Dodge Neon Modifications
I bought my 05 Neon because of it's infamous value. The car turned out to be much more than just an economy car. I added a jet chip for $223.00, aftermarket catback exhaust for $267.00 and a cheap little performance module for $23.00. After only $513.00, my Neon went from 132 HP, to 189 HP. Easy HP for cheap. The downside... most aftermarket parts for the newer Neons are very pricey. All in all, I absolutely love this car.
Thank you,
Dave Fritz
Also, any exterior mods that will look good on a yellow neon?
as far as the air cleaner goes removing the top does nothing but make it sound meaner and actually take power away.just buy a kit off ebay I only pain $20 for mine.
There is no way in heck a chip and an exhaust will add 60% hp! Why do so many people make silly claims like this? I bet if that sucker were put on a dyno it might see something like 15 hp improvement at most.
False info like this needs to be challanged. Personally, no one should be allowed to post hp improvements w/o proof of a dyno.
I AM A DISABLED VET ON A REALLY TIGHT BUDGET AND SO FAR I HAVE LOVED MY EXPERIENCE WITH THESE GUYS. I'M A CUSTOMER NOT A REP SO I GET NO KICK BACK, I JUST LIKE MY NEON AND HELPING OUT IF I CAN, YOU WILL BE SURPRISED AT WHAT YOU CAN ADD TO IMPROVE POWER AND MPG AND OVER ALL PERFORMANC, JUST REMEMBER IT'S HARD TO DRIVE AND FIX UP A CAR, SO BUY PARTS ONE AT A TIME AND THEN WHEN YOU HAVE WHAT YOU WANT PUT THEM ON. HOPE THIS WILL HELP
THE BEST WAY IS TO REPOSITION THE BATTERY BOX INTO THE TRUNK, LIKE I SAID NOT CHEAP BUT THE END RESOLT IS WHAT YOU SHOOTING FOR RIGHT. CHECK OUT MODERN PERFORMANCE . COM. THEY ARE OUT OF HOUSTON, TX. THIS IS WERE I AM FROM AND WHO I USE, I'M SURE THERE ARE OTHERS BUT I LIKE THEIR SERVICE, AND PRICES.
HOPE THIS HELPS YOU OUT. :confuse:
has anyone tryed one of those cheap MAF chips off Ebay? Or that throttle body coolent bypass?
I dont expect big gains but dose this really work?
If its a M/T the throttle body is 49mm the A/T is 52mm so pulling one from the junk yard or boreing yours out is easy,you can use a dremil.I also did the intake manifold. That along with a cold air intake and it will be able to breath alot better.thats the cheapest HP youll find.And it wont affect anything else.
You can put on a aftermarket coil and sparkplug wires ect.but thats not gonna add HP unless your cars having some spark problems?
Next id cover exhuast.The whole exhuast system on that car is a joke.A Header is a great upgrade.after the Cat its a straight shot till the gas tank,where it makes a "S" bend.Im gonna use a glasspack and eliminate the "S" bend.Its not as loud as you would think.It sounds okay with no muffler at all,but needs some back pressure.Just sliping on a euro muffler after the "S" bend wont change much but the sound.Hope some of that helps?Goodluck
