Honda Pilot Transmission Problems
At approximately 136,000 miles, I began to notice a bit of a jerk when the car shifted up. This was intermittent, and sometimes occurred between 1st and 2nd, and other times between 2nd and 3rd. Occasionally I would notice it from 3rd to 4th. The problem became more regular and when I had my scheduled service at the dealer, I mentioned it, and was subsequently told that no problems were noted when the technician drove the car. A couple of weeks later, the problem was constant, and this time the dealer said I had an internal problem, and they did not work on transmissions, but only replaced them with a new or rebuilt unit. I subsequently took the car to a local AAMCO service facility, and after inspection, was informed that the transmission was badly damaged. The mechanic that fixed my transmission said that he has seen quite a few Pilots come in at nearly 140,000 miles with the same kind of damage- that it almost always involves the 3rd gear, and this subsequently leads to failure of the transmission. He even went as far as to say that he believes that Honda has a problem with these transmissions.
I'm wondering whether anyone else has had a similar problem. I know there was a recall several years ago that involved a minor modification to the transmission, but when I brought my Pilot to the dealer, they said it was not affected. This is my first Honda, and it has had all service done regularly by the dealer. Perhaps 140,000 miles is considered about normal before a transmission wears out in such a vehicle, but I assumed it would last longer.
Any thoughts???
Any thoughts???
If you didn't know '99-'03 Honda V6 transmissions are prone to premature failiure. There is a class action suit against Honda for these early failures.
link title
You may want the Honda dealer to look at the car. Tell them you are aware of the hig failure rates of the V6 transmissions. Many people have reported receiving discounted transmissions (Honda pays for the trans, you pay the labor).
Good luck. If this was your only problem after 140k then you didn't get too bad of a deal.
I have a 2003 Honda Pilot LX with 52,000 miles on it. It runs great but I have noticed that the engine hesitates to upshift to a lower rpm at low speeds, ESPECIALLY when it is going downhill. I would like to know if anyone has this problem??
But in any case, the thing I wanted to emphasize to everyone is that they have to make sure to change out their transmission fluid when Honda recommends to. I have noticed that my transmission smooths much faster and smoother when this is done and I've been told that the fluid gets black mighty quick. I think that this may be a byproduct of the tranny problems.
pjhrtd - you need to get your car checked out, there is no special way to downshift other than hitting the brake (but i'm sure you have no problem with that)
I agree with you service recommendation. I would suggest draining the tranny at 15,000, it's easier than changing the oil since there is no messy filter.
Is this the SAME transmission that's been in the Pilot since the beginning? I can't find any solid information on this...
Dave
As for the transmission staying in a lower gear when going downhill, this is the computer's "Grade Logic" at work, adding engine braking to keep the car from gaining excessive speed downhill.
I wish the Pilot had a manual shift gate like my Acura TL, but it's not to be...
I am having the same issue and not sure what to do I have the xtended warranty (thank God) did you ever resolve this issue??If so what was the resolution???
Below are the specifications for the model years that show the gear ratios.
2007
http://www.hondanews.com/categories/889/releases/3635
2006
http://www.hondanews.com/search/release/2943
2005
http://www.hondanews.com/search/release/2265
2004
http://www.hondanews.com/search/release/1469
Joe
I am not suggesting that this is the case with your car. I am saying that buying a used car is risky if you cannot prove the service history of the car. A honda that has not been maintained properly cannot be expected to be more reliable than any other car that hasn't been maintained. The pilot was my first new truck. All my other cars have been bought used, but I made sure that the owner had dealer service records. No quicky-lube oil change with kitchen towel oil filters for me.
I purchased this vehicle specifically because it had great reliability ratings. I obviously have huge concerns about this now.
I took it in to be checked out today. I was shocked at the amount of the proposed repair bill. I, of course, declined.
On my way home I contacted the national Honda Customer Service center (800-999-1009) to ask for their help. They didn't offer any promises and said that each determination is made on a case-by-case basis. They took the service manager's name and the salesman's name. They were very friendly and said they'll contact the folks at Bob Lindsey and then have someone contact me within 48 hours.
Shortly after arriving home this evening my salesman called and offered me a discount on the transmission repair. I was very impressed that he put in the extra effort to research and identify some discounts (I'd seen him talking tothe GM on my way out). However, it still isn't enough to make the repair feasible for me.
I'll update this after I hear back from the national Honda case worker. Assuming Honda (both National and Bob Lindsey) make this repair feasible and newer models don't suffer from this, I'll very happily continue to be a proud Pilot owner. If it turns out to be otherwise, I’ll post it here and help spread the word to beware.
When I explained this frustrating period of waiting to the lady who took my call this evening, she politely apologized and said there is nothing that can be done until this one person responds. Until this case worker does so, I'm out of a functioning vehicle (that I had thought was the pinnacle of reliability).
I'm trying to write more politely that I'm feeling, but I am beginning to sign up for the various forums available for venting should this blown transmission lead to a "blown gasket".
I'll update this once more info is available.
Susan
Is this an acceptable equivalent to the Honda Transmission fluid? Do you think there is any damage to my car using this other fluid?
Thank you so much for your help!
Kir
Susan
1. By pressing the 4VTM button on the dash. The rear wheels are engaged upto 16 miles an hour. Us this button to get out of a sticky situation.
2. When accelerating to prevent torque steer and to improve acceleration.
3. When slippage is detected by the computer.
Other than in these three situations Pilot run on front wheels.
Is there any negative to this? It would seem to me I'd save on gas as compared to AWD? Comments?
S
I would rather have the peace of mind of full-time AWD than a part time system like the pilots. But the pilot offered a great value and I decided to live with the part time AWD system. When I drive in the snow I am more careful and don't push the truck as much s I used to push my Landcruiser or the ML320. I have driven both those vehicles in heavy snow storms from New York to Washington DC and they both drove well. I have't done that in the pilot yet so I couldn't tell you for sure how the part time AWD system compares with the Landcruiser and ML320.
But if I had a choice of two vehicles that met my needs and one came with full-time AWD, I would go for it especially if I live in the snow belt.
Also tried out the Vehicle Stability Assist in an empty parking lot at a ski resort and it worked well, I couldn't make the Pilot spin-out. I turned-off the VSA and all four wheels are fully powered and will spin, just like a normal 4WD....made a couple "drift" loops just to practice my skid recovery.
I have exactly the same problem as you had - same speeds and all. Would be happy to know how you solved yours...
D
Less than 1k miles later, while drving on the highway at 65 mph, the VT-4 light comes on. I do not have to push the VT-4 light for it to come on, in fact it no longer responds to the bottom before or after it self-initiates. Sometime, it comes on even when the vehicle is just idling.
I also began to notice a bit of a jerk when the car shifted up. This was intermittent, and sometimes occurred between 1st and 2nd, and other times between 2nd and 3rd. Occasionally I would notice it from 3rd to 4th. The problem is becoming more regular. When I slow down, the engine / transmission rumbles. Any suggestions?
Speaking of fuel economy....it sucks.
I regret buying this vehicle. I will give it a few weeks to see if I can get used to it, or just dump it and buy something more powertrain friendly. I drove a Toyota Highlander on vacation recently and it was way better. I bought the Pilot mostly because it had a better backend to haul stuff. Stupid decision.
Avoid this vehicle.
bw
Hang in there.
i have honda pilot 2003 model, which has a transmission problem, and the dealership told me it needs to be replaced. Pilot has 166000 miles.
With this many miles is it advisable to get the transmission replaced? or just replace the whole car. Meaning, how many other problems can i expect on this. I just had the brakes etc replaced for a 1000 $ a month ago. a 400+$ timing belt replacement is coming up in a month or two.
Should the transmission be replaced at a honda dealership or other places like aamco.
Without getting the transmission fixed is it possible to get the annual car inspection passed?
what kind of warranty is typically offered on these replacement transmissions.
If i trade this car in, do i have to disclose to the dealers about the state of the transmission. If they dont ask then i am planning not to say anything about it.
i dont have much experience in this area, do the dealers typically ask questions about the car that is being traded in?
