Honda Pilot 2007 - 2008
in Honda
Just picked up a 2007 EX-L Pilot last week. So far, I love it. Drove an Explorer previously - the Pilot drives much better. Also, I'm 6'5" and I fit nicely even with moonroof.
Anyway, much to my surprise (and my wife) the doors dont auto-lock when the car goes into motion. I called the dealership I purchased it from and they said it cant be done. I called another dealrship (about 50 miles away) they said its a simple programming update - just come on by???
Looked through the manual and dont see mention of this feature. Driving us crazy as our last 3 cars had this feature and we end up driving around without locking the doors.
Seems like a saftey feature they'd want. None of the reviews I read prior to purchasing complained about not having this features - which surprises me.
So just wodnering....
Let me know if you find out anything to the contrary.
However, if you are involved in bad accident, a locked door may prevent someone from being able to rescue you from outside (they would need tool to cut the door first, or break the window while your family are still inside). So whether or not it is a safety feature depends on your view. In any rate, if you like it , you can always hit the central lock button, which is just one push away.
As far as turning on the lights vs true DRL's I prefer turning on the lights, especially in a car that turns them off for you. My Ralliart does that. I could care less what anyone else thinks whether looking from the front or back. If DRL's are good then headlights on are better. You have the marker lights on with the headlights as well as the taillights adding visibility to anyone following. If anyone is so silly as to worry what others think when their headlights are on they need to do some serious internal evaluation.
Just bought a new Ford Explorer SportTrac which now has less than 2000 miles on it. I know DLR's are about a $150 option on this model. My Trac has most everything I want except the DLR feature. Today the dealer made a computer adjustment during oil change, and pronto I have the DLR feature!!! Cost? N/C. I'm pleased. Now I have automatic lights and DLR's. My dim lights are on when the motor is running and I engage the vehicle in drive. Sweet.
FYI:
AutoLock: AutoLocking is not a feature available on the 03-08 Honda Pilot from the factory.
DRL: US 03-08 Pilots do not have Daytime Running Lights. I am thinking of installing a couple of relays to do so myself. One problem with turning on lights manually during the day as mentioned is that the dash gauge lighting becomes too dim.
Auto Off: This is a feature on Pilots above the LX trim. Turns off headlights and parking lights automatically 15 seconds after you pull the key from ignition. They come back on as soon as the driver door is unlocked.
Can anyone tell me if this is true, and if not, how do we get this feature working? We tried the method of turning the key to II and holding down the lock button, but it didn't work.
My nearest honda dealer is about 80 miles away so I bought the new wiper blade on-line.It came with no instructions and the owners manual only refers to the front wipers.
There are a couple small stops to prevent it from pivoting all the way to where it needs to be to remove from the arm. No particular release, just a "hard tug." I didn't particularly enjoy using the force needed to snap it past the stops, but I didn't see any alternative, and nothing appeared to break.
http://www.carspace.com/bigdadi118/Albums/bigdadi118%27s%20Album/2007_pilot_wipe- - r.jpg/page/photo.html#pic
What area of the car did you find this problem?
Where can I get a replacement garage door opener? I have called the local Honda dealers parts department but they put me on hold and could not answer my question. Any feedback would be appreciated. Thanks!
- Tuan
No part of the metal is pulled or twisted, so it does not appear that someone tried to pry it off. I showed the plate, the bolts, and the rear of the vehicle to the dealer, and no one had seen this before on this age of vehicle - a 2007. The dealer has indicated that Honda will not repair under any warranty - vehicle has 53,000 miles on it.
I have never had this happen to a vehicle in 36 years of driving. Has anyone else had this happen? I am very disappointed that Honda will not stand behind the vehicle.
I've done some online research and I guess it's a somewhat common issue that the rear license plate bolts on the 2007 Pilots will snap clean off, leaving the license plate laying somewhere on a country road or busy interstate highway.
As of today, my left bolt/nut is completely gone, and my right one is half-rotted through and is ready to fall off too. I've contacted my dealer twice about this, and they've basically blown me off (claimed it happened because I "over tightened" the bolts). I then raised such a ruckus that they put me in touch with Corporate, but Corporate says it's not their problem because the car is out of warrantee.
I'm furious - a 2007 vehicle has body rot to such a degree that parts are falling off it. I don't know if it's poor sheetmetal, a bad weld, or what, but Honda has an quality issue on their hands if you ask me. My brother-in-law knows welding, and he says that the materials were not properly clean in the factory before the weld was applied, and this resulted in a bad weld. He also noted (due to the fact that I have a gaping hole where the nut used to be) that the sheetmetal is VERY thin in the tailgate area. I am very disappointed that Honda will not stand behind the vehicle, especially given that it's only a 2007 and relatively new. Honda's actions (or inaction is more like it) will go a long way towards helping to decide which brand I will purchase the next time I'm buying a new car.
THAT BEING SAID, I was wondering what other people have done to fix this problem? I've heard a lot of good sounding ideas from friends and family, but I was wondering if anyone has any tried and true success stories. As long as it firmly holds the license plate in place and looks relatively normal (for resale purposes) I'm game for any type of solution. It doesn't have to be exactly the same set-up as it was when it came from the factory (since that's a failed engineering/design solution anyway). I'm fairly handy by the way, so I'd like to do this myself.
The local Honda dealer informed me I would have to pay $347 to replace these bolts. (Total number of bolts 7)
This vehicle has under 23,000 miles and is still under warranty. Plus it was sold as "Honda certified".
What should I do so that Honda pays to replace these bolts replaced?
I feel this is a safety issue since these bolts can crumble and fall off in the near future. Thanks!
Now, am I correct in assuming that once I leave the dealership I cannot purchase the extended warranty from Honda? We drive a ton of highway miles, so I wasn't all that interested in the warranty to begin with, but if I was, I'd want to shop around dealerships for it.
Overall, wife loves the car. It was pretty decently serviced for the CPO certification and the leather is in nice shape (not always the case).
Next stop - trailer hitch and roof racks for my surfboards.
Mark
This will be my last Honda though, I've had it with them.
I have opened and closed the fuel cap 3 or 4 different times, filled the gas tank a few times, however the message still flashes on my odometer.
Does this mean I have to replace my fuel cap? Also, my vehicle is due for Safety inspection this month. Is this a safety issue and will I fail the Inspection?
