Pathfinder Engine Swap
Anybody out there know if a vg30ett (300zx) or RB26 (Skyline) Engine would fit?? if so with how much Mods?? Any help is appreciated!!!!
normal operating temperature. Originally it was surging, I disconnected the ACC valve and idled it down,then it quit surging.Plug it back in, idle raises back up. No surging now, just a high idle. There is no air in the IAA unit, I have bled it several times thinking that it had air in it. Now I am positive that it has no air in it. I have recently installed this motor myself, I did not change the ECM, I felt no need because the motors were identical. There is NO check engine light on, ECM light is green. PCV valve is new,
Thank you in advance!
