Acura Integra Electrical Questions
in Acura
I recently purchased a '98 Integra LS. When the headlights are off and I step on the brakes the clock and radio lights dim and the front running lights come on until i release the brakes. When the headlights are on, the cruise will not work and the brake lights stay on. Any ideas of what would cause this and how to resolve the problem?
I have a 1992 Integra LS and it runs great but there is one problem that I can't seem to solve. I'll be driving and the wipers will come by themselves and then then stop after I shut the car off for a few minutes. It won't happen again for sometimes a couple of weeks and then start again. I have changed the wiper control inside the car but that has not solved the problem. Has anybody had the same problem? Any ideas what the problem might be or does anyone know where I could find a solution?
Thanks Paul
I remove the distributor out and forget to mark its position and replace the coil now it has spark at the plug but I can get the car to run?? It acts like the wire is out of order and the plugs are wet! I my question is can I have a problem with the distributor and have spark at the plug?
Can any one please help
also. so far replaced a/c diodes,fan timer module,and ecm.checked all fuses,in dash
fusebox/and under hood fuse box. any ideas,this car is driving me crazy.
http://techauto.awardspace.com/overheating.html#nofan
Corkscrew
Last night I was driving fine and then i cut the car off and absolute no power to my starter when trying to start back up and everything else is fine no click or nothing. Then i just waited turning the car off and on but nothing finally after 5 minutes it was fine and started no problem. happened a couple times already and one time i couldnt get it to start for like 30 minutes so i had to push start it and working fine ever since..... just odd when it does happen.
Thank You
i know there are people on here that know tons more than i do, but i hope that helped.
i think it could be the voltage regulator in the altinator some one help.
:sick:
I have the following error codes showing up on my 1999 Acura Integra:
PO301B, PO302B, PO300B, PO304 = Cylinder misfires.
and MFR P1399 = what is this???
Does anyone know what could be causing this?
Any help is appreciated!!!
