Mazda Millenia EGR problem
I have had an EGR problem with my 1999 Mazda Millennia since the first week a I had purchased it in 2002. They replaced the EGR valve and knock sensor multiple times. They even drilled bigger holes in the engine and my engine light continues to remain on. Now the engine light is blinking. Any suggestions? The dealership where I have been taking it to told me to ignore the light. The only thing is $3000.00 later I have the same problem but now can not drive it because the light is blinking. The dealership told me now I have to replace a part that is going to cost around 2600.00 just for the part. Please help with any advise!!! I can not trade it in or drive it!
But we'll wait to see if someone here can help as well.
Thanks for your help
and have more test perform. and possible an EPA issue.
The last diagnostic code P0431 if anyone can help does this code mean I need a converter or pre cat? and what web site I can find a pre -cat and price.I don't want to trade the car looking to move into another house don't want another bill.If this continue I might not have any choice but to trade.I went to three independent dealer and was told to replace the cat converter,but the mazda dealer stated that I need pre-cat talk about confusion.Need help
2. P0420 code cat convertor
3.Replace fron and middle converter code reset
4.P0431 code appears again
5.replace both cat convertor CEL still on
6.TSB on both 02 sensor
7.02 sensor replace CEL still on
8. Pass emission in 06
9.Diagnostic perform from 3 other dealer Cat code
10.Tenn Dept of Safety State emission analyzer code P0431
11. Mazda Dealer might need pre-cat due to Codes P0431
12.EGR Valve clean
Jazzyman
(note, this is a completely different problem from the previous one I just posted- I felt that if I was asking, I might give something back)
Apparently this car has a history of a faulty computer that turns the TCS off light on when it shouldn't. So the TCS off light is misleading. It has nothing to do with the TCS - it's emissions. Removing the sensor has solved the problem on 4 others that I know of. Happy driving!
have been driving with the Check Eng Light on for almost a year. Recently it started to blink. took it in to Firestone for Diag; they told me i have PO-431 Ignition coil #4 mised fire and typical O2 sensor issue. I plan to chang my spark plug this weekend. Don't spend money on O2 and anything more than a Thousand dollars repair just ignord it as long you have AAA just drive this car and have a good time - I really like this car but have no intention to upkeep it,
cars are losing proporsition from day one.
just gas and zoom.
go to Pepboys they sell it for $149, $90 installation.
replace the spark plug yourself but i think you can only
buy the distributor cap from the dealers.
Diag at Firestone is about $59 but i believe you can get a free one from PeppBoys.
I"m considering buying two universal catalyic converter instead of going to the dealer paying $ 2000.00 can this be done or do I have to go to the dealer?If anyone
that have the same issue and use universal catalyic let me know please before I spend the money and what brand is best for universal converter Eastern or Magnflow
1) Replace air filter--K&N hi-perf filter runs about $65 and is worth it-
2) double check battery posts/connections---clean/replace as necessary-
NO check engine light should BLINK and that may indicate a screwed up computer---very expensive!! Last resort-
Since you have the supercharged model, it's possible that you have too much boost---as nice as it is, the boost just uses up more gas and, let's be realistic here, it's not going to walk away from a BMW M3 or Porsche, so turn the boost down and see if that clears the indicator----you know that you can turn the light off by simply disconnecting the battery, right? (have to reset all your stereo channels--bummer) BUT IF YOU CLEAN UP THE BATTERY POSTS WHILE YOUR AT IT, IT'S WORTH THE EFFORT--
code reader may be also worth the $300----good luck and aloha, Mike in Kaneohe
p0301 & p0170 & p1522
i have already changed the cyl#1 spark plug(to fix #p0301)
i had the mechanic do an injector cleaning
i closed the screw on the idle and it would not adjust, it remains @ 800 rpm
Can someone plz help me and give me an idea as to what i have to do for these problems. Hopefully someone knowledable can assist.
You are welcome to get me at lifeofreilly@hawaii.rr.com rather than the forum---either way!!!
Aloha, Mike
Thank you so very much, my hubby finally fell asleep... has insomnia trying to get the car in working order..
It's people LIKE YOU (helping others) that make this a Better World! :-)
with the economy the way it is and our personal crisis; we gotta fix and cannot buy!!
he will probably have me email you again tomorrow if that's ok with you....
we are in Florida!!! The Atlantic Hawaii.......
Aloha
Ada & Angel
asing123@gmail.com
so replacing the sparks and wires will take care of the p0301 issue,
what shall we do about p0701 (leak?)maf sensor?
and lastly, the p1522 ??? check wiring on solenoid? where are they located?
Be Blessed
Could the gas line be froze?? Battery issue?? or Electrical??
Car idles perfectly but when put into drive, it reaches approx 2000 rmp the engine bogs down and doesn't allow me to speed up, going up hills is worst most of the time i end up slowing down. Mazda did some work on it then suggested it was the supercharger... Fail... I purchased a used supercharger and after the swap out the problem is exactly the same.. So to add to the mess, I attached a diagnostic computer to my car which I have done plenty of times before... except now when I unplug the cord (specifically the cord) from my car. It stalls out and will not turn back on until at least the cord is plugged back in. Iv tried all forms of plugging it in and out with and without a battery no luck
When the car bogs down... sounds like its missing, with a crackling noise.
Don't get me wrong, I'm pleased that I've gotten this many miles out of the car. However, one should also expect to be somewhat free of a car from getting a CEL so frequently. I've done everything possible to cure my P0400 (Generic EGR Malfunction) code to completely go away and it did for about 30 days over a 3-year period, which was long enough for me to get my emissions inspection passed for the next 2 years (I have about 10 months left to go) and then I'll need another emissions inspection, but I doubt if I'll be dropping big bucks into the car so it will pass. I'm very fortunate that I can do 90% of the work on the vehicle myself. To date, here's all that's been done to try to resolve the EGR (P0400) issue:
1) Cleaned the EGR valve of carbon.
2) Cleaned out the EGR chambers in the intake manifold.
3) Cleaned out the two "snake eyes" that hide behind the intake butterfly valve.
4) Replaced all of my vacuum lines (about 25 feet, total)
5) Replaced the 2 solenoids for the EGR system (Vent and Vacuum solenoids).
6) Had the BG EGR process performed ($250.00 at a shop).
7) I removed the intake manifold and took it to a machine shop to have it dipped int their
parts cleaner tank and then pressure sprayed to clean out any carbon.
8) I replaced the EGR valve with a know used working one.
9) Re-installed the intake manifold, but the EGR issues didn't disappear.
10) I took it to a shop to have them look into the issue further. They claimed I needed to have my EGR valve replaced. ($750.00 in parts and labor).
11) I was happy that the issue seemed to be finally resolved, right? Wrong! I had my car inspected for emissions and it passed. Then, a week later, the CEL light was back on. It's been that way for the past 14 months as I really don't want to work anymore on the P0400 code. It's impossible to cure on my car. I don't think throwing more cash into it is the answer ... only to get frustrated.
I don't see myself buying another Mazda product in the future. A bit too expensive to get parts for - if you can find them. Currently, it appears the front pre-cat is no longer on the market unless you go to the dealership and buy it. The rear pre-cat is available from about 2 or 3 other 3rd party manufacturers.
The EGR valve costs $400 at the dealership and is about $300 from Mazda discount parts places on the Internet. When I had my Ford Taurus, the most I ever paid for an EGR valve was about $65.00.
Greetings. If I could ask more specifically - which component is the EGR sensor on the Millenia? I've checked my replaced solenoids for the EGR (Vent and Vacuum) and they are within spec in regards to Ohms.
I suspect, though, what you're referring to on the Millenia might be what they call the MAP sensor. That is a device, mounted to the back of the engine on the firewall and has one vacuum tube running to it. I believe most of the MAP sensors that I've seen on Millenias were made by Mitsubishi.
I should probably spend a Saturday morning going to a "Pick and Pay" junk yard to collect some items for potential replacement. Though, there is always the risk of getting a part that's no better than the one you're trying to replace.
This past weekend, I did buy an universal DC power adapter, though. Using that with my Millenia service guide, some aligator clips and spare vaccum hose, I'm going to follow through with the proper test procedures to determine if the sensors and solenoids are all operating properly when a load is applied to them. This will keep my from buying an endless supply of parts that might not need replacing.
I was continuing doing some research and it looks like the GAS CAP...yeah... The Old Gas Cap is not hold the correct vapor pressure and its making the EGR Sensor to activate the signal...
So I want to a Auto ZONE and bought a new $10.00 GAS CAP, after few hours, the CEL went off.. Im loving my car again.
I've also been reading that this did't work with some cheap gas caps and some of the guys with the same problem were forced to buy the original gas cap from mazda $125.00 but it did fixed the problem just by replacing it.
I wish I knew this very long time ago, because I've been paying under the table to get my Emission Inspection Passed.
I hope this works for you.
With that being said, I hit 165,000 miles on my Millenia about a month ago. I was kind of getting to the point of feeling a bit frustrated with many weekends of having the hood up on my car to get things situated - oil leaks, valve cover gaskets, etc. So, I was able to buy myself a newer Buick LaCrosse. I posted my Milly on Craigslist for $1,200 and it sold within 10 minutes of being posted.
I liked our Millenia a lot, but locating parts was becoming harder as time passed. Also, the dealership doesn't charge $125+ for a gas cap. I believe that it's somewhere in the range of only $25.00. However, if you buy from tascaparts.com - the Millenia parts are discounted and I think their price for the replacement cap was only about $18.00. I'm not affiliated with them in any way, but have been very happy with their prices and service when I needed them for my true / authentic Mazda parts.
Enjoy!
However, the benefit in using the "true" Mazda cap is that you can continue to use the tether, if you like that feature. Some people who don't have a good memory will leave the gas station with their gas cap still sitting on top of the pumps.
