VW Golf Engine Problems
in Volkswagen
I had a new engine put in my tdi golf 2001.
Was working fine.
Now the heater is not working and the engine is overheating. I found out there was no antifreeze in the radiator. Any ideas?
Was working fine.
Has anyone had the same problem? Is it a common fault or do I need to change different components until it stops?
If it is a common problem with the car, they'll know about it.
The relay is probably about £30 and can be changed in about a minute. All relays are behind the fuses inside the car.
Thanks for getting back to me. I was wondering if it was the relay with the number 30 on it ? If not what one was it.
I've been having trouble with my Mk3 Golf GTI 8V consuming 1 qt of oil every 500 or so KM (about 300 miles) so I had the engine rebuilt. The problem persists even after the complete rebuild and I can't seem to find what's causing it. I've heard of VWs burning a lot of oil, but this is ridiculous. Any ideas?
Right, the problem your having is simple, i dont know if you have sorted it due to the date on the last post. Anyway, what you need to sort out is the crank shaft sensor. Mine did the same thing, would cut out while on the motorway. I tried the exact same thing...replacing the fuses, believe me when i say it does not work.
Hope you get it sorted
Cheers
I am considering getting a turbocharger on it, but all i can find on the internet is turbochargers for VW's with a 1.8l engines.
Can i get a 1.8 turbo and use it on my 2.0 anyway?
The 2.0L engine is a VW engine. There are SUPERCHARGER kits for the 2.0L engine. ... but I am afraid you would need some engine-building experience to add a turbocharger to the VW 2.0L engine.
100,000 Miles. 2.0 Engine
And my check engine light is on. I got it looked at the local garage and they said its a Evaporated Emissions code. I changed my vacuum tubes, and it still didn't turn off.
I also started to notice that when i start it up, theres like a slight squealing noise from the engine area, and its coming from a pump of some sort.
Also sometimes when idling at a stop light, instead of the RPMs being just below 1000(like it usually is) it bounces up and down above 1000, could this be involved? Can someone try to tell me what else i should do?
Thanks John
Appreciate your help in advance. I must say..I am the first owner of the car, its got only 62K on it and it has been largely reliable...be it winter or summer...this is the second time I have seen this Engine Light on ..the first time was long back.
Cheers.
I have same problem on golf 01 hatchback. I went in a vw. garage, they connect engine to the computer and it said temp. coolant switch.( 29.euro). After two days, light was on again. They connect car again and it said number one oxigen sensor.(210.euro) Golf has also no.2 oxigen sensor and few more sensors.Mecanic guy said maybe it`s no.1, maybe no.2 sensors they can`t know untill they change everything showed on the screen.He told me this light are usualy for golf and this sensors are mess very often, sometimes with no reason.I paid 166 euro for tem. cool.sensor(29 e), cleaning body and litlle bit coolant.I`m waiting to get ox. sensor from my garage (it`s under varainty)and when it`s done to see was this sensor caused problems or another one.I can`t imagin how much this will cost me but I can`t drive my car like that, forever.
I tried to get price for air condition and fitting but can`t fine it on any web pages. If you know anything,please text me.Thank you And sorry for my spelling.
http://www.amazon.com/VW-Golf-Cabriolet-1990-98-Chiltons-Repair/dp/0801991226
Spending that money now could save you some down the road.
A couple of things come to mind. The fuel pump you put in is bad, you got some kind of crud in a fuel line that's blocking fuel flow now and then, the fuel filter might need to be replaced. I'm all for going after the obvious first. Look at the fuel system. I'd bet on that being the location of the problem with what you've said.
I'm new here. Just trying to post my problem. Don't know if I'm in the right area? Well I have a 1996 VW GOLF Diesel. Just today the panel indecated an LED 'SERVICE2'? Normally it says SERVICE1 when the annual service is due and the orange coil icon is fashing none stop? It will turn over, but not start up? Sounds like its out of gas? Tank is full.
Anyone have a clue what it might be?
Thanks for your help!
I have a V8 truck that only rpm's at 2000rpm on the highway.
ValleyVW :confuse:
A constant issue.
I put new plugs in, it still misfired, but cleared up. car sat for a week, then its misfiring all the time on cyl4, if I try to drive it, then cyl3 misfires. then i loses sooo much power it can barely get up to 35mph.
Any ideas?
Replaced the fuel filter, tried injector cleaner, and new plugs...
it actually ran great for a little while. it happens all the time, but before when it wasn't bad it was in the mid-range and mid throttle.
This little car was nice when it ran, very under powered, but i liked the 30mpg, and the heated seats.
This is certainly my last VW Gas. I would look in to a TDI jetta wagon for the wife (pre 2007). Aside from that, i hate the 2.0L engine, with its aluminium oil pan and steel drain bolt. The threads stripped out, so i used an over sized plug. and its oil consumption of 1qt every 1500miles is not acceptable (VW said its normal). So, if I change the oil every 7K like factory states, it will be empty.
JUNK MOTOR.
:lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon: :lemon:
the dealership advised me it was the cam belt which i got changed, but a week later it has come up again
Does any one now what that code means?
Wondering if anyone out there had some good advice.
My Golf GT TDI Mk 5 is misfiring around 30mph intermittantely. The dealer says there is no problems and its still under warranty. The car is also stalling from cold if not 'revved' up enough. Hard to do when you drive an automatic!
Anyone had similar problems to this?
thnx you
john :confuse:
Problem:
itermittent slight loss of power, slight hesitation during acceleration. Car idles OK sometimes but when giving it gas in park it hesitates a little. When driving on the road it can run for 15min l go back to running crappy after 15 minutes. Had a vw garage tell me its the ecu or 02 sensor after spending 2.5 hrs diagnosing. they said they needed 3-4 more hrs to diagnose further. I replaced fuel pump, filter, 02 sensor, checked vacume lines etc. still not fixed. I did notice that unplugging LAmbda valve harness connection next to fuel distributor the car ran the same as if the computer is not seeing it.
Thanks in advance for any advise. scott
