Pontiac G6 Engine
                    i have a 2007 pontiac g6 and on my engine it reads ecotech.  My car was 19,000 and its a sedan but my problem do i have the engine with 200 or 162 horsepower?????its a 4 door if that helps
Gas mileage is not crucial if the difference between the two engines is less than 5 MPG. Which engine is more reliable? Should I go for the 6 cylinder engine or save a few bucks and go for the 4 cylinder?
If you think the dealer is incorrect, find an independent shop with a decent reputation and have then do a quick analysys. That should answer your question...
Should not exceed 15 psi, cap setting.
