Jeep Grand Cherokee Security System Questions
1998 jeep grand cherokee laredo . problem the horn goes off for no reason. I suspect something with alarm . Possibly detects door opening . Any easy way to disable alarm?
See Also: Jeep Cherokee Alarm System--How it Works
To disable the alarm you need to ground a wire that is running throught the drviers door jam wire harness. It is a violet with a yellow tracer wire. It needs to be put to ground.
On the drivers side in the foot well area just above the hood release mechanism you should see the wire harness that is coming from the drivers door.
In that group of wires, locate the violet with a yellow tracer wire. Do not cut the wire. Instead, strip the violet/yellow plastic off to expose the bare wire.
Get a section of new, similar gauged wire (18 guage works), and strip away the plastic on both ends to expose the wiring. Take one end of this new wire and wrap it around the exposed section of the violet/yellow wire.
Take the other end of the new wire and ground it to the body of the jeep. This will ground the system and should permantly disable the alarm system.
Here is a link that shows a diagram of what I have described:
http://www.allexperts.com/user.cgi?m=17&imgID=40582
Hope this helps!
use only the key no other stuff on the key ring
make sure that you are using the key that you know is good still sounds as if anti theft unit is still coming on
thanks...
yes if the light with the key is on the car is in protect mode some will not start at all once code is set (sorry to say that i dont know how to turn it off )
alan
Anyway, local comprehensive insurance rates are sky high so I'm looking to cut costs. After a lot of internet research, I've read about the RAVELCO engine immobilier which claims to have a perfect record over 30 years of NEVER allowing a car to be stolen by driving it away! No protection against towing, obviously.
Does anyone with this Ravelco system care to offer any feedback about it? I also plan to use a deadbolt hood lock and heavy duty Unelko brake pedal jack lock to layer my security.
Typical car alarms are ignored. Lojack and GPS tracking don't prevent theft, just track down what may be a stripped or destroyed car, and very expensive. The Jeep comes with a coded ignition key that I've read can be bypassed by thieves using laptop computers and car remote decoders.
Does anyone have a better solution, short of a 24-hour armed guard, to secure their car?
After opening the driver door panel, I do not find the purple / yellow wire. I think it's possible for Asia to have different wire colors. Please help me to explain exactly which wire to ground.
http://carcomputerexchange.com/jeep/grand-cherokee/cat_10.html
This was happening to me and it would be very frustrating with the alarm. I would lock the doors and the alarm would sound once I would go to unlock. I would have to go to the passengers side and use the key to turn off the alarm.
Permanent Disable:
This is a simple fix once you know where to look and what to do. Open up the glove box and remove the door to the glove box. Then remove the 4 (7mm) bolts. Once this is accomplished remove the rest of dash on the passenger side. Once this is done look at where the glove box was and there is some wires sticking out off to the left. These wires go to the alarm unit that is held in with only 2 Phillips head screws. Take out those screws then remove the plastic box from behind the dash. Finally start your jeep, ONCE THE JEEP IS RUNNING unplug the alarm. The computer will recognize that the alarm is still there from this point forward.
Using this fix action you will not have an alarm, but you will be able to lock the doors and not worry about the alarm killing your battery.
I hope this helps!
1995 Jeep Grand Cherokee
So would this instruction help my case. I assume the remote unlock unit will not do its thing anymore, requiring locking and unlocking doors manually?
