Nissan Sentra oxygen sensor problem
Hi everyone thanks for helping me out. I have sentra 2002 SE-R, when the check engine ligtht came up few days ago. I took it into dealer for checking, they said it's my bank 1 oxygen sensor and ISC throttle chamber problems. I woulder if anyone have the same problem before? and if anyone knows what cause those problems. Also if there is a way of clean them.
I want to take them in, but after reading some forms about other owners took in to fix other similiar problems but still have the light came up few months later. So, I also wounder if it's worth to take in.
If it is bank 1 sensor 2 then it is not critical at all. The only thing it does is the exhaust check for information purpose.
Double check with dealer which sensor it is. There are number of devices on a market (OBD II readers) which can read the code and reset it if needed.
and what about ISC throttle chamber? is this important, too?
I think that these 2 problems are linked. Probably bad sensor (best case) fools computer and it says that idles are too high or low. Does you car run normally? What are RPM at idle?
The thing is, there was that recall on the ECM foam casing which you've probably already had performed, and the reason for the recall was, some acidic material in the foam casing could eat away at the ECM. Since we were never notified of the recall, it did not occur until the ECM was encased for 4 years. Quite likely, it's not until the ECM starts crapping out that people finally bring the car in to be serviced. They replace the foam and it's already too late.
One sad thing is, the ECM costs a good $500. I (and your mechanic) hate to spend $500 just on a hunch. What's more, I happen to be in the semiconductor business, and I know those microcontrollers don't cost anywhere near $500 to manufacture. Nissan is making quite a profit off of those parts. If they had notified us of the recall, it could have been done on time and we would not need new ECM's.
Nissan dealer replaced the bad foam after I found out about the recall: 5 years after the purchase of the new vehicle.
Let's make Nissan pay for that: Nissan is required by federal law to inform every Nissan Owner about any recalls during normal service. If dealership forgets about it Nissan may pay heavy fines imposed by National Highway Safety Administration.
and how are we going to make Nissan pay for that? any ideas? :confuse:
All you typically need is:
1) A large socket wrench (1/2" drive)
2) An extension 10-12" for socket wrench
3) anti-sieze for the threads on the sensor. (Only apply to the threads. The sensor will not like this of it gets on the sensor end itself.)
FISHFACE said: If under 80,000 miles which is what I was told the emission warranty is,demand that they replace under warranty,if over 80k ,then I would ask them to show you which sensor is out ,there are 4 oxygen sensors on the sentra 1.8 engine,2 upper and 2 lower,it will more than likely be one or both of the upper sensors which you can purchase at Autozone for about 115.00 ea.,make sure you ask for the one with the factory plug on it,and ask the guy at autozone if he can take it off for you ,he may or he may not be willing to do this for you, if not they rent the special tool to remove it with,it takes about 5 minutes to remove and replace right on the front of the engine,ask the autozone sales person to point the sensor out to you on the very front of the engine ,and if he won't take it off and put the new one on ,then ask a male friend or family member to unscrew it with the tool from autozone (screws on and off just like a spark plug ,only it has wires coming out of it with plug on other end).
That, my friend, save me another thousand dollar there.
good luck
Here is a company I used http://www.ecudirect.com
You send them your ECM and they repair or replace the faulty parts and send it back to you or you can just buy a new one. I had mine repaired and they did a great job. Great prices and decent helpful staff. Give them a call and good luck
The mechanic said that the manufacturer should have done a re-call on these models because they were aware of the problem. Now I have to pay someone else to go in a re-set a computer on my car.
Is anyone else with a Nissan Pathfinder having this type of problem? :mad:
Chulo1
Corkscrew
Any ideas I could really use the help. Thank you.
1 Check for damage to the new sensor, be sure connections are clean and tight when replacing with an oem sensor
2 Using a "universal" sensor instead of an original equipment sensor where you had to cut and splice the wires. (they may be spliced wrong)
3 Check coolant temperature sensor as the computer considers coolant temp when deciding whether or not to go into closed loop
4 Oxygen sensors have to "breathe" so don't use grease on the connections
Corkscrew
My question is do I use both the solid black for one withe and then the black and red for the other. or do I put both wite wires on the solid black?
also what should I do about the check engen light. it is still on I restet it by taking the battery cable off but it just turns back on later? Does it have to be cleared by a computer?
Yhank you for the help.
There are
DTC PO132 HO2S1,
DTC PO133 HO2S1,
DTC PO134 HO2S1, and
DTC PO138 HO2S1.
Can I tell with the Car Serial or VIN if I cant take one of the sensors off?
Thanks in advance for help. :confuse:
After the wires are connected correctly you will be able to reset the check engine light
Corkscrew
faulty spark plugs and wires
clogged fuel injectors
emission problems
short or open circuit in electrical wiring
Better check these other probable causes to be sure.
If the dealer says that the problem lies in the bank 1 oxygen sensor, then have the oxygen sensor in front of the catalytic converter checked. This is mostly due to faulty functioning of the sensor and should be replaced immediately to avoid causing further damage to the catalytic converter.
emission problems
If the dealer says that the problem lies in the bank 1 oxygen sensor, then have the oxygen sensor in front of the catalytic converter checked. This is mostly due to faulty functioning of the sensor and should be replaced immediately to avoid causing further damage to the catalytic converter."
