Hyundai Elantra Basic Maintenance Questions
in Hyundai
Hello everyone...
I have a question about some fluid flushes..
I have a 2002 elantra with 42500 miles on it. I have been good about all of my maintenance, and at 32k miles I got my 30k service done at a dealer. that included some belts, coolant drain ( not flush ) and a transmission drain ( not flush ). I had also previously done the chemical clean before on the fuel injection system. Well, I bring my car in every 3k miles for an oil change to a local shop ( not dealer ), and the last two times they tell me i need all of my fluids flushed!! He showed me the transmission fluid, and it wasn't cherry red, but not "black" as he said either ( only 8k miles after I had it done ), it was a burnt sienna, brownish color. He also said I need a coolant flush, power steering flush, brake fluid flush, and fuel injection chemical clean.
I just got the power steering done, because I haven't before, but do i really need the rest of those again so soon, as well as the brake fluid?
Thank you for your advice!
My boss drained the fluid in his Explorer a couple of years ago, and refilled it. After driving for a couple of weeks, he was surprised to find tht the fluid was a little dirty. He took it in to his dealer, and they told him that when you just drain, instead of flushing, there is a lot of dirty fluid that is trapped in the torque converter that doesn't get removed. When you then drive the car, that dirty fluid mixes in with the new fluid and causes the dirty appearance. This may be the case with you. However, if you are going to get your tranny fluid flushed, you should have a dealer do this. The Elantra uses a special transmission fluid, and a lot of times, outside shops do not carry it, and will even tell you their own fluid meets the specs (or that they can add something to it to make it meet the specs) when this actually is not true. I am not sure why your dealer would not have actually flushed it to begin with.
Most places around me are able to suction out ALL of the fluid, and then replace.
I did a complete service but could change it (fuel filter) because I could not find it.
All that said, I've seen Do-It-Yourself instructions for this on other message boards. (Google on "Elantra forum" and check out the first few sites... one of them should have the DIY.)
1. Warm up engine, drive onto ramp, shift to P, apply parking brake firmly, shut off engine, put wheel chokes (or bricks) under rear wheels to prevent car from moving.
2. Open hood and remove oil filler cap.
3. Get under car, remove the plastic cover piece under the oil pan and oil filter. This done by removing 3 bolts (using 10mm socket).
4. Place container under oil drain plug, remove drain plug using 17mm socket or wrench, wait until used oil is completely drained to the container.
5. Move container under the oil filter, remove oil filter with an oil filter wrench. This took me a while as the oil filter was very tight.
6. Use finger to apply new oil to the rubber band on new oil filter, install new oil filter with hand. Then use oil filter wrench to tighten 1/2 to 3/4 turn.
7. Put a new aluminum gasket/washer on oil drain plug, then screw it on with hand. Tighten it with wrench 1/4 turn. Do not overtighten. Or if you have torque wrench, use 30 lbft torque. Reinstall the plastic cover piece under the oil pan.
8. Using a funnel pour 4.23 qt new oil to oil filler hole (I used Quaker State 5W20 synthetic oil), put oil filler cap back on.
9. Turn on engine, oil pressure light should go off within 5 seconds. Drive to level ground. shut off and wait for 5 minutes then check oil level. It should be at Full.
Thanks for the help.
Robyn
Just google "obd codes" and it will show you listings for the OBD II codes that appear on a diagnostic tool (also known as an OBD reader).
Do you still have any powertrain warranty left? If so, I'd suggest talking to dealer's service dept. for a process to follow the next time it happens; i.e. drive it straight to a dealer or have it towed or something else.
Even without warranty you might talk to them. A sensor somewhere is saying something's wrong.
The 05 has 96K and the 06 has 45K and both run perfectly. The 05 uses no oil at all between 5K oil changes.
BTW: Bought both new as first cars for my son and daughter. Plan was to get them through the last two years of HS, college and a few years beyond before a replacement is necessary. So far the plan has worked well and seems to be cost effective for the long run.
Have a 2006 GLS 4-door with 51,000 miles which my daughter has at school. I've done all the scheduled maintenence which is really just coolant flush! and oil changes at 5,000 miles or 6 months. I did the timing and three other belts at 48K because it was 5yrs - we brough the car from a dealer a little over two years ago with 26K+ miles.
Now I'm wondering if I should have the auto tranny fluid serviced. The manual shows it to be done at 108K miles/7 yrs but the severe schedule shows at 30,000 miles. The car gets probably 60/40 city hwy driving and the city is generally shorter distances, in traffic which qualifies as severe. I've just checked it, the level is good and color is within reason, looks red on the dipstick and sort of brownish on a paper towel. So should I have it serviced or just leave it alone?
Other then that, I'm still loving my car. LOL
You should still have the space for a spare so you can always purchase a wheel & tire on your own.
BTW, others like the Chevy Cruze have also dropped the spare tire. But Chevy at least offers it as a $100 option.
Thoughts? I believe that most auto dealers are self serving in this area (really??) and as a matter of fact the sticker they put on my Elantra windshield says change the oil every 3000 miles.
Yes, I am aware many folks just want to change their oil every 3k to 4k miles. I had been thinking every 7500 miles, or 6 months ... whichever comes first for me.
Thoughts? I believe that most auto dealers are self serving in this area (really??) and as a matter of fact the sticker they put on my Elantra windshield says change the oil every 3000 miles!
If you want further clarification, I'd suggest going by what Hyundai says v. the dealer; sometimes they operate with different (profit) motives. http://www.hyundaiusa.com/contact-us.aspx lists their phone number or lets you submit a questions online.
I think you can very reasonably split the difference and do 5K between changes year-round or, if extreme cold is your guide, 3750 in winter & the full 7500 in summer. Figuring out what works for you may depend on how many miles you drive.
I wouldn't do it on the first batch of oil, but maybe on the 2nd or 3rd (after you've got 10K miles or so) you could also use an oil testing service to determine how the oil is doing after 3750, 5K, 6K, etc. miles. I haven't done it personally but Edmunds has and they use http://www.blackstone-labs.com/.
And as a friendly reminder, you don't have to get the oil changed or have any other scheduled service performed at the dealer. Just document the service (keep your receipts) in case you need to make a related warranty claim later. Personally, I use my dealer as their prices are competitive enough and they're friendly & competent and don't usually try to oversell. My wife uses a local shop for oil changes but the dealer for most other things (related as she now has a '12 Elantra).
