Saturn S-Series Electrical/Lighting
                                  in Saturn
                    Just recently, my Brake light started coming on, on my dashboard for several seconds or more then going back out.  I checked the fluid and it was fine.  The next time the brake light came on, I noticed that the needles for Both my Speedometer and RPM gages dropped to zero for as long as the Brake light was inlluminated.  Once the brake light went off, the needles once again showed my speed and RPM (were functional).  This occurs while I'm simply driving down the road.  What could be wrong and how do I fix it?  Thanks.
well if you got a clue to my car sl1 problems of power lose to gauges and fuel indicator going down and then back up and the rpm and speed gauges doing the same.but sometimes total power lose to everything. All power out to engine, lights complete power failure any commits please.????? :sick:
I did notice when it happened that it was cold out side. This is not the first time it has happen to me.
First: The brake light is probably coming on because your emergency brake handle isn't all the way seated.
Second: the brake light when it comes on is probably sapping enough power from the dash display module to drop your computerized stuff all to zero, Because of the low output from the alternator. Put a new alternator into it.
But my Haynes manual makes no mention of where these are located, nor how to get to them without unnecessarily tearing the whole dash and subcomponents apart.
Does anyone know how I can get to these items to check them for proper functioning and adjustment? If so please post ASAP - thanks!
My problem is that when I first start the car in the am after an all night rest, the signals may or may not work, about a half hour later they will always start working.
I also have a problem with the headlights (auto day/night system) in that if the headlights are on when first starting in the am, I park the car at school and the headlights will not go off. It is daylight when I reach my destination, but have to use a flashlight to shine on the dash sensor to get the lights to turn off. Bad sensor maybe?
Any info would be appreciated.
Thanks St.West
Yesterday I was 95 miles from home and I had a transmission leak from the filter.
I lost 3 qts of oil. I replaced the filter and put 3 qts back . The reason I looked under the hood was 2 fold. I kept stalling at my destination and the ABS light was on. The engine would stall only if I applied the brake pedal.
Six hrs later in panic mode ,having to drive 85 miles back home I found 1 solution.
Remove fuse from brake and I made it home. If I but the fuse back in and press the brake pedal the engine will die .
Okay my transmission was soaked with oil. I cleaned off all oil. I checked the wiring harness and it was clean .
**In front of transmission are 2 sensors or switches.
If I look at wiring diagram it shows Brake transmission safety interlock ,Brake sense switch and stop light switch all in series. Could one of these be my problem?
Another thing when I step on brake pedal the dash board left and right signals light up dimly .
Today I put the brake fuse back in and everything is okay.
I do not trust this car at the moment. Anyone have a clue
Please let me know what you think. Thanks
Any help or suggestions would be great ..
Rick
Phoenix, Az.
here they are:
-my rear window defroster never worked (bought it in the summer so i didnt notice)
-my gas gauge stopped working, then my car wouldnt start...fuel sensor was broken according to the dealer, and was fixed for about $700
-all my dash lights went out
-my driver side window stopped working...the dealer said it was both the switch and the motor (not sensible to me) but i havent had it fixed yet
is there maybe some overall electrical issue with my car causing all of these individual problems? i really dont want to keep spending hundreds and hundreds to fix them but not actually find the source of the problems
Here's a guess based upon not being there...have you ever replaced your engine coolant temp sensor (ECTS) If the car doesn't know its hot the fan won't come on. Also, the S-series fans come on when the temp needle is just about to enter the red zone, higher than most....
coil packs and intake modual valve. none of this has helped. does any one have a clue? also the engine fan will not come on
Event 1- I start the car and start to back out of the parking lot. All of my indicator lights stay on and I have zero gas and zero speed. (though I have gas in the tank and am moving.) I turn the car off and the engine cranks but won't turn over. So, I disconnected the battery waited 1 minute, reconnected, and it started fine and everything worked.
2- Later, I was driving and my fuel indicator rapidly fell to 0, I lost speed indicator and my indicator lights went on (after driving a while this time). I pulled over, turned off the car and restarted. Everything was fine.
3- Again, I pulled out of a parking lot and lost power steering. I rolled out of the way, and after a few tries with just cranking, the car started and everything was fine.
4- Last night, I left work and it wouldn't crank at all. My clock was even blank. But the radio would work when I turned it to the fan/ radio on position. I disconnected the battery, 1 minute, reconnect, and it started fine. Started fine this morning too.
I'm suspicious about the recent hot weather here having a part in this, but it wasn't hot every time. Probably not the battery because most of the time it works.
Any ideas? How much is this going to cost me?
I've troubleshooted some and have determined that it's not an alternator or fuse problem. None of the relays are specific to that area either. I believe I either have a short at one or more of the wires at my instrument panel or it's a computer chip problem. The problem does seem too specific to be a computer chip problem (no fuel injection, or any other problems.)
The problem is finding a schematic or wiring diagram for this area. I don't want to remove the dash and pull or adjust the wrong wire (air bag) and cause some serious problems.
any ideas??.. first time here. bye the way...it has 178,000 on it and runs
like a top. from what i've been reading, i'm very lucky.
thanks keith
great form...
THANKS MILTON
Make sure you get the actual codes and then post them here. I'll keep an eye out...
Bought a 96 SL1 SOHC 3.5 years ago with 261,000 km (now over 362,000) on it. It's a plain jane with minimal electricals on it- lights, heater, rear defog, and radio.
The first year it was fine, but has gone through 6 replacement alternators since (just put on #7). The battery has been changed twice with the alts. Some of those alts have failed in as little as a week, others lasting 6 months. Some of the alts were making a low volume med-high pitched whistle, after failure.
Both my mechanic and I are stumped. We both have never seen or heard of such an occurence before.
Anybody have ideas on what is causing these failures?
Argus462
Stan Cobb
Savannah, GA
Simply pull the top section of the plastic steering column apart. This allows you to see the turn signal switch. Unplug the existing switch and compress the top and bottom tabs on the switch, then slide the switch out. Push the new switch in and plug it in. Snap the plastic steering column back together. Hook battery back up and your done!
thanks,
Stan.
Also when I bought the car 3 years ago, the dash lamp for the temperature gauge side has been out.
Tlflan
thanks much!
