Hyundai Sonata Engine Questions
I am looking at a 2004 Sonata with 41000Km/24000Mi. The car is immaculate but... When in drive and stopped, engine noise/body vibration is significant. I'm told they are all like this, however...
My 2000 Ford Focus has similar problems which started several years into ownership and got worse. When cold, the dash vibrated, coins rattled in the cup holder. In 2006, I finally bit the bullet and replaced the engine mounts. Voila, new quiet car. An unbelievable change. So now back to the Hyundai. I think it also has fluid filled engine mounts. Is this the cause? Service says it's rough because of the counterballancer but this should make it better.
Anyone have any experience with this problem.
Jim Brooks
Jim Brooks
I have not had this experience with any other car. For instance my Mercury Sable will glide a long distance with my foot off the gas pedal.
Is this normal for the Sonata? Won't this contribute to poor gas mileage if the engine is breaking when it's not needed? I have read it's not safe to shift into neutral while coasting?
:confuse:
The question I have is do you just accelerate to 30 and take your foot off the gas? or do you cruise for a while at 30? If you accelerate rapidly to 30 then take your foot off the gas then you are most likely in a lower gear and the effect will be greater than if you were cruising in a higher gear.
I did a little test. It takes about 14 seconds for the car to slow from 35mph to 25 mph when it is in gear with my foot off the gas. If I throw the car into neutral immediately after removing my foot from the gas, it takes over 35 seconds to effect the same slow down. A look at the RPMs shows the difference as well, 1500 dropping to about 1000 rmps with my foot off the gas versus an immediate 800 rpms in neutral. I assume that's gas saved but I didn't know if the amount is significant.
Your right my '95 Sable does show some effect but not nearly as significant as the Sonata. I wondered if it was a breakin thing or if that is permanently how cars behave these days?
And again, if you drive an Accord, you'll feel it even more... Actually in the Accord's case, the NEWER Accord has this a bit less pronounced than the older Accord... My '95 Accord was almost annoying the way it would down-shift the second I lift my foot of the pedal, at around 30-40 MPH. Our '05 Accord is more smoothly doing it, but still more noticeable than my Sonata. It's called something like "downgrade logic"...
All cars will have a similar effect. When you put the car into neutral you completely disengage the engine, your RPMs should go to an idle rate. But if you keep it in gear the engine is still engaged and will slow the car down significantly.
It may be a definite asset, or it may never work at all.
It take off smooth and when you turn the engine off , the car stop straight away.
Like ray said ,get some one to have a look at it now. For peace of mind.
I'll also add that I think that the transmission is supposed to learn our driving over time. I like how mine performs now better than when new. Perhaps these two items are related.
I have noticed recently that as my mouse goes over the name of the contributor that I get "info" about them. This is fine, except that I haven't figured out how to get rid of that info to read some of the comments under the "tag". I have tried going up and down, etc.. and I can figure out how to read them, but couldn't that "pop-up info" be made to disappear in a few seconds?? I am really more interested in the comments than the info about the contributor. Please consider an adjustment of sorts. Thanks, van
Meanwhile, the place to talk about this is here: Forums Software.
You are not alone in your feelings. I'm beginning to like them, but that's because I figured out how to get rid of them when they show up unexpectedly.
Now the rattle is gone, so is the rear end clunking (like an old car with bad ball joints) The car is just smooth, quiet, and tight, just like my wife's brandee new '07.
I'm really impressed with the dealership, that they got everything back together right with no leaks, squeaks, rattles, or other problems. Kudos to Hyundai and it's service department and the people who train and select their employees.
thanks!!
I have a Check Engine Light problem with my 06 ^ and suggested to the service dept that it might be a 'chain' problem and they said it wasn't possible.
Would tensioners solve the CEL problem in your opinion?
The car has 14M miles and has had 2 ignition coils replaced along with an O2 sensor , 6 new plugs and wires. Currently it is in the shop for the third time in as many months.
Any suggestion on what the dealers mechanic might look for?
Thanx in advance for any help you can give.
I haven't driven or ridden in his car, so I haven't actually witnessed the tachometer climbing that high. Here's my question:
Does anyone in here have a Sonata with a defeated rev limiter (don´t worry, I won´t ask you for your VIN ).
If so, have you been able to rev your engine that high? How often? The redline on the I4 and V6 Sonata engines is somewhere between 6,200 and 6,700 RPM depending on the year/engine.
I'd be interested to see if anyone else is able to rev their Sonata engine past 8K without blowing it up.
With better breathing, and a tweaked chip to push more fuel into the engine at high RPM, and maybe some bigger injectors, you'd assume an engine would make more power at a higher -RPM power peak.
The question is, how long could the engine's internals handle the extra RPM and power? I guess we don't have any Hyundai "ricers" in here yet.
I do not agree with your service advisor about either comment he made: that a "sport suspension" is inherently noisier than the "normal" version on the same car or that a V-6 being heavier (it may be but it is minimal) would cause one not to have the noise. I personally have recently rented both I-4 and V-6 versions of the GLS model. These were 2007's and having ~26,000 rental miles were hard used vehicles. I don't know if I am insensitive or what but driving both cars over temporary "winter patched" repairs on generally poor Pa roads I MAY have heard some suspension noise on the worst parts. Would this noise have been apparent if I was driving a Camry, Accord or some other brand car? I suspect so but don't know for sure. I have come to the tentative conclusion that individual owner sensitivity to noises may play a part in this "problem".
