Chrysler Town & Country Tires and Wheels
We drive a 2004 Chrysler Town and Country Touring. It has the system that checks tire pressure. Whenever a tire pressure is low, the normal message is "Low tire pressure in 1 tire(s)". However, whenever the temperature falls below 40F degrees, the message "Service Tire System Soon" is displayed in the message console. I check tire pressure in all 4 tires, and they are all right on. If the temperature raises during the course of the day, the message goes away.
I could care less about the tire pressure monitoring system. Is there any way to just disable the system to make this message go away without having to bring the car to a Chrysler dealer and having them replace whatever sensor is malfunctioning?
Ron D.
Ron D.
I am on the same page as you are, for I asked the dealer to simply disable this monitoring system and he told me there is no way, until I get it serviced properly.
I didn't buy it, hence, here I am, looking for the answer to your question (actually, now, our question...).
If I come to know about it, I'll e-mail you, and would appreciate if you would do the same for me. My e-mail address is gblument@gmail.com and my name is Guilherme Blumenthal.
Thank you (and good luck to us...).
I do not have great hopes as it's been there before for this problem and they do not seem to be able to fix it. My warranty is up next summer, so I am really pushing them to fix it this time.
I decided to pull the spare today on my 2003 Grand Caravan. No issue, just wanted to check tire pressure etc. We just bought it used. Checked the manual and followed the instructions. It says to turn the knob until the tire is on the ground and can be removed from the mechanism.
Did that. But the tire stayed near the top. The cable spooled out through the connector piece, but I could not get the tire to drop. Looking at the thing, it appears that there was a safety running to that would hold everything in place incase the metal wire broke.
Question. Am I right that there is a safety and if true, how do I get the tire to drop.
If there is not a safety, then what do I need to do? I hung from the tire and it didn't go anywhere.
I'd really like to get this fixed on a nice sunny day rather than wait for a flat in the middle of a rainstorm.
Steve
Did you ever figure this one out? I'm in a situation where I need to get the spare off and am having the same problem. The cable comes down, but the tire isn't dropping. I've tried a number of things, but something is not letting lose.
Let me know if you get it solved.
Steve
Frank
Frank
I concede that if I had an owner's manual, which the rental company removed, it would have been easier. I doubt a person intimidated by mechanical things, male or female, would be able to change this vehicle.
For the people concerned about removing their spares: The crank handle specifies that when you retrieve the tire, you crank it until it clicks three times. I recommend making sure that it's fully drawn up to three clicks, it's possible there's an interlock mechanism that allows you to drop it again later. Just a guess.
I recommend that women driving this vehicle get a AAA membership, as they will never be able to change it themselves. And I really hate the idea of joining AAA.
I turned the crank so the cable went all the way down to the ground with no luck. Same as everyone else, the tire was still suspended with the safety latch engaged.
I got a 16 inch long flat head screw driver and cranked the cable back up so that there was only 2 inches of slack in it from the tire itself. I noticed that the safety latch was froze and rusted up. Crawling under the tire (with the van NOT jacked up yet) I pushed up on the tire with a knee and then hit the back of the release lever twice with a hammer on the screw driver, and the tire popped down the two inches of slack on the cable. The lever was tricky, there are two forks that hold the nylon bracket in place. The release side of the lever is a square piece of metal outside of where the nylon bracket is being held.
I am not sure how safe this was, but I was able to drive home and live to fight another day.
It took me 15-20 minutes with my van up on ramps to free the latch. A flathead screwdriver, wire brush, some sandpaper and a bunch of lube got it working again. I've read on some other boards that people make this an annual thing to make sure the tire is accessible when needed.
Harv
I had to immediately go out of town for a week. I asked my wife to take it in Monday morning to the local tire shop. Fortunately I had checked on tires when I thought I'd need to buy some soon. I found the Falken Sincera SN-828 and it seemed to have good reviews for a reasonable price. That is what the tire shop put on. With lifetime replacement/road hazard warranty and lifetime free rotation and balancing, the total was a little over $300. I got to drive the van today on a 200 mile trip and I was impressed by the ride smoothness and low noise from these tires--much smoother than the Goodyears, although those tires had 60k miles on them.
P.S. My 2007 T&C does NOT have TPMS. But it is odd in other ways, also, e.g. it has DRLs and my understanding is that is not a standard feature on the 2007 T&C LX. I bought it a year ago with 50k miles on it. I am wondering if it was a fleet car, although it was in too good of shape (absolutely spotless, wear-free interior) for a rental IMO.
