I didn't ask about the oil recommendation. Any recommendations?
:confuse:
Paul
They don't put synthetic in it when it is new nor during maintenance unless you request it. (I got this from the service manager). They count on the low blowby and the large crankcase (7 qts w/filter vs 5 for most cars) to keep the oil going that long.
I still feel queasy about keeping dino oil past 5k. So, I plan to do the 1st oil change at around 3700 miles and use synthetic for all servicing after that.
The reasons that I'm going to use dino on the first change is because that leaves 3700 till the next service & dino oil will help during the break-in period.
Paul
I have a 2001 S40 with over 100K miles. This little pony hasalways been serviced by the dealership at 7,500m. They use synthetic oil and still going. Maybe you should try it.
I have a 2001 S-40. My service engine light is on and I've been told that I need to replace my O2 sensor.
Dealership wants a bit of money. If I change this myself will the computer reset it self or do I need to get the computer re-set by the dealership? :confuse:
The only other ways would be to use a scan tool to clear the code (can buy one for $100-$200) or pull the battery cables and reset things (however, this can cause the ECU to go back to defaults which can yield lower MPG for a tank or two, plus you'll lose your radio presets).
-Brian
thanks in advance,
Dave
When it comes to service I have no problem laying out the cash to the right people.
VOLVO XC90 -- Resetting the service reminder indicator (SRI)
(The text message "Time for regular maintenance" is displayed for 120 seconds each time the ignition is switched on.)
-Turn the key to Ignition position I
-Press and hold in the reset button for the trip odometer and turn the key to Ignition position II within 2 seconds
-Hold the reset button until the warning triangle flashes.
-Release the reset button for the trip odometer within 4 seconds. -The instrument panel gives an audible signal when resetting has succeeded.
It's hard to open it. Pls. help. Thanks.
Ecolyer
This did work on my 2007 S40, be sure to close the doors, turn down the radio, and tell your wife to stop talking.
Thank You
Paul
Pb
I also have a 2009 Prius and it took me less than 5 miutes and no tools last Saturday...Amazon price for the Prius Fram Fresh Breeze filter was less than $15.
Oh well, my Volvo seats are better than those on the Prius....
