grommet on the hood release cable that passes thru the firewall. It was cracked.
The passenger side was the grommet on the round bundle of wires that runs thru the firewall right under the heater box. The grommet is the larger one, about 1.5 - 2 inches in diameter and has a bunch of wires going thru it. It looks like it either shrunk or it wasn't spec'd right from the factory. What a pain to find. Hope this help some folks. Good luck.
I read the posts on this site and decided to investigate myself. I used to have PUDDLES on both driver and passenger sides in the front and back.
I ended up removing the plastic cowl cover under the windshield and then the wiper tray which holds the wiper motor and the wiper mechanism. You have to take off the wiper arms themselves to do this.
The wiper tray has channels for water to run and in the middle there is a plastic/rubber flap for the water to collect and drip down a "chute" down the middle of the engine bay and firewall. My wiper tray was COMPLETELY clogged with dirt and leaves at the mouth of the rubber flap. I vacuumed all the dirt out and cleaned all the little crevices and replaced the wiper tray.
I also siliconed the heck out of the fresh air intake on the passenger side since the gasket shrunk like everyone else. And I siliconed the heck out of the cables going through the driver's side firewall.
So far I have had NO problems. I did all this 8 months ago and we have had some hard rains since then.
Hope this information helps. Let me know if there are any questions.
BTW....took the car to the local Ford dealership. Lets just say they found nothing and had only wags at the potential problem.
The passenger side wheel well needed removed then I could see the 1 bolt and nut that allowed water to run back in the cabin. The bolt was just under the Heater box assembly. Just put a silicone around it, and around the rubber flapper hole in the firewall. No more leak.
Thanks to all that posted their scenerios This helped track down my issue.
