2007 BMW X3 Hitch Installation
rarincinci
Member Posts: 2
With the purchase of my new 2007 BMW X3, I had the dealer install the receiver hitch option (to use with a bicycle rack). The installation was done such that the rear bumper now has a large hack sawed out opening that looks extremely unprofessional and unfinished for a $43K vehicle. This is unacceptable to me. There needs to be a better, more eloquent and less obtrusive way to provide an opening for the receiver. The receiver is only a few inches square while the hack in the bumper trim is more than a foot wide leaving an unfinished look and exposing parts of the under-structure that are not supposed to be seen.
Is this the standard procedure where they saw along the indentation in the bumper and leave the opening unfinished? I can now see inside behind the bumper cover and the hollow tube formed between it and some unfinished interior bumper under-structure. The edges are left unfinished and the under-structure part is not black like the bumper cover and is obviously not intended to be seen with exposed mounting holes and tabs.
If this is standard procedure, is there an after market trim piece? Has someone else come up with another solution that looks better?
If you want, I can take a picture and post it for you. If your dealer screwed up, you can show them the other pitcure.
These are closeups from a low angle. I think it looks much more noticeable here than in person. But I think you needed closeups to see the installation
See more Car Pictures at CarSpace.com
Even my wife didn't complain about it. I think the dealer said that the bumper came with a bump-out / cutout and it was a matter of popping it out. For my use, you need access well to the right and left of the hitch for the safety chains for towing, and for the electric hookup. I'd heard complaints about the bumper being hacked, but really thought BMW took care of that with the pre-set cutouts. In person and from a distance, it really isn't as bad as these photos appear, but however it looks, the things gotta work for a living, too.
I hope this helps.
If you get one installed, I'd like to know how that went and how and who did it. Thanks.
