Chevrolet Malibu Interior
I'm looking to replace the piece of silver trim that runs across the passenger-side dash since mine's a little scratched up. Does anyone know how difficult/easy it is to remove the trim? I'd also appreciate any tips on finding a replacement and removing the old one.
This is the redesigned Malibu (not the Classic style).
Thanks in advance.
Thanks in advance.
One question--believe it or not, I've never actually owned a car with an antenna before (my Intrigue and my old Alero had integrated antennas on the rear window). Do you have to remove the antenna before bringing it through the wash?
Yates does a nice job--I just wish it wasn't so pricey. I can't afford to bring it there too often!
I always thought that Yates was a good value...its just I don't always want to spend $15 on a car wash! I do the Armor All myself too though...
Maybe I will see you there sometime. Ours is a Navy Blue Metallic LS with 1sb. Currently working on mile 200...
I have an 04 Galaxy Silver Maxx, just 10 days old and I want to avoid the "spiderweb" appearance that I had on previous cars. If you can suggest any particular type of wash & sponge or mitt that will prevent scratching and similar problems, I'd appreciate it.
Use a detergent made for washing automobiles--dishwasher soap is to harsh, and will remove wax. I prefer 100% cotton terry cloth for the soap application, and the Detailers Preference microfiber car towels for drying. Both are available at Costco, as is car wash soap.
Flood the panel as you wipe the area. This will rinse away the dirt as you lift it from the surface, and prevents scratches.
For wax, call Maguiers on their 800 number and ask what they recommend--they make waxes for specific tasks, finishes, and weather areas.
I'm planning on having clear vinyl hood & headlight protectors installed, along with a piece on the liftgate where you push the gate down. It will help prevent some rock chips on the front, and scratching the gate as you pull it down. Here is a link:
http://www.invinca-shield.com/asp/genkit.asp?kit=641
MadMaxx
'04 Galaxy Silver Maxx, 22 days old.
Thoughts and suggestions would be greatly appreciated!
There's very little abrasiveness to this compound, which is applied with a soft towel, allowed to dry for around 10 - 20 minutes, and wiped off. Wiping off is easy save you have to turn the towel a lot to avoid buildup and "dragging".
The stuff lasts longer than any wax I have used; around 3 - 4 months - and definitely helps keep bugs from sticking. Don't use it on rough black plastic, though, as it can leave a white haze behind.
The plastic handle on my shifter has become wobbly and can be lifted up a good distance (I don't force it as I'd probably break the wires going to the handle controller).
Anyone had to deal with this? Any fixes come to mind, plz?
For those who are having the same problem, the trick is to pull down the plastic "pyramid" just below the main shift handle to expose this allenhead screw facing the rear window, tighten it, then push the plastic pyramid back up so it meets the handle once again.
Hope i am posting in the right area. I was wondering - with light color fabric on my 05 Malibu seats, the seats will probably get pretty dirty soon. Anybody come across decent washable covers for those seats ?
Yury
where did you get them from ?
that's good, however my seats are rather light in color, and i already hase minor stains that are visible. nothing out of the ordinary, but if i had a decent washable cover that'd make life a bit easier.
i ordered some on ebay, hope they will turn out ok.
It's marketed as headlight and lens polish.
Still, I'd appreciate any info about replacing the trim in case the scratch remover isn't enough. I was also curious as to the price I might expect to pay for the part from a junkyard or something.
Thanks again!
it is an eBay listing for a iPod adapter for this generation of Malibus complete with installation instructions. Scroll down to see the dash part of the instructions, looks like the first few steps are what you will need to do.
Again, if anyone has other info they can share, I'm happy to get all the help I can.
you want those long horizontal silver panels removed, right ?
I figure it's not too complicated, but I also don't want to damage the part. I tried removing it earlier today, but I couldn't see any obvious clips. The piece was beginning to flex, but I didn't want to force it without knowing that that's the way to do it.
I have a low mileage 05 LS. There's a fair bit of squeaking coming from the dashboard when I drive over bumps. Also as of yesterday the driver's seat developed a squeaking sound when I press against the back.
Any thoughts on the subject ? The silver panel on the dash seems to be producing most of the sounds.
If so, inserting small pieces of foam into some openings between the parts might help get rid of the sound. (I know, a trivial advice and you've likely thought of it :-)).
The dashboard squeaks only in cold weather ,rubber edging is rubbing against the glass, goes away when the temp goes above -5C.
thanks.
btw, i noticed the glass squeaking then cold, but i think the long silver panel squeaks as well in temps way abowe -5C.
