Ford Explorer Brake Problems
My 1997 Explorer exhibits sluggish braking for the fist couple of stops when cold. The truck has new Motorcraft pads on all 4 wheels. Zero fluid leaks, good rotors, what could the problem be.
What is amazing is that they detected the brake booster was also i bad shape and I had to change it... maybe you should look into that as a problem.
Did you change the fluid and clean the brake lines?
Good luck
I HAVE SPENT GOOD MONEY WITH THE FIRST ERRONEOUS DIAGNOSTIC AND HAVE DOUBTS OF THE 2ND. ONE. THANKS.
Is it a known problem with Explorers?
Anyone had any similar experience? I am so frustrated now, I will take this vehicle to a brake- check tomorrow.
Has anybody experience similar problem or there might be a service bulletin on this?
I push the brake, nothing happens, car continues to move, then feels like the brake takes hold. Very scary.
Anyone else having this problem?
My '92 Jeep acted the very same way, ABS continued to remain active right down to virtually zero, "creep", speed, NEVER letting the Jeep come to a full and final stop.
I am a BIG fan of a new design that would disable ABS unless the vehicle direction of travel deviates, according to VSC, from the desired one.
I discovered your web post regarding similar brake failure on your Ford Explorer. 2 questions for you:
1) Have you had any other brake failures, other than those listed in your post?
2) Did you ever find out what caused the brake failure and what if any repairs were made to the SUV'S braking system?
Thank-you in advance for any assistance you can offer.
The more of us who post the problem with NTHSA the sooner Ford will be forced to find the problem and come up with a fix.
I have also had a middle row passenger side seat issue where the seat would not lock down after the seat had been lifted...this vehicle was one of the first made as I leased in Feb 2011.
I have been lucky, it does it maybe once a day on the average but of course I'm driving around always worried about it. I also see on this forum the accidents that have happened to others. I am new here, just starting to read everyone's issues....do we have any idea at all what this problem is???? I can't seem to get any help with this and not in market for new car yet. Thanks for listening.
Shar11 :confuse:
