Chrysler LHS Electrical/Lighting
Want to go to a brighter headlight than the standard bulb. Any recommendations?
Walt5
Tusk :confuse:
Yesterday the all the gauges went dead and the radio displayed a code ending in 05. The windows, sun roof and engine run but the rest of the electrical including A/C is down.
I just had the starter replaced, then things started going bad. Could it be a bad ground or something worse?
Any suggestions?
Can anyone please give me some advise on this matter.
any help would be great.
Last night again Wipers start up for no reason at all dry weather and no rain censor on this vehicle anyway, and the lights on the interior of the truck blinks on and off rapidly whenever it feels like last about 1-2 minutes then acts normal again may go for a other month then starts acting up again does anybody out there have a similar problem how was it fixed
I just found number 14 fuse (5 amp) blown. I replaced it and everything came back on momentarily and then the fuse blew again. I am assuming there is a short. Where do I look first? I got 3 trouble codes also.
1. Code 77 Speed Control Power Relay circut is open or shorted
2. Code 21 Problem with Oxygen Sensor Signal Circuit, Sensor Voltage to computer not fluctuating.
3. Code 12 Problem with the Battery Connection. Direct Battery Input to controller Disconnect within the last the last 50 ignition key-on cycles
any Ideas?
any Ideas?
Today, I had the same problem as you described above with the instrument panel gauges not working and the number 14 fuse blown. Please advise if you found a solution and what the the solution was. Thanks.
hope that helps
