Don't expect any help from GM or anyone if the car goes nuts. I tried to get help from them and all they wanted to do was schedule me for an appointment. I asked her, "How the hell can I schedule an appointment and get the car in if it won't start?' She couldn't answer the question.
Never again for a Saturn or GM product. GM= Great Mistakes
You should be in the Hyundai forums telling them how wonderful their chosen cars are? Why are you posting here--you said you're done with the Saturn? Why drag it on?
Actually, in re the corrosion, my GM owners manuals recommend washing off the underside the car at the end of the winter salt season IIRC.
I personally take mine to the do-it-yourself car wash when the weather breaks and I spend my minutes spraying the underside instead of the pretty part. I do that 3-4 times during our winter. Then in the spring I use my garden hose to spray the underside. If there's a rainy period that washes the salt off the roads, I drive my cars during a rain to spray the undersides with fresh water to rinse down salts.
I wash the underside rinsing off the salt that throws up on the parts, including the brake lines and gas lines if they are metal, and corrodes them. I personally believe the brine solution that is pre-sprayed onto roads here in Ohio are more corrosive than the mixed salts granules they use.
So some preventative maintenance would have helped your car. I would do that with the Hyundai. Hyundai had major problems with their Accents in the past and that's part of the reason they came out with the non-transferrable 100,000 mi/10 yr warranty. So the warranty won't change the used value of the cars in reality because the next owner dun't get the warranty!
Report back to us in 10 years and let us know how you're doing.
Make remarks about posts, not about other members.
MODERATOR /ADMINISTRATOR
Review your vehicle
it was weird most of the time cuz i would try it but then go back out around mid day and it would start just fine.... so i started looking on here and saw ppl were saying the ignition relay which i had one of the parts guys at the dealership look at it and he showed me a free way to c if it was the problem by switching it with the defrost relay. that didnt work
sad the main reason i wanted that car was cuz i thought it was a gorgeous blue.... now im thinking the 1999 ford taurus would have been a better option!!! I love my car when it runs for me but its just so frustrating when it has this problem, also key does get stuck occasionaly but i use the spare now that has alot less wear on it
It will be great if it lasts a really long time. But I would always wonder every time I got inot my car... this could be the time it doesn't start.
I had my first one change 6 months after I bought my car, new. Then 4 yrs later I have the starting problem. Haven't changed it again yet.
Something is wrong with your mechanic if he can't find an ignition switch for a generic GM compact. It's not an S Series that shared no parts with other GM cars. He's telling you BS.
Cut the white wire. http://youtu.be/ww5AGhFWcBw
Any recommendations? Buy another ignition switch and try to reset the pass-lock with that one?
I have the correct part (as listed in multiple previous posts).
My procedure is: install new switch, turn key off, plug in, attempt to start, wait 10 minutes on run then light goes off, turn off for 5 seconds, attempt to start - do this 3 times and on the third turn car off for 30 seconds, attempt to start, turn key to on position, does not start, when key goes back to run position engine turns once but does not start and no pass-lock light. Attempt to start again and again and nothing but when key goes back to run engine turns once. Strange huh?
Any help greatly appreciated.
Sarah
GM Customer Service
Read your message about remote starter. Can you tell me what you do after you start the car and then get in? How does it work? As far as the key in the ignition? Sorry, I have not idea about this stuff.
http://townhall-talk.edmunds.com/direct/view/.f1137a7/674#MSG674
I reside in LA, have a 2005 Saturn Ion, the starting problem is about 3x a week, used to wait for 10 minutes and car would start but on Friday, 2/17, it did not start for 1 hour. Same thing happened this morning, 2/20.
I changed battery last October, and brought it to mechanic but they can't find anything wrong with it. Please advise on what to do. Thanks for your help.
I reside in LA, have a 2005 Saturn Ion, the starting problem is about 3x a week, used to be for 10 minutes wait time and car would start but it on Friday, 2/17, it did not start for 1 hour. Same thing happened this morning.
