Volkswagen Eurovan DIY Tips
Claires
Member Posts: 1,222
in Volkswagen
This is the place to share tips for performing your own maintenance and repairs on your Eurovan.
This forum is great!
hopefully uj
Download the Eurovan parts list and search for the "Shock Absorber Guide" at the end of the parts list.
Thanks you
I'm assuming you're pushing the button to down shift, the eurovan transmission actually locks the shifter when pushing the button to down shift. So don't, and just shift down. Why it is different than other manufacturers transmissions, I don't know.
Instruction.pdf
instruction.pdf
There is only the plug to disconnect for the switch, thats all.
It took me 30 minutes to do it, and I'm not a mechanic.
I simply can not open it to replace the latch. The panel is alresdy off so I could reach most of it from the inside. HELP. I use the van for work so it is a little abused but I still call it my baby.
http://www.carspace.com/guides/Ignition-Switch-replacement
If you have any questions, feel free to ask me.
JB
Is this a bad thing? Is it something that needs to/can be fixed? Does this phenomenon have a specific name? Any input would be greatly appreciated.
Good luck!
Now I have to fix the power locks. Any else having problems with them. Already swapped out the lock Actuator on the drivers side but it didnt fix the problem.
problem is you push he door lock button on the key and all the locks close (except drivers) then open up again immediately.
any ideas appreciated
Someone suggested frayed bad wires in the loom where they go through from the door to the chassis, Mine look fine??
did you get any answers??
Im toying with the idea of writing to VW as I know this is a common problem.
You can just pull fuse # 11 on the bottom row to get manual control back
Mike
Ralph
I am having difficulty removing the ignition lock cylinder. The symptom we are experiencing is the key will turn, but the car will not start. It seems to not be able to make a connection. When you pull the key out the electrical systems stay on in the dash board, like the battery light, and other warning lights which stay on when the car is not running. I have taken the steering wheel covers off, but the screws that need to be removed to replace the cylinder are specialty 3 pronged heads which a phillips will not fit.
I have also disconnected the battery so as not to run it down.
Thank you,
jcolombo86
Go here for more information on how to change it.
Ignition switch replacement
Good luck
Thank you for your response and guidance. Just to make sure I understand it is your suggestion to start with the ignition switch first? The symptom we are experiencing with the ignition is it will not start the van (of course), when we pull the key out the dash lights stay on, and there is no feeling any longer of resistance when turning the key.
Your pictures are extremely helpful and if I am to do the replacement, do I need to take the steering wheel off, or other parts of the dash?
Thank you very much.
DO NOT REMOVE THE STEERING WHEEL! AND BE CAREFULL AROUND IT, THERE IS THE AIRBAG AND YOU DON'T WAN'T IT TO GO OFF! :sick:
If you don't feel resistance in the ignition lock, it can be the lock too. hard to diagnose over the net. But the switch is around 10 bucks, so start with the cheapest part. If the lock cylinder is worn, you probably won't be able to replace it yourself. As you will need the proper cylinder, that can only be purchased trough the dealership (Anti theft device reasons) plus you will need special tools. Normally the cylinder can be set to your key, so you won't have a different key to start your car. Had to do this on my rear hatch, as someone tried to brake in an broke the lock.
Good luck
Check out your local paper for cheap Eurovans or Transporters with manual gearboxes for sale. It may seem like an expensive option but putting another crap automatic is just flushing your money down the loo.
