Visitor Agreement.
I'm not that surprised. How effective it is in a straight line is probably dependent on how easy the brakes are to modulate, and the quality of the driver. For panic situations, I'd imagine that ABS beats having all 4 locked up for a novice.
wale_bate1 - I, too, would be interested in more info on how pervasive a problem this is. While reminders to drive alertly and with caution are always appreciated, I haven't seen a lot of documented consumer complaints about this.
MODERATOR /ADMINISTRATOR
Review your vehicle
"While reminders to drive alertly and with caution are always appreciated, I haven't seen a lot of documented consumer complaints about this."
I think there's more than a few folks wondering the same thing. Given the pervasiveness of FWD vehicles over the last 25 years or so (and the fact that the vast majority are equipped with automatic transmissions and see duty in adverse road conditions), one would think if there was a problem it would be getting a bit more airplay.
I'm just hoping that some driving novice lurking in here doesn't think that they should be bypassing the ABS system and using the e-brake instead..... :sick:
Is that wrong?
Can't be; look at Jason Bourne...
You forgot one thing:
it's a conspiracy!
We consumers have been kept in the dark.
Seriously, thanks to you and the others that have done a good job questioning or debunking some of the theorizing that's been going on here.
Meanwhile, I'm parking my RWD, rear-only ABS Frontier (with manual transmission, no less) in anticipation of adverse road(bed) conditions tomorrow -- snow and ice. And (horrors!) the FWD, 4-wheel ABS, automatic Camry is going to get me to work! I may even use the defroster!
Maybe I should rephrase that then:
"I'm just hoping that some driving novice lurking in here doesn't think that they should be bypassing the ABS system BY using the e-brake instead....."
Better? After all, I'm only repeating your sage advice from post #47:
"Yes, applying the rear brakes in a controlled manner via the e-brake defeats the Anti-lock system, but there are times when that is exactly the desireable outcome."
Ah.
Well THAT certainly cleared things up..... :confuse:
I'm still waiting for those English subtitles. :sick:
