Grand Marquis starting nightmare
in Mercury
I have a 1996 Grand Marquis. It has 56,000 original miles and has
developed a problem that 3 different mechanics cannot figure out. I bought
the car in August of 2006 and it ran great and looked like new. All was
well until the temperature dropped below 30 degrees. The car would start
then immediately stall, but on the second try would run great. This was
not a big problem, but did not want it to get worse so I took a garage and
they told me it needed new plugs and wires and to replace the air intake
control valve. Well the next day it was the same so I called the garage
and told them and they said they would check it out. They said that maybe
it was the wrong plugs so they put in the OEM recommended brand, but also
free of charge the replace the water temp sensor. That is when the fun
began. The next day it took me 10 minutes almost a dead battery and
finally starting fluid to get the car started. I have since had replace
the mass flow valve, fuel filter, another temp sensor, oxygen sensor, and
thermostat and nothing helps and paid out over $1,000 so far. Please let
me know what to do as if I can get it started and even to get it to stay
running for the distance of 2 blocks after that it runs great,. Now one of
the mechanics suggested a fuel pump and that will cost me over $400 and
not sure if it will help.
If they didn't, they should because they seem to be guessing. Otherwise, you will have to take it to a Mercury dealer service. Some shops are connected to on online database which, once the codes are obtained, it tells them where the problem is. I believe Auto Zone diagnoses engine problems that way.
Plugs, Wires, Distributor, Relay to Distributor, Ignition Coil, Battery {twice}.
This started two weeks ago. Some days it starts no problem; yesterday, today is a different story . . . .NOTHING. I ran the battery down then began all over again . . . NOTHIN'. I'm at my wits end and need someone to come along side and "PLEASE HELP". Your assistance is well appreciated. Thank You, walar2007.
If it does you should try replacing it.
Also, having read that these 96s have had a plastic intake manifold problem, please tell me how that is detected before I get this problem as well. I am an elderly myself and already dissappointed in my local Ford dealership. Have a couple of good mechanics who have been laid off but would like to know something of the problems myself before I even talk to one of them.
there's a list of what i've done in an attempt to fix the problem:
replaced all fuses, circuit breakers and relays
replaced the starter (thinking the soleniod could be the problem)
replaced the alternator many times (on the 3rd one since april)
added several ground straps
added new wire directly from alternator to battery, removing the existing wire from alternator to starter (i have read the this wire is a fusable link)
replaced sepentine belt ( this made the problem worse)
replaced the battery twice ( just a few days ago - car great great for about 50 miles)
opened and cleaned every connector i can find
cleaning the connectors had the car run good for almost a week. a second cleaning had not effect
i desperation i went to my local mechanic ( i worked for him many years ago). he had the car for a day, told me it was fixed (the stator wire connection) charged me 40 bucks. as soon as i drove away it acted up again. his opinion is to rebuild the alternator though him or "keep going to advance. sooner or later you will get a good one from them"
i had advance check the alternator on the car. voltage high 15's - 75 amps, battery was good but low on charge(this prompted me to replace the battery a week ago)
they replaced the alternator. made no difference in the problem.
i called ford and even discussed the problem with a local ford dealer's service manager but they were of no help. they claim they have never heard of any cars with this problem. i just cannot bring myself to take this to the dealer.
so, can ANYONE out there help me? i am at my wit's end and really dread the thought of turing this over to a dealer.
thanks everyone
I have a 1997 Mercury Grand Marquis that has the same extact issue!
As for the speedometer, a few years ago I noticed that my needle was hesitating and then jumping up and around. Some time later, my odometer quit working, but my speedometer still works and no longer jumps. I took this as a sign that a gear inside the dash unit that drives the odometer had failed, temporarily interfering with the other gears. I have not had it fixed but I imagine that removal of the speedometer assembly and replacing the gear would be necessary. I don't know about the smoke situation but I also had a heater core failure that causes leakage of fluid inside the cab and produces a filmy smoke that gums up the windshield and stinks. Since I live in Florida, I just disconnected the heater hoses to the engine and plugged the connections on the motor. Hope this is of some help to you.
Also, the check engine light is constantly going on. That is my biggist issue here... as in the State of NJ, your car won't pass inspection if the check engine light is on - even if the car passes emissions. Last time I had to go pay to have the computer reset right before I take it to the inspection station.
I love my car. It suits my needs and is in great condition, except for this fact. If I get the computer replaced, will it stop this whole crazy thing? If so, can anyone tell me about how much it costs to have the computer replaced? I've tried to find out - but can't seem to find the answer.
