BMW 5-Series Starting Problems
My 2001 525i wouldn't start. Just a "clicking" sound when I turned the key. Thought I may have had a dead battery; friend provided a jump. Still just a "clicking"--would not crank. Disconnected jumper cables, THEN I discovered I did not replace my gas cap the night before after filling with gas. I replaced the gas cap. With the jumper cables NOT connected, turned the key again, Bingo! Started right up. That was three days ago. No problems since then. Was the problem the gas cap or do I have a problem with my ignition system? If it is the gas cap, why did it start the night before when I left the gas station with cap "off"?
Thanks !
Thanks !
The clicking sound, though, is usually when you have a dead battery. I would try to repeat the occurance again. If the same thing happens again, I wouldn't worry about it too much. If it doesn't, then I would look into it a little further. The car will probably start the first time, and then not start again. Try it and see what happens.
Has the battery been load tested?
Terminals cleaned?
Ground cables cleaned?
Those are the most likely culprits.
Connections at the starter clean/tight?
How can I tell if the problem is the starter or alternater or anything else? Please advise. Thanks.
If the battery is discharged you either have a bad battery, an excessive current drain on the battery, or a bad alternator. Any good shop will be able to load test the battery as well as measure the current drain and alternator output. My bet is on a current drain, altenator next, and a bad battery last.
Best Regards,
Shipo
Hardie
Any thoughts or direction would help - I recognize this is for 5-series Bimmers - but would be thankful for help with my 3-series.
Have the battery load tested.
Sierrajadeus :confuse:
2. Load test the battery; a simple voltage test often won't reveal a bad battery.
3. How do you know the alternator is "fine"?
My money is on a bad battery.
I seem to be having the exact same issue with my car. 2005/525i, What was your soulution?....Car first started with a small hesitation then it just won't start, it won't even try....(Like if not pressing the brake pedal). Thanks for yoiur prompt response.
I have a 5.25i BMW, 1989 model. The car started to give some problems some months ago. The moment the ignition is turned on, the rev will be going up and down and will be dwindling between 200 and 700. after about a minute of doing that, it will switch itself off. Atimes when i'm in motion and i suddenly apply clutch and brake, it will also go off, in the same vein going on very rough raod could be very tough, the car will always go off. My elecrician had checked the Air flow meter, Air valve and could not locate where the problem is. The funny thing is that if the rev is increased to about 800 now, before long it will come back to about 300 or 400 by itself. Pls is there any serious problem that i must deal with here?
kapu808@hotmail.com
808-306-1997
danny
had the battery tested and it was fine , all the instruments lights are all working but the car won't start
can anyone help
I took it to the dealership (still under warranty), and they said it was fixed. The believed it had something to do with the break system, that the car was not registering when I was pressing the break while starting the car.
The problems have started to occur again, and wanted to see if anyone else had experienced the same problems.
Does anyone have an answer? :confuse:
my car doesnt start in the morning, i tried, charging the battery n putting it back and it starts up fine, but, the next morning it wont start and the battery would be flat. i also bought a brand new battery but it dint change anything.
Can someone please help me with this?!!
If you have a clamp-on or in-line ammeter, you could monitor it and then go through the fuse panel, pulling one fuse at a time to isolate which circuit is drawing the power. That will get most circuits, but some are on fuseable links, which are harder to check.
