Infiniti G35 Climate Control Questions and Issues
My 04 G35 ac is swithiching from recycle mode to vent mode. I have had at the delaership several times an they seem to be dumbfounded. They have replace the open winding, auto control panel and ac controller. This switch happens within 15 minutes of driving. Any suggestions would be greatly appreciated. Anyone else experience a similaar issue?
I've learned that it's necessary to press the vent/recirc button a couple of times to be sure it's been properly manually overridden into the recirc position. But I don't believe this is normal for any vehicle, let alone a vehicle this technically sophisticated.
When I had it in for maintenance at the Infiniti dealer a couple of months ago the technician had no idea what to do or suggest. Is anyone else having this issue or know if there's a computer upgrade available to fix? :confuse:
What was the outside temperature? I think if the outside temperature is about the same as in your car, this A/C might just change to fresh air so it doesn't need to run the a/c?
However, it's not a matter of that. To clarify, it's not that the AC is turning off - it's that the system is choosing vent instead of recirc while in AC mode. The AC never switches off by itself.
An additional problem that I should mention is that there is no way to run just the fan (AC off) in recirc mode. The system won't allow it. With just the fan on, as soon as I hit recirc, the AC is turned on. There are plenty of times when I'd like to do this (when humidity is not an issue) but it won't allow it. In all other cars I've owned (even ones with "Auto Temp Control"), many of them Nissan's, I've always been able to do this.
I use fresh air without the A/C during the cooler months just to get fresh air in but still use the recirc button if behind some smoke dumping car or something.
It stays where I put it, unless I play with the mode button.
(floor, defrost, vent, etc.)
It's just that the ac won't stay on recirculation, it will randomly switch back to fresh air, mostly at the worst times such as behind a bus with diesel fumes.
Mine is an 03, it never did this for the first two years but since 05 it's been constant. Any infiniti loaner they give me doesn't do it.
I didn't know about setting the mode by holding the button, but I did try that before as I thought it might be similar to programming a button on the radio. So I held the recirc button down for a while and later in my drive it started switching to fresh air again.
Thanks for your help.
