Caravan/Voyager Serpentine Belt
My wife has a 2000 Plymouth Voyager that lately has ruined two serpentine belts. As the belt comes down off of the tensioner it makes its way around the power steering pump then around the rest of the accessories. The belt starts working its way along the edging of the steering pump pulley, I believe either the pulley may be slightly bent (which it does not seem to be) or the tensioner is wearing out. Has anyone else had this problem or have any solutions?
I called Chrysler and they said they don't plan to do anything to fix the problem. I would think they make this a recall item. This is the last time I own a Chrysler product. Next time it will be a Toyota.
http://www.midwayautosupply.com/pc-48526-261-gates-system-solution-micro-v-kit-f- or-chrysler-33l-and-38l-engines-38379k.aspx
Best Regards,
Shipo
I placed an order for the kit....$99.00 is worth a try.
Bob
Best Regards,
Shipo
Good Luck
Frank
I checked this and, YES, there is a service bulletin which requires a new belt, tensioner and a shield. They also have a Pulley guard (essentially a washer that keeps the belt from slipping off Chrysler part # 500 3480 AA. I'm on my way to get that right now. I will try to put the belt on myself. May need some special tool to tension the belt and will find out and let you guys know. Chrysler sucs, in my opinion. I called them in Detroit and got no help. They should have told us about this a long time ago. This will be my 6th belt and lots of aggravation. Next time I'm buying a Toyota.
Frank
Hmmm, serpentine belt problems or engine sludge, take your pick. Personally I'll deal with the serpentine belt and be happy that my engine is spotless in the inside after 135,000 miles (as of today).
Best Regards,
Shipo
Is this a do it yourself job? and should I buy a new belt? I took a look at it and it seems rather tight to get your hand in there.
You can get the same kit, made by Gates, from midwayautosales.com ($116 including shipping. Depends on whether you have the 3.0 or 3.3 liter) and do it yourself.
You have to removed the front right wheel and the water deflection shield below to get access to the pulleys. You may need a wrench to tension the tension pulley to slip the belt on.
lfulwider
I have the Goodyear system on my Dodge Minivan. You can get it at a Goodyear auto repair shop. It's going to cost you about $130 plus about $100 to install. This includes the new double ribbed belt, tensioner and pulley.
I am not happy with Chrsyler dealerships as I have replaced my serpentine belt at least 5 times until I found out about the service bulletin and Gates/Goodyear systems. I didn't try the Chrysler fix even though the part (a washer) is only $15.00, after they are done with with replacing the belt, tensioner and spacer it's going to cost you more than $300.00 (In Seattle.)
Shop it out. My math told me to go with the Goodyear kit. It's been more than 4 months and the belt looks good.
1997 Voyager, 3.0L, 140K miles, original owner...
Belt tensioners are replaced about 1 per year. The last time it was replaced it just howled when it got wet. I was told by the shop that the wrong pulley was on there. They went to a different belt on the second try. I don't know who replaced the pulley since I bought it new, it will remain a mystery. Anyway, after getting it back, the serpentine belt fell off while driving it and we lost power steering, alternator, A/C.
The belt dragged on the ground for about 20 miles until I drove it back to the shop that replaced the tensioner. They reseated the belt. Yesterday, it fell off again. I am being told by them that when we hit a big puddle the belt tends to fall off of this model. That's funny since we've had it over 10 years and it's only come off twice in that time, both times since they worked on it.
Should I give up and sell it? Is this a chronic problem with this model? Help!
Aside from the headliner falling off, valve job at 55K, remote mirror failure, eats belt tensioners about 1 per year, fan relay failure, valves tapping like a diesel, yada yada yada... it's an OK car.
http://www.gates.com/brochure.cfm?brochure=2911&location_id=3488
By all accounts, the special belt kit from Gates stops the belt problems completely. Said another way, I've heard from lots of folks that have put this system on their vans and so far at least, not one belt has been thrown.
Let us know how you make out.
Best Regards,
Shipo
Best Regards,
Shipo
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NBH&Par- tNumber=38342K&Description=Belt+Conversion+Kit+-+V-Ribbed+Belt+to+Dual+Sided+V-R- ibbed+Belt
Best Regards,
Shipo
There is also an aftermarket pulley system that has tracks on both sides of the idle pulley and it solved my problem more than 18 months ago. It's a Goodyear serpentine pulley kit for about $235.00. I would go to Chrysler first since it's cheaper.
I would not rely altogether on the rain water or puddle excuse.
It came off on my wife over a dozen times. No power steering (no control), no water pump (engine overheats causing dangerous to aluminum heads), no alternator (no battery charging), no AC. All powered by ONE belt. $40 a pop to put the belt back on. An independent recommended a kit, parts and labor, over $300. We then found a radiator leak, thinking the slick antifreeze was causing the belt to come off, so I spent the $300 replacing a new radiator. Still the belt came off.
I have looked over numerous forums on the web and with all the problems with Dodge, Plymouth, Chrysler vans, why do we have to pay to get it fixed?
I thought I'd be smart and start out with some "cheaper fixes". One guy was selling disks to put over the tensioner and idle pulley for $30. I found the disk covers from Advance for $8 apiece and installed them on both idle and tension pulleys and thought how smart I was until I went through a puddle...twice and both times it came off. I started looking at the Dayco 89251 from Advance, but it is a smooth tension pulley. My wife called me today and guess what...she went through a puddle. So..here I am ordering a Gates 38379K kit from Amazon $111.63 incl. S & H. Advance has Goodyear kit 49215K for $124.99 plus tax, but it had to be ordered. You can also order separate double sided belt, grooved idle and tension pulleys, but they total more than $111. The double sided belt is over $65.
CONTACT THE NHTSA on their web site or call them at 888-327-4236. I am surprized if someone hasn't gotten KILLED yet!!!
Quite difference from several years ago when I was replacing them every few months.
Thanks Martin
Thanks martin
Otherwise, Dodge will fix it by putting a special washer, about $20, in the pulley/idler to prevent the serpentine belt from jumping off.
Funny, Dodge had this in their service bulletins years ago and but dot bother to tell you about it. You find out through the Internet, unless you go to an honest dealer service department that will search it out. I don't know how well the Dodge washer works out, but I'm sure they're going to charge you for labor as well.
Goodyear did the trick for me.
FWIW, I've had two Gen 3 vans with the 3.8 and one Gen 4 with the 3.8 as well, and in a combined 480,000 miles, not one belt has fallen off.
Best regards,
Shipo
Martin
Good luck
Martin
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400101428236&ru=ht- tp%3A%2F%2Fmotors.shop.ebay.com%3A80%2F__%3F_from%3DR40%26_trksid%3Dp4712.m39.l1- 313%26_nkw%3D400101428236%26_sacat%3D%26_fvi%3D1&_rdc=1#ht_1930wt_870
I cannot figure out how to get the belt back on, I have followed the diagram under the hood, but still have too much slack in the belt. I must not have it right around the belt tensioner. I also checked to make sure the new belt and the old belt are the same size and they are.
PS I would have never thought you had to lower the engine to drop the water pump!
1997 Voyager.
I am baffled as to what advantage, Chrysler engineers, thought they were getting by specifying a pulley system without raised edges. As most of you probably know, older cars usually had a manually adjusted tensioner with v-belts and raised edge pulleys. Even when it was somewhat out of adjustment, that system usually worked.
For those of you needing to compress the tensioner to put on or take off the belt, some auto parts stores lend the tool for free (refundable deposit). Those tools that I have seen have one long arm and shallow sockets or attachable spanner heads. The long arm will not work, on a 3.3 engine, if you are trying to compress the tensioner from the top of the engine for lack of clearance.
The advantanges of a serpentine belt (over a "V" belt) include (but are not limited to):
- Lighter overall component weight
- Greater torque applied to each individual pulley
- Smaller/shorter overall packaging
- Significantly longer life (assuming no alignment issues exist)
- Faster R&R/simpler maintenance of components behind the belt system
If I recall correctly, the 3.3 and 3.8 liter engines in the Gen 3 vans had their tensioner accessible from the top, however, in the Gen 4 vans the bottom is clearly the way to go.
Regarding your situation vis-à-vis the water pump replacement causing an alignment issue, I find myself wondering about things like, A) differences in gasket thickness compared to the factory gasket, differences in the drive axle versus a Mopar pump (I'm assuming you have an aftermarket unit), and C) if there was any residual gasket material from the factory gasket left behind when your new pump was mounted.
Best regards,
Shipo
