Dear gwmort, Can you expand on your tire wear experience. I am awaiting my Touring Prius and have heard some issues with Tire wear. The tires seem to have a "V" speed rating which seems to indicate a higher speed tire. Are you running "V" rated tires? What do you mean by "I never push the rated speed anymore"?? Can you expand on this some more?
Also, can anyone out there suggest a good 3 season tire for when my first set wears out? Good meaning: >=50K miles on a set, good 3 season traction, low rolling resistance and lower noise?
Go with a set of Michelin HydroEdge tires. 800 rated for treadwear, 90,000 mile tread wear out warranty. We got ours at Costco, which is cheaper than WalMart. HyroEdge is Michelin's lowest rolling resistance tire, by the way. They are wonderful where it rains a lot or for slushy surfaces. Combine those attributes with your traction and stability control, your ABS, and you've got a winning combination!
The reason I asked is the tires on the first model were a real expensive oddball. I know a friend that wore out two sets before he found a good alternative. He had to special order the OEMs from the Firestone store. He ran on his spare for two weeks when one of the OEMS failed. The new Prius seems to do much better on tires.
My 2007 Prius stopped running at 5000 miles....Toyota won't fix under warranty. Say I jump started it wrong.....so I get to foot the minimum $4800 bill. This does not make me as happy as I was the day I bought it. Had mechanic walk me thru the jump....and I know difference between red and black. So why did the car die in the first place....at less than 1 yr old. How could one do $4800 worth of damage anyway on a jump start. Anyone have any ideas of how to get Toyota to fix my sick car under warranty.
We all feel sorry for you. So, under what conditons did the Prius stop running? You came out in the morning, and it did not start? The gas engine did not some on? What happened when you pushed the start button? What error messages did you get? Why did you have to Jump the car? Did you jump the 12V battery - I assume? Was it dead? (zero volts) - I would guess you have a bad cell in the ELECTRIC battery - or more than 1 bad cell. Clearly that voltage was not up to par.. but I don't think you would try to jump start that battery.. you can't get enough voltage. What damage is the dealer saying was done? Is the battery now 'reversed polarity' from being discharged to low? Was there any warning signs before this happened? Even if you lost 1 cell in the Electric battery, I would think the car would still run under the remaining power.. but perhaps poorly.
I'm sure we would all like to get as much info as possible on this failure.
I bought a little (4" high) bottle of eyeglasses cleaner spray, and keep that and a minipak of Kleenex in the glove box. The wipes someone mentioned are probably a bit simpler to use.
I am looking to buy a used Prius and needed to know if there are any model years that I need to stay away from due to problems. Thanks for you help. ricklo
The current generation seems to have no issues at all. Not to sure about the first model. But why used? Many are selling used for as much as a new one or more. Heck I'll sell you my 07 that has 30,000 miles for what I paid for it, and I know here in California I can get more that I paid for it right now.
With nearly 80K miles on an '04 Prius I'd say ..."Good Luck finding a used Prius (2nd Generation '04-08). I can't see buying an '03 or older unless it was at a great price. As with the other comment, I'd say ...put down a down-payment on a new one and wait for delivery. Used ones are going for premium prices (when you can find em).This last dollar in gas increase to over 4 bucks has made Prius owners one up on everyone else as I see it. I've saved in access of $10,000.00 in 4 plus yrs over a V8 sedan that averaged about 16 mpg. By the way...I've seen a few used (damaged Prius) on ebay and/or auto finder listings, that could be a handman's special and save mega bucks if you're good at auto repair. Lastly...It might not be a bad idea to wait a few months and get an '09 Prius with what ever it may hold in styling and tech. improvements. Railroadjames
Ginny, I would put that car on E-bay with a reserve of what you paid for the car. Here in Los Angeles I'm seeing used 07's selling for $30,000. As much as I love my Prius I'm thinking it is time to sell it. The $8,000 more that I paid for it buys a lot of gas in a Honda Civic. Let me know what you get for it if you sell.
I have an '07 Prius with 13000 mi. A little quirk developed a couple of wks ago. If I go over a big bump there's a good chance my "Audio" screen will change to the "Consumption" screen ! I have also noticed... but not recently... a radio channel can also change over a big bump in the road ... this only happened once or twice...but my driveway has a large dip where it joins the street and if I'm not going v-e-r-y slow that screen jumps to "Consumption"! Anyboby have any ideas on this ? A friend suggests something may be loose (?)....thanks
Consumer Reports showed the '03 Prius (last year of the first generation Prius) as having a lot of reported electrical problems. I have an '08, myself. The current version, of which the '08 is the last one, is rated very high in every category by Consumers, and in fact is their most-recommended family sedan!
OK, OK, it appears Prius owners are completely happy with their cars! I get it. I have read through nearly all the replys to this "Prius owners with 50K miles" posting. Isn't there ANY Prius owner who have had problems with their big Hybrid batteries?
I own a 2003 Honda Civic Hybrid. The "Integrated Motor Assist" battery had to be replaced after only 60K miles. Of course this was covered under warranty by Honda. However, the next replacement will have to be covered by my at a cost of $2000.00!! In addition to this I have had the car in to the dealer for at least a dozen other warranty repairs. Also, the local dealer is quite inept at repairs and needs to do them multiple times to get them correct.
Anyway, I really like the idea of a Hybrid car and I would like to replace my Civic Hybrid with one of Toyota's Hybrids, but I'm skeptical about Hybrid reliability, etc from the bad experience with the Civic Hybrid. I'm wondering why Toyota's Hybrid batteries seem to last longer than Honda's. They are the same Nickel Metal Hydride type of battery.
I bought mine used. It's actually worth more than I bought it for now, which is unheard of for a used vehicle.
It's a 2004 model with about 65K on it. When we bought it last year, it had about 40K. So you can see that we're big drivers.
What I've seen is that get's much worse gas mileage in the winter than in the summer. Not that it's bad. I get between 40 and 45 mpg during the winter and between 55 and 60 mpg in the summer time between fill-ups. This is probably because the car has to take longer to warm up and Utah puts ethanol in the gasoline during the winter to cut down on greenhouse gases while we have the inversion layer in the Utah and Salt Lake valleys. I suspect that the ethanol is about half the reason for the dramatic drop in mpg. Then again, short trips really kill the mileage because the car never gets a chance to warm and it continually tries to warm up every time you turn it on, wasting gas (which drives me nuts).
Everything else is great but I think that if the warm-up period were more efficient, it would greatly increase the efficiency of the system as a whole.
The only maintenance I've had to do on the car is that I accidentally put the wrong kind of coolant in the system and had to have it flushed -- very expensive.
I've also replaced in the cabin air filter, also more expensive that I like. Let's just say it cost more than the $5 I wanted to spend, but when it's full of leaves and dust, you kind of have to think it might be a must. No, the thing was $25 -- not expensive but way over priced for some fibers and plastic.
As for the person who has only changed their air filter for the engine air intake, not changing that regularly can shorten your vehicles life due to increased stress on the system. Since the Prius only needs an oil change every 5,000 miles, you should check your air filter every time you change your oil. Still, I need to consult my manual about what routine maintenance I'm due for, particularly how often I should change the air filter.
One piece of advice for saving just a little more on gas, keep your tank full. Then you'll only pay the higher prices to top off your tank. It's a difference of paying extra $.05 more for 2 to 4 gallons instead of 7 to 10 gallons.
It could be that you were just very unlucky to need a replacement battery. It's also possible that Toyota is able to do a better job of keeping the battery charge level within the range that promotes long battery life.
I've never really considered this before but Toyota have the ability to charge the battery almost any time they want to whereas, as far as I'm aware, Honda only charges the battery with energy recaptured from braking/deceleration. It's also reasonable to assume though that if Honda has a battery at or near the lower limit of charge they won't call on it to deliver power.
I feel your pain and fully appreciate your frustration with honda.
I had a 2006 Pilot that was in the shop 11 times in the first 5 month. That vehicle was a major piece of crap. i have talked to others who also had multiple problems with Pilots.
Somehow I think honda bribes consumer reports for reviews and statistics that are significantly better than reality.
My Prius touring edition should arrive next week. Not sure what color it will be as long as it is black or silver I am okay with it.
I know many Prius owners who like everything about their cars except tire wear (also voiced in these forums). The touring edition has different suspension and 16 inch wheels. I am hoping that will make a difference in tire wear. The touring model does come with performance tires which probably will not wear well but that will be temporary.
The good year tires that are on the regular Prius are not particularly good tires. The same model tire was on my pilot.
The OEM tires are garbage. Mine are gone at 30,000 miles. Planning on getting a set of Michelin Hydroedge tires. They are expensive but are the best for the Prius.
I have the HyroEdge tires on my Prius. They are superb. I originally bought them (at Costco) for our 2005 Corolla and liked them so much, I had the dealer switch them to our new 2008 Prius when we bought it. They were too good to let go on the Corolla (which has the exact same size tires). I will replace them with another set of HydroEdge when they eventually wear out. The original equipment Goodyears, however, did quite well on our Corolla, but as you say, Prius seems to be hard on tires, so not so great on Prius. Can you believe the above-market prices being gotten for Prius's right now?? I just saw a price for a 2007 Prius at a Portland, Oregon Cadillac dealer for $28,995. Incredible.
I can't belive what the used Prius are selling for. I'm tempted to sell mine on E-bay to see what I can get and just buy a small used car for now. I just wish that I did not love my car so much or I would.
That's the exact temptation I wrestle with these days. My wife won't let me, though, and it's probably for the best in the long run. I hope that the scarcity of available Prii on the open market won't turn into higher theft (and insurance) rates for us. Another thing: there is always the possibility of war with Iran in the near future. Israel is looking like it's going to attack Iran if we won't and the Israeli Prime Minister has said that "Bush is going to do something" before the end of his (Bush's) term. Hmm. Any major upset in the Middle East and you know what happens to the price of oil - I think I'll squash any further thoughts about selling my Prius for a quick profit. Could be the mistake of the century.
That is what I go back and forth with. With what is going on in the world gas could get much higher and real fast. Then I have the motorhome that gets 11MPG and I offset that with my Prius! What I really want is the next generation with the new battery pack and plug in, would not even mind seeing a diesel Prius as a plug in. Maybe we can get in the 80 MPG range with diesel and a plug in.
I am plenty happy with the headroom and elbow room in my Prius Touring model - even with two big 200lb boys. Where the car falls short is in the seats. I take my Prius on long drives and it saves me a ton of money, but the seats are not very supportive for long rides - I like my seats stiff, like in my last car, a VW Golf. Any ideas how I might bolster the seats? Any of the standard aftermarket products any good?
K&N company (www.kandn.com) claims its air filters enhance power and improve gas mileage, and are guaranteed for life. Does anyone have any experience with K&N products?
I've been waiting 3 years for the next version. Good thing I have a 2004 so I can wait. Toyota is struggling with the Li-ion batteries. Since I live in the mountains, my wish list also includes and electric turbo and 4WD like the Highlander. The plug in feature only helps if most of your driving is real short trips. I can't see how they can get the electric range beyond 5 miles. Right now in EV mode I can go 1/4-1/2 mile max before the ICE comes on. Battery improvements would have to be 10 fold, with some programming changes to make it practical for around town use battery only use. Not likely soon. Maybe 3 years. Don't believe McCain, Clinton, Greenspan, Gore. They don't have a clue. Read Amory Lovins of the Rocky Mountain Institute. He knows what's possible and when.
Purchased a Touring Prius in April ("Preferenced/Ordered it just before things got crazy with the 2-3 month waiting lists) Took a month but got the color and style we wanted. The dealer has some visibility as to whats coming off the production line in JPN.
Findings: Live in Denver area and are in the Mtns every weekend. 2 adults in front, 2-70lb dogs and a beagle in the back seat. Built a carpeted/wooden platform for dogs in back seat & works great. Story tons of "stuff" in the hatch area & feet area of back seat. This car is replacing a Ford Explorer. while it obviously doesn't do all the Explorer does, with a few mods and a bit of packing planning it is exceeding our expectations and costing 75% less in gas.
It doesn't set any speed records climbing the mtns but it actually does quite well. Engine & CVT transmission revs pretty high sometimes but other than that its just fine climbing.
Weekend Mtn trips - 200 -miles RT - Car averages 39MPG up and 55MPG down. Sometimes at Hwy Speeds on slight downhill grade, a soft foot will find the engine running on Battery only & keeping speeds up. (round trip avg btwn 44 - 47 mpg car fully loaded sometimes AC running) Driving style makes a HUGE difference in MPG. Heavy foot = 35 - 39 MPG around town. Lite foot = 44-50 Mpg.
Options & suggestions: Got option #2, added after market (front)HEATED, leather(front & back) seats thru dealer for $1500. More colors to choose from vs Toyota and didn't have to take Opt 6 to get leather. (Toyota doesn't seem to offer heated seats in Prius) Thru dealer seats are covered under warranty. Added Clear Bra thru dealer - $200. Strongly recommend it. DIY Options - Mud Flaps & 2" receiver/trailer hitch for Bike rack. (Both very easy to install & from Coastal Tech), clear Plastic headlight protectors. (prevents rock chips from pitting or cracking expensive headlight lenses), rubber honey comb cargo area mat. Keeps dirt & grime away. Costo Rubber Floor mats. Tinted Windows - first time to have them and love them. With all that glass area the tint makes a huge difference in keeping the suns heat out. Cost - ~$200. Tires- Spoke with local chain tire store have been using for years & trust them- they suggested when tires need replacing going with 205/55/16's. More choices than the stock 195/55/16's & lower cost too. the 205's are only about 1/3" wider & will fit and minimal/ possibly no hit on MPG. We love the car, no complaints yet after 4000 miles....
Our Prius has over 80K miles and we too have little to complain about and much to praise. Our '04 Prius has been exceedingly trouble free with only a slight problem with replacement (3 times) of Hd lt bulbs that are stinkers to get to let alone switch. We too have 2 large dogs (1-100lbs & 1-70lbs). We found useing a fitted twin size bed cover for the dogs to lay on w/ the Rr seats in down position works excellent because the fitted corners stay @ corners of seats & Rr corners of the Rr mat. As to care of the car and many of the things you felt to address I would only add that I highly recommend "Wheel Alignment" at 35K to 40K. It preserves the tread a great deal. I know this to be true since this was learned the hard way. It's $$$ well spent just like frequent oil changes.
Just read your posting, RR James. Thanks for the tip about wheel alignment @ 35-40k. I know fast tire wear can be an issue with these great cars. (Why is that, by the way?) The twin fitted sheet I will remember, but our dogs don't like riding in the car for some strange reason!?
Dear Rick294, I am not entirely sure why the tires wear so quickly other than to point to the Tread Wear Rating number of only 260.... ie. not long lasting Tread wear.
Sorry for not getting back to you sooner but....Grandpas gotta lot to do these days. About the tire wear: I'm not sure there's a complete answer to the issue. Not everybody got the same brand and then there's the issue 'bout tire air pressure...Recommended tire pressure is quite high and some owners fail to keep tires @ the right level. As I pointed out, the problem with Alignment can be a serious factor as to tire wear. I got 51K on my "OEM" tires and then only 22K when I came to realize I had an "alignment" problem that led to new tires again.
It could be that I have mistaken the tread wear number on the OEM Prius tires. The same Goodyear Integrity tires on the 05 Corolla we had were rated at 460. Bubkis says his are 260. I did see that low of a figure on some Scion Goodyear tires before we decided to go with Prius. I had never seen a treadwear figure that low before. Pays to take a closer look, apparently. I'm unhappy that Toyota would put that low quality of tire on their products. Disappointing.
Rick294 be sure that they are exactly the same tires. The Prius OEM tires are V rated which typically means "higher quality" softer compound with stiffer sidewalls, faster speeds (Corvette speeds) (and lower Treadwear) Why they put them on Prius is unknown to me....
Check out tirerack.com for the specs on the Prius OEM tires. The UTQG # is 260 for this tire.
195/55VR16 Load Index 86 = 1168lbs (530kg) per tire Speed Rating “V” = 149mph (240kph) 86V SL Treadwear: 260 Traction: A Temperature: A260 A A
That is correct. I am driving a touring prius. 16" Tires.
The 15" tires (Non touring Model) are indeed rated at 460. Based on these subjective tread wear numbers, they should last much longer than the 16" touring models. Check out tirerack.com. They have all the specs on OEM and replacement tires. Its an excellent resource including Customer reviews of tires.
I bought a used 2001 Prius in 2007 from N. Hollywood Toyota. There were a number of problems that the dealer needed to fix that were not taken care of before they sold it to me. I think I paid too much for the car and could not afford an extended warranty but the original warranty still had some time left on it.
I had problems with the car not starting periodically but they seemed to have fixed that finally. Now, though, the problem has returned and the warranty has run out. It will cost $215 dollars just to get to the problem, which seems to be with the high voltage system, according to the diagnostic. In addition, a slow break fluid leak appeared a few weeks ago and I am told that it will take 5 hours and $500 just to get to the leak area because it is so buried under other things.
Don't get me wrong, I love the car but I am disappointed with the reliability and the cost of the repairs, which I can't afford. Does anyone know if it is possible to buy an extended warranty at this late date? Also, I may need to buy a car - does anyone know of a good car broker? I don't want to make another mistake on price paid.
I understand that the early Priuses (2003 and older) did have some problems here and there. For brokers, check the Yellow Pages under Automobile or Automotive - Brokers. Priuses, right now, are seen as gold-plated. It might pay to put out the money to get it repaired and then sell it. Last year, Priuses were popular, but this year (after gas crossed the $4 line) they are in huge demand. You didn't state what you paid for the car, but whatever it was, it likely would have been that much more this year. My suggestion would be to skip the extended warranty, get it fixed to your satisfaction and sell it. You'll have no problem selling it, I'm sure. Charge enough to get all your money back that you've put into it. Buy another small Toyota product (Echo, Yaris, Corolla) that get good gas mileage and make a deposit and put your name on a new Prius waiting list. You can always step out of the line if you want to. I understand the 2010 Prius is to arrive in January, 2009. Good luck.
Thank you very much for your suggestions. I bought the car for $17,000, thinking that the freeway stickers were worth 2K or 3K. Now I owe $14K and the car is not shown as being worth more than about $12K at best, but it has these problems which, until fixed, would make it worth less. At the moment I am bummed, but I am looking at the options and will figure out the best way to go. Thanks again.
Sarahdance, My suggestion would be to fix-er up now and sell ASAP if you're uncomfortable with the car. There is no better time to sell a Prius than when Gas prices are around $4/gal. Prius's no matter what yr, have never been in such high demand... Call a dealer and find out how long the wait list is for a new one. Last I checked in our area it was 3-4 months.
A reporter with a large financial magazine would like to speak with hybrid owners and their experiences. If you are a hybrid owner, please respond to ctalati@edmunds.com with your daytime contact information no later than Wednesday, August 6th.
So glad to share the good news that my '04 Prius is running well after a 6K trip out west. We hit the Highplains of the Dakotas, the vast mountains of Montana (Bear Tooth was amazing @ 11,000 ft) The Prius handled the climbs like a trooper. Milage was between 44-47mpgs most of the time. We went on to Glacier Nat. Parks and again not a single problem. Lastly, we went thru Bonnaville Salt Flats in Utah and the temps were over 104 degrees. I managed over 520 mile tanks of gas multiple times b/4 the last blip blinked. I TRUST THIS CAR! That's a fact! Your friend that started this site. Railroadjames
Actually well over 90K miles on the '04 Prius. A few dings and a chipped tail-light lens (compliments of a huge S.U.V.and the usual wear & tear. 2nd set of tires and only an additional "wheel alignment" (very much needed). 2 head light bulbs and a couple of chips on the windshield. Oh! Slightly dirty uphostery (never get beige again). I still think the "blue"' is the best color of choice. Best dang car ever and I've had over 50. Everybody notice how many more there are out there now?
I have an '06 with only 31k miles. Excellent car - a few paint chips courtesy of the 5 AM gravel trucks leaking stones onto the road surface. I cut a sidewall on a piece of road debris and replaced all of the tires with 205-60-15 Bridgestone Potenzas - GREAT improvement in ride and handling! Air filter and wipers are the only other changes. Great car.
Gripes: the back-up beeper (why is it on the inside?), having to start the car to open & close windows, overly complex controls (hard to see in bright sunlight, hard to hit the right "touch" spots on bumpy roads or in traffic), headlights are almost impossible to replace if you have big hands ... that's about it.
Hint: ultrabright bulbs will not last in a Prius.
Al in all ... best vehicle I've ever owned for reliability, utility, and economy.
Thx
sc
Railroadjames
What mountains do you live in?
http://www.tirerack.com/tires/Spec.jsp?make=Bridgestone&model=Turanza+EL400-02&p- artnum=955VR6EL40002&vehicleSearch=true&fromCompare1=yes&place=18
195/55VR16
Traction: A
