Troubleshooting the Pathfinder
I have two questions:
My first regards installing a K&N air filter to get better gas milage. After installing, I disconnected the negative side of my battery to reboot my computer, but didn't notice any difference in performance. I repeated the process and left the battery disconnected for a few hours and still no change. Any tips??
Second, I recently sprayed out my engine bay at a local car wash. Now my pathfinder is hesitant when I push on the gas. It seems to react a little better at higher RPM's. I checked to make sure my spark plugs were all connected properly, and checked my distibuter cap to make sure there wasn't any water traped... I also ran some SeaFoam in my last tank of gas and a little with my enging oil... Any help?
As for the washing, you probably loosened something or got water somewhere, check your vaccum lines for leaks or disconnects.
-mike
Also, I was planning on replacing my spark plugs. Would this help the sputtering acceleration if my current plugs are dirty or malfunctioning?
15->16 maybe.
Advantages of the K&N will be better throttle response, more power, also if you increase your exhaust size the higher flow of the air filter will help it as well.
Better for the environment since you re-use it for the life of the car, rather than throwing it away ever 15k miles.
As for spark plugs, can't hurt to replace em on a 94 Pathy.
-mike
-mike
-mike
J.P.
if it is egr motor $140 they will replace and the control value $55 and clean out the metal tube that may have carbon in it they say it is a 5 hour job. it all seems a bit high
is it the said parts and can i do it myself?
It was driven up till the exhaust went and I parked it 3 yrs ago...
I really want to get this thing back to life but I cannot get it to start now. Here is what I have done so far.
- Drained the old bad gas out really really yellow stuff
- Drained the lines
- Found the new Gas I added smelled more like bad gas the fresh stuff redrained it again.
- re drained the lines
- I cleaned the plugs they still look new as I put then in just before I put it away...
- The Fuel pump is working-----
- Truck fires up when gas is added through the carb---but wont run on its own.
- Took the carb/throttle body off cleaned it still nothing
- Added a bit of oil to the cylinders
Anyone having any suggestions feel free to help me out.... This Pathfinder was good to me so I would really like it back
I have the same truck. You said you drained the lines but did you change the gas filter? It would be clogged if you had bad gas.
RM
When veh warm enuf to not stall it will either shift thru pattern to high gear. When coning to stop will stall. trans does nt disengage. you can shift to neutral and get a high idle. when at complete stop put trans in drive. no problem. once veh op temp veh runs and ops norm
How in heck do you remove/move these stinkin roof rack cross bars?! I can't get the torx screws loose - I already stripped one. :mad:
2) I've confirmed by testing that my speedo is showing too high mph. For example, when the speedo shows 65 the vehicle is only going 60. I can adapt but would prefer it be closer - I know some cars are off but this is almost 8% different. Anyone have this or know anything about it?
3) Have dual zone climate control; everytime I start the truck, I see the defrost logo come on. It goes off after a few minutes. It's winter so it's usually mid-30 degrees or below outside and I know that when defrost is on and outside temp is under 36 f the a/c is activated so I'm concerned about gas mileage. I'm not manually starting the defrost - it happens automatically. I can't find anything specific in the manual - Is this defrost thing normal?
Thanks!!!
Any thoughts on how to get it out of 4W Lo?
any info would be great
i did it myself... drained the quarts...then replaced nut.... filled what i removed... then i disconected hose at the bottom of radiator in front of oil filter... i placed a 4 foot hose attached to hose i removed and with a buddy i started engine for 4 to 7 seconds... when quart container filled i stopped engine and also placed 1 quart of new tranny fluid... did it quite a few times untill fluid was coming out red new..
Lifted front end and couldn't determine problem. Now I'm thinking the CV joint.
Any ideas or suggestions?
it seem .s your car went into a shut down lockout mode ,which try auto zone for free to see if they can flash the computer or a dealer get a price to re flash the computer. it should not cost much for this operation.
It died as I pulled in to the parking spot at work. I still had power (lights, radio). I turned off the car and attempted to re-start and got nothing. no click or anything. still had power
Can anyone help??
