You are absolutely correct about the red lighting being better than the blue.
However, the "blue lighting" in the Mazdas is really a non-issue. The accent lighting is extremely subdued, to the point that you really don't notice it much - and the blue on the instruments is really just a subtle contrasting backdrop for the text and indicators, which are red, as they should be.
The bright blue instruments on my old Jetta (which VW touted as a clever feature that made them different) really kick the migraines in, let me tell you...
-c92
How do you figure it will "definitely top" the new Highlander when we don't know anything about it yet?
Ford *and* Mazda are not at the same level as GM in that department then :-)
That is the one point where I don't agree the CX-9 has an advantage for its target market. Straight line acceleration is about the same and it is not like people will be carving canyons while carrying 6+ passengers.
At any rate, I think we just entered "it is too/it is not" territory...
...but I am right ;-)
I guess the difference is that when not only are folks here in this forum saying that the driving dynamics are better in the CX-9, but so are several magazine reviews. The Odyssey minivan beat the Town & Country and Sienna in reviews because of the better driving dynamics too, and I don't expect many minivan owners to be "carving canyons." Better driving dynamics is beneficial even during normal driving, as well as being safer.
Braking is better, so I would agree to that account.
My "it is too/it is not" statement was less about performance than about all the other points. The "about the same" comment about parking space maneuverability - despite the CX-9 shorter wheel-base, narrower body and smaller turning radius - made it that much clear.
PS: The Odyssey beat the other minivans in other departments besides performance. Car & Driver, for instance, also listed "the best front seats, great instrument cluster, nifty second-row mother-in-law seat". It also dinged the Caravan for "rather bleak interior materials".
As the owner of an '06 Oddysey and now a '08 CX-9 GT I feel qualified to reply about the ad that bugs you.
I regularly have screaming kids in the car, and I also regularly get hit in the head.
The Honda beats my old '05 Audi A4 3.0 AWD Convertible for fun. Hard to believe but true. In the convertible I couldn't really hear the passengers screams, and the back seaters only saw the backs of the front seats so the fear never really could build properly in the turns.
Damn it if I don't get the Honda to flip some day.
All joking aside I am constantly amazed at how nimble, responsive and yes fun the Odyssey is to drive, when I floor it I love to see how fast it toasts other cars. I will say fully packed with 8 people and luggage it def boged down and would not go above 108 no matter how hard I pushed it.
Bottomline you are right you are never going to convince a hot chick to hold your grab handle by driving a honda minivan, but hey my wife wouldn't want that anyway. You will get full sheets of plywood, and 10' lengths of pvc pipe in without the tiniest complaints. The Oddysey is my workhorse the CX-9 is my wife's "I am not a soccermom" car, and my get all dressed up and go out without the kids, dogs, neighbors, church choir, book club all at the same time car.
Tommy
So far, both engines have done well, for all vehicles involved.
Totally agree, and I would like even more torque: when my wife and I test drove the Acadia, we both noticed sluggishness of the line, and hesitation when trying to accelerate when driving at 40 mph or so. Now this could be due to the faulty transmission software that has now been somewhat rectified, but the Mazda was definitely more responsive, and I believe weight is definitely an issue.
So to your point, the Acadia definitely needs to achieve most of its torque at lower RPMs, and that's the way the engine was tuned. Once the Acadia gets moving, it performs fine: it gets similar 0-60 and quarter mile numbers than the CX-9.
Well said. My sentiments exactly.
Low end torque is not something that you need "advanced" engine tech for anyway. Detroit has been making high torque at low RPM engines for decades now.
You are missing the other portion of the story, the HP numbers are better too. Even the larger Mazda engine is a few HP shy of the GM's.
Achieving high torque at low rpm AND high horsepower at high rpm is a challenge that GM managed to achieve better than Ford. If you have to spin an engine faster to produce the same amount of torque, given the same combustion efficiency and engine size, you will spend more gas. That is how GM managed to keep the mpg numbers for lambdas low for its size and still tie the CX-9 performance numbers.
400 lbs of weight are not the issue here. Case in point, Ford uses virtually the same engine in the TX 08 as Mazda does in the CX9 07 (same peak torque/hp rpm) and yet the TX is nearly 400 lbs lighter.
It depends on whether you consider Variable Valve Timing technology advanced. Excluding the large displacement engines used on Detroit muscle cars, smaller push-rods have largely fallen out of public's favor for their lack of power at high rpm. It is hard to move those rods fast enough, valve floating and all that.
The Mazda engine has a whole lot more torque than the GM so it makes perfect sense that the Mazda engine will reach peak torque at a higher rpm.
The torque for the Corvette LS-6 engine should peak at 8000 rpm then :-)
Peak torque and peak rpm are not related that way. To illustrate that point with an extreme example, the Mazdaspeed 3 engine has a higher peak torque than both CX-9 and the Outlook (280 lbft) and yet it happens at a very low 3000 rpm.
Peak numbers only tell part of the story, as an engine may achieve higher torque than others through part of the rpm range but still have a lower peak torque. That is why one would never try and have that Mazdaspeed engine on the CX-9, it peaks high and abruptly without sufficient low-end torque to adequately move a loaded 5000+ lbs monster from idle. When they put it on the CX-7, they wisely tuned it to deliver a flatter curve with considerably lower peak torque (240+ lbft)
Come on people! did we not already see this? The Lexus GS got bad ratings from the godly CR 2 YEARS AGO.
I appologize for forcing my oppinion that CR isn't biased to Toyota.
It's funny about the Chrysler Vehicles that CR says are realiable, as they may all be on the chopping board RIGHT NOW.
Braking distances are worse in the CX-9.
So what you're saying is that neither one is better and that the buyer can only really choose based on looks/styling?
I guess I can agree with that (though that's probably not what you're saying).
That is the right way to look at it though.
Popular mechanics had them tied for braking but got better handling numbers on the CX-9
Do you have any source showing the CX-9 braking numbers to be worse than the lambdas?
What they said is not important, I want to know what they measured. Fork the numbers or concede the point :-)
All joking aside? I hope that 108 with 8 people in a fully loaded van with screaming kids IS a joke....
Their numbers are useless for comparing two or more vehicles. Mainly because they don't test them together on the same day in the same conditions. MT shows 127 feet from 60 for the CX-9 and 124 feet for the Enclave. Pretty much a wash IMO.
Oddly enough, the smaller utes were the ones which had the longest stopping distances save for the Veracruz. The latter took 134 ft. on that day according to MT which isn't bad either IMO.
When they tested the CX-9 and the Acadia back to back, the CX-9 stopped at 123 ft vs 138 for the Acadia. The weather was snowy according to the pictures.
Do slippery roads favor lighter vehicles while braking? I would think so, but never saw any test.
However, Popular Mechanics also tested a CX-9 and an Outlook back to back and got a virtual tie.
I am yet to see any braking numbers showing the CX-9 being *worse* than a lambda...
...so we can add that advantage to interior design, equipment, value, and driver comfort. :-D
That's a forced induction engine. You cannot really compare that with an n/a engine. However, in the CX-7 engine, it achieves 258 lb-ft at 2,500 rpm's, all through the power band, with peak HP at 244 at a higher RPM.
I really do not see such an advantage to the GM with how it delivers the power over the 3.7L Mazda. So, since you give the advantage to GM in that dept., you must say that GM is at a huge loss in the total vehicle design department because they built a vehicle that is over weight, and bulky.
I was illustrating the point that higher torque does not necessarily translate into peak torque at higher RPMs. I probably need to lookup some data on the power curves for both engines before debating it too much.
On the contrary, because of that engine, they got virtually the same acceleration/passing numbers as the CX-9 all the way to 70 mph, the same mpg, yet hauling more people and cargo. That carrying capacity, combined with a pleasant exterior design and one of the best GM interiors (sans Cadillac) so far seems to be winning buyers from all other brands.
The numbers I posted were from the SUVOTY competition and the CX-9 and Enclave were tested on the same day in that case. Does the Enclave stop that much better than the Acadia?
Dodge Caravan is quicker 0-60. Edmunds says it's the quickest minivan they've tested.
Does anyone get Consumer Reports? If so get the issue with the CUV test, where the Outlook took 1st. I read it in a magazine/ book store, so I don't have it.
Like I said, less cheesy ineterior, red lights, more equipment, smaller center console for more driver/passenger space, better value. And I will find the CR braking numbers. So interior design,equipment, value, braking distances and driver comfort= advantage Lambda. Nice try.
sitting back laughing to myself with feet up and a beer at hand...
According to CR:
Braking from 60 mph:
Mazda CX-9: 150 feet
Saturn Outlook: 142 feet
There's a whole other story that you're forgetting here, in terms of mpg: the transmission was specifically programmed to give better fuel economy. It does a very quick 1-2-3 shift, and holds gears a long time (especially 5th). Kinda painful when going up inclines and it doesn't want to shift into 4th. GM Insiders have noted that although they have reprogrammed the transmission software, they couldn't really make it more "sporty" because it would result in lower mpg.
So the engine is definitely the whole story here, and actually I would say that the way the transmission software is the main factor in better/same mpg.
According to CR:
Guys, CR does not test the vehicles on the same day in the same conditions. Please don't use their numbers as reference because it is very misleading. Nastacio and I previously posted numbers from head to head comparisons where the CX-9 was tested on the same day as two different Lamdas. One time it did better, the other time it didn't.
For all we know CR could have tested one in the snow and one on a 100+ degree road.
It certainly does, hard data on one side, "it is too" on the other.
Still trying to figure out the whole 30+ cu.ft of cargo capacity difference? :shades:
As for the capacity, I lost interest in that conversation pretty much when it was over here as I'm still happy with our purchase.
I could only imagine what else we'd be reading if atexeria was in on this latest diatribe as well...
still chuckling quietly on the sidelines with gregg_vw sipping another cold frosty one...
I still say it's a combination of the narrower width of the FS and height of the cargo hold...see below.
http://www.familycar.com/RoadTests/FordTaurusX/
"The seatback folds down, and then the whole seat pivots backward to make a load floor that aligns with the second-row seat. Even the front passenger seat can fold forward to accommodate something 9 feet long. The one drawback is that the cargo hold isn’t very tall."
http://www.familycar.com/RoadTests/FordTaurusX/Images/Load-Floor.jpg
vs Acadia
http://www.familycar.com/RoadTests/GMCAcadia/Images/LoadFloor.jpg
And I completely agree with you, but after two beers one could suggest GM was cooking the numbers.
It should do quick shifts thought. Unless you are under full-throttle, what is the point of revving past the peak torque rpm (3200) other than keeping the engine in the sweet range for the next gear?
What got me though, was gear hunting during our test drive.
Flooring it while going up an incline sent the transmission from 6th to 4th, then to 5th and back to 4th. Within 1-2 seconds, the thing started moving with some gusto.
