2007 Honda Odyssey Touring-Variable Cylinder Mgmt
I recently purchased a new 2007 Odyssey Touring. When the Variable Cylinder Managment system engages (from 6 to 3 cylinders) there is a very noticeable hesitation/bucking. According to the owner's manual and Odyssey video, the driver will "not notice" VCM being engaged. I test drove two other Odysseys equipped with VCM and didn't notice any hesitation/bucking.
What you are describing, however, is something out of the ordinary. Sounds like it's time for a trip back to the dealer.
Hesitation & bucking is definitely not normal. Have the dealer look at it & keep us posted.
Do any fellow VCM equipped owners feel anything when the system engages/disengages?
My wife drives an 07 EX-L with same problem. At first, I also thought it was the VCM, but then I took it for an extended test drive. I noticed that when it does hesitate on deceleration the RPM goes up from 1000 to 1500. To me it seems that the transmission is downshifting whenever the van is coasting.
The van has a little over 1000 miles on it now, and seems like it doesn’t do it as much anymore, or if it does, it does it much smother now.
The tranny was redesigned in 2007 to be sturdier but it seems smoothness has suffered.
I'm noticing the exact same issues, at lower speeds. Seems somewhat to happen at the same time as the VCM engaging and disengaging. But have also noticed the RPM slight jump and drop also. It's annoying as heck to me at slower speeds. That said, my wife doesn't notice it and she drives it 95% of the time. Might watch it for a bit as the car has 800 miles now.
Would love to hear if someone else discovers a definite problem or solution.
She did say the ECO light flashed so much that she finally put a black piece of tape over that part of the dash display.
The ECO light in our '06 comes on every so often but not in a "strobing fashion" as she described. I just assumed she was overly sensitive to it.
My Accord Hybrid also has a (well behaved) ECO light as well.
I would have to have some experience in an 07 Ody to tell you if behaves differently than our 06.
I read that 2000 rpms translate to 60mph but mine does 1800rpms at 60. Did they change gearing for 07?
Why are the valves closed when the cylinder is deactivated? Wouldn't open valves cause less resistance since there is no compression or vac? Or does air drag cause more friction than comp. & vac? Just curious.
Don
My aunt's 2005 Odyssey runs between 1,700 RPM and 1,800 RPM at 60 MPH, so I think the initial info you got is a little off. My 4-cylinder Accord (2006, Automatic) runs at 2,000 RPM when going 60 MPH, but the engine is smaller and less torquey, meaning engineers tune the gearing differently to account for this. The Odyssey should run lower RPMs than my car, so I think 1,800 is normal, and that your van is no different than others.'
Yes, the '05/'06 Odyssey has a different transmission than the '07. The '07 Ody now shares the same transmission as the Pilot & Ridgeline (4 shaft design).
Also you are correct, the shift points are different.
'05/06 Odyssey: 60 mph = 2000 rpm
'07 Odyssey: 60 mph = 1800 rpm
I'm not 100% sure if they changed the shift points to eliminate the dreaded droning defect found on all '05/06's or just to maximize efficiency of the drivetrain.
I have droning sounds on my 2005 LX-L. THIS IS STRUCTURAL ENGINEERING DEFECT due to resonance. It occures at 1500-1600 and 2000-2100 RPM especially whem more torque is needed (acceleration, uphill climbing). It will not go away until Honda will change engine mounts or other unknown to me (probably to them too) parts. Changing A pipe reduces the sound, but A-pipe failure is due to the resonance and will happen again and again. The resonance is well known to damage and destroy things. Honda probably doesnt care about it, since damage occures way beyond warranty to other parts (already had power steering pump replaced as well as brakes) probably transmission and other parts.
People, if you in search of new minivan DO NOT BUY HONDA ODYSSEY LX-L (leather with cylinder managment) or Touring - it will give you trouble in future, unless Honda acknowledges the problem and shall fix it. Meanwhile it should give extended warranty on these cars for free as a courtesy and acknoledgment of destructive resonance -humming, vibration.
dvhagan
Has anyone gotten an answer for this problem?
So I am not sure these problems are related to the VCM, and will report back once I get a chance to take it into the dealer.
