Mazda3 Lighting & Electrical Questions
Just took delivery of a new GT on Saturday. The salesman told me that it has DRL. I can't find that it does and the only reference in the owners manual is that Canadian models have them.
I have not had a chance to contact the dealer again but was wondering if anyone here knew anything or if it is something that can be configured by the dealer. My BMW had DRL but it had to be configured by the dealer through the vehicle computer somehow.
Thanks and love the new ride!
I love my ride too!! Awesome Zoom-Zoom.
In doing some research I found a Miata thread where some owners of US models from the mid to late '90s were purchasing the Canadian DRL module for their vehicle and installing it. It would be great if someone here could provide some guidance, Nifty56 if you can tell us which lights are used it would be a great start as I am sure the module can be bought and installed fairly easily, provided the Xenon bulbs are not used for the DRL.
Stallionre, the salesman told me the same thing you mention - to turn the knob to "auto" and this was the running lights. I pointed out to him all that does is make the headlights come on at dusk. I think sometimes people are confused about what DRL is.
Making them mandatory in the US would be great, however, it would wear out the Xenon bulb faster and as high price as they are, I wouldn't want to buy them every two years.
I looked into the wiring diagram of a '05 model( not available for '07 models yet) and found only a single horn unit( many cars have dual horns). This should be a safety concern and if this is the case for every "3", then Mazda should upgrade it.......
Anyone have a suggestion?
i drive a 2003 Mazda 6
Check the manual.
Please advise what you learned about your problem
What does the Mazda dealer suggest you do? Have you thought of taking it to another Mazda dealer?
Won't even take a jump. The shop has no clue. Battery has been replaced
If it won't take a jump, does that mean you need a new battery each time it gets drained?!
mariong
I find that that statement by the dealer representative not only surprising but disturbing. You may want to write to MazdaUSA and inform them of the situation and see what they say. How old was the battery and in what condition was it? Also, it may be difficult to prove that the battery did not discharge for another reason (e.g. accidentally leaving on the overhead light switch).
I don't think Mazda or any other car company would try that, it would qualify as a form of hari kari. Batteries are one of those items in the car that you know you have to replace; but not after two weeks sitting around. The dealer representative was being disingenous and not offering a helpful answer. There are lots of reasons for a battery draining. The good news is that a battery is cheap to replace.
I agree; I leave my Mazdaspeed 3 in the garage for weeks at a time and when I finally have to drive it it has never failed to start.
It started with the "Engine" light indicator coming on. Took it to the dealer and they couldn't figure out the problem. They concluded that it was a glitch and reset the code. The next week, I left the car sitting no more than 2 days and the battery was drained. Took it in and they replaced the battery, concluding that the battery had a faulty cell.
Again, I left the car sitting for about 1 1/2 day while going out of town. Once again the battery was drained and I had to jumpstarted. My conclusion is that it is not the battery and the dealer have no clues what the issue is. Something is obviously being left on and is draining the battery.
I'm taking the car in again and will give an update soon.
Has the dealer measured the current draw when everything is shut down(key out, all doors closed)? It shouldn't be hard to isolate the problem; it takes a lot to drain a battery in 24-36 hours. Simply just start pulling fuses and relays until the current draw disappears. My son left the door open on my MS3 one night and 12 hours later it fired right up.
I've been patient but after the third battery and the problem is still there, I have to escalate the issue. I'm no auto genius but I new from the start it was not the battery. I didn't want to be a difficult customer, so I went along with their BS diagnostics. They were very relunctant about giving me a loaner car too.
I decided to take my car to the Clearlake Mazda dealer and give them a chance to resolve the issue. I explained the history of the problem and my frustration with Jeff Haas Mazda. I told them quit focusing on the battery as the culprit and put the focus elsewhere. Basically do something different then just replace my battery.
The rep. from the Clearlake dealer was very understanding and accomodating to my needs. She took the car in and offer me a loaner without any hesitations. They let the car sit for 2 days and they confirmed that it would not start.
Initially, they thought maybe it was because my doors was not shutting tightly because of the Thule roof rack I installed. They make sure the doors were shut tightly and let the car sit at the dealer for 2 more days. Again the car would not start.
They finally narrow down the culprit to the junction box. It was explained to me that the Mazda 3 will go into a sleep mode after you shut off the engine for some set amount of time and my car was not doing that. They order and replace the junction box and let the car sit for 2 days. This time the car started. Problem solved. Thanks Phyllis and Clearlake Mazda.
I'm glad I bought my car at the Clearlake Mazda dealer and not Jeff Haas.
Peace,
I am going to follow up with the service manager again to find out why wont they test the electrical signals to see where this is really coming from and fix it! I can see this happening if you havent used your car for a month or two but not after 2 to 3 weeks? Obusurd.
Actually, this may not be unrealistic depending on a few conditions. If your battery is older (e.g. more than a year) and you typically drive short distances (e.g. mainly city and not highway trips) and you have not driven the car for an extended period of time (e.g. three weeks), I can see the battery draining and going "haywire". A battery recharger might be a good idea to avoid this in the future.
I'm not sure I understand, are you saying that the battery was charged up and failed or not? Also, how old is the battery? The bright side of the story is a failed battery is not as bad as a failed alternator (although one can lead to another).
Battery was fine, no idea how old it is as the car was bought used. The battery was recharged once because it had been run down from cranking the engine. What I meant where I said it failed to start was it cranked fine, but the engine did not start (the problem ended up being fuel pump and filter).
So the battery was fully charged, the car ran for 15-20 minutes, the car then sat for nearly 4 weeks (Dec 23 - Jan 18) without running for more than perhaps a minute at any time and the battery had the additional drain of cranking the engine a number of times, yet the battery still seemed to have plenty of cranking power at the end of all of that...in the final attempt to start before calling for tow.
Hope that is clearer
Yes!
