Toyota Camry Seat Belt Questions
i have a 2003 camry and today when i went to take the seat belt off, the belt folded over on itself as it retracted. when i went to pull it out it stayed folded and now refuses to retract. does anyone know how to take the panel off the side of the car so that i can fix this? i'm not at all happy about it and i've never seen this happen before in any car. i would really appreciate any help you could give me.
southerngirl64
And, like 210 delray said, heavy things on the passenger seat will cause the alarm to go off.
You reference the chime, and someone suggested to wear your seatbelt, and you replied back that you do.
Are you indicating that you put your seat belt on, and it still chimes? (with no weight on the passenger seat to trigger that seat sensor).
Or, are you saying you start the car and start driving without your seat belt, causing a chime, and then you connect your seatbelt later (or don't connect it at all)?
The manual describes the operations of the seatbelt & chime.
Then there are others who insist on carrying heavy objects (or big dogs) on the front passenger seat (where said objects can wallop your head really well in a serious crash).
Speaking for myself, the only place I don't wear a belt is in my own (short) driveway when I'm just repositioning the car. And heavy objects always go in the trunk, or if they must be inside the occupant compartment, they are put on the floor or buckled in place on the back seat.
Also, if the buzzer is going off when you are in park, just put the seatbelt on and take it off and the buzzer will stop (it does in my car). And, without a seatbelt on, my buzzer eventually goes off, maybe after about 30 seconds.
If this occurs for an adult, unbuckle the belt, let it retract fully, and then put in on again without pulling out the belt all the way.
Almost all cars have this feature today as a safety feature to more securely hold child restaints in place (does not apply for obvious reasons to the driver's belt).
I think that this type of seatbelt design is dangerous. It could choke people and/or injure someone.
Solution:
Don't pull the belt all the way out.
2010 Camry (same as 2011), kids, zero issues.
