Right Hand Drive Jeep Cherokee
I would like to find other rhd jeep owners who use their jeeps to deliver mail, mostly to discuss and compare maintainance costs and special problems.... my real special and costly problem is the transmission, in 82,000 miles, I have just had the transmission replaced for the second time!!!! I own a 2000 rhd jeep cherokee, 2wd rear wheel posi-traction, basic model... and must admit I really like driving it despite the very costly upkeep on it
my e- mail is fab4cat@aol.com
meanwhile, i found using sea-foam in my gas tank once a month helped keep the carbon buildup to a minimum, it's more expensive than regular gas additive but worth it
Hey, that kinda defeats the purpose of a Forum!
If you keep the discussion here then everyone can learn and benefit.
I miss the '91 Laredo that I had converted to RHD. It was better for mail delivery because it had pockets on the door, the glove box doubled as a mail tray, and the parking brake hole was a good place to put rubberbands. The only thing I like about the 2000 factory RHD is the cup holders in the middle and not having to stretch to use the turn signals.
Here are photos of the Cherokee I used to have
Marcus lives in Austrailia where the RHD is standard and his site has a WEALTH of info for maintenance & upgrades. Plenty of off-road tips & modifications but just skads of real world experience with the RHD XJ's.
Sitting there for so many years and not knowing is she would even run we towed her from Wyoming to Colorado and began to restore
We are searching for another seat, mail jeeps came with one and a tray for the mail. Does any one know where I could find a seat?
Thanks and happy motoring.
Thanks, Robin
I have put a new stater motor on it and that works fine.
, when you put the key in and turn you have all electrics, when you turn again for the engine to start, the engine starts and i can't use windows ,heater, airA/C ,radio, and the battrie is not charging i think.. lights work indicators work
..But if you turn the key slightly when the engine is running , the one that makes the starter moter scream all work.....can you help
I think maybe it's the ignition switch or the alternator...can anyone offer an opionin.
You guys have jeep mechanics at your finger tips i have to travell over 200 miles just to get ripped off...
This problem was there before i fixed the starter ..incase you were wondering..lol
Thanks Bill
Happy motoring
I recently bought a 93' Jeep Cherokee sport right hand drive that has 95k original miles on it, I drove it over 2 hours to get it back home with out a problem. The first day that I delivered mail with it started to have an issue where the motor would rev really high at 25 to 35 mph for a short while before shifting gears. This happened for about 10 minutes then it stopped accelerating while in gear. I tried shifting gears with no luck, if you stepped on the gas it revs the motor like its in neutra. Anyone have any idea what needs to be done to fix this? Is this a problem with the transmission? Any advice would be great.
