Chevrolet Lumina A/C & Heating Problems
 jamesmolly
                    Member Posts: 1
jamesmolly
                    Member Posts: 1
                    I have a 98 lumina sdn with a 3.1 lt engine. I have a problem w/ the A/C and the heat not functioning. I have replaced the controls,& have charged the R134a. Is there any other trouble shooting techniques I can use to locate the problem... PLEASE HELP!
Of all the 35 cars I have owend and the several score more I have driven.The chevy lumina is secound to none! I have read many questions about this model and have felt the same reservations. The older model i am not familure with. Though I think it would be a fine car to own as well. You see; know matter what car you my drive and own.They are not perfect machines and they need certin amounts of care and maintence to last. I bought my lumina 3 yrs ago,it is a 1998 model 4dr. my brother has owend a APV van since 1993.It has now got 230.000 miles! Mine is a pup yet...173k!! when i got mine i did not look at the blogs to learn enything. I am happy to be here though..I am very interested to share what i know and would like to hear from others too. What i bought this i got it from a car dealer.I paid 6000, for a 3000 doller car. I was very worried..about the longevity of this car. I had a windshiled put in before i picked this car up.
The origanal was cracked. I insisted on a transmission back flush too. Since the reason i was there was a burnd out tranny in my prior car. So with some trpidation i picked it up and very soon fell in love with this car.
I have heard of some problems with the 3.1 but the one funny thing i have in common would be on cold start-up she likes t rattle the lifters. When i first hard this i was scared. But a call to my bro.. revield that this was a common thing with his engine too.. dont worry about it.
I am the worst person in the world next to a woman when it comes to oil!!! I do try to keep it around full. but I have only changed the oil in this car 4 times in 3 yrs...heh heh.. dont try this one at home.. so the average milage on this car between changes are about 21k miles.Am i sounding proud or boasting?? Sorry i am illistraiting the dependability of the car..I bought.I have put 90k miles onthe car. I had to replace a failing starter. I have had to replace the rotors and pads. the master window swich whent on the fritz.. i was going to chang this out but it started to work again..so i just leave it alone for now.
Its all simple maintenance things with her. I have a fondness for this car! This car takes me to work every day. It takes me and my kids around to all the places familys go. wgen i feel loke racing she will go to a hundred in about 7 secounds. when we need economy,she gets 26 miles per gallon!!! Not to shabby for a 4000 pound car with a v6.
I live in the arctic too. alaska. we had an un global warming moment of - 45F for a week. She ..my lumina froze up! the car had frost all over it. The engine too if you touched it with moistfingers..you would stick to it! I started a fire under the car.. she started 3 hours later:>
One question I need to have answerd though is the trans..has a slip in it. Its only when i get down hard on the peddel. Ill try a hard burn out and the trans will slip and ill over rev the engine! when i let up on it she runs normally. I noticed this 3 months after i bought it. trans oil is clean and the trans dont leak. soooo. if enyone has an idea??? Well enyway i will not trade this car for a new vett.. ill write again later ..have fun
replaced compressor, resivior and check valve
still not cooling
what other parts may be resoponsible for this problem
Please help.
Could this simply be a switch problem?? I put about 400KMs per day on this car...there shouldn`t be anymore air. Anyone had a similar problem?
Ian
otherwise im sure you'd have overheating problems.
The a/c fan won't blow cool air, or any air for that matter. But at times when I crank the car, you can hear the fan turn for a few seconds but it never reaches high rpm's and then it stops turning.
The auto parts store says the fan is $40.00. But I looked and cant see where the fan motor is located. I was told that its not hard to replace, or reach.
Has anyone replaced one of these, if so please tell me what I'm up against and where in heck is that fan motor located?
Thanks much,
Tracey
Tonight, things got a little worse. Now, unless I keep giving it gas, it will drop right off and die. It will no longer fall down to 700 rpm and idle there as usual though I give it gas at the start.
So, as I drove home tonight, the engine ran fine, but as soon as I let off the gas, the car died on the spot. At lights, I had to depress the brake and gas at the same time to keep the car running.
Ideas please! What is it!?
(possible dirty air filter, way past needing new oil change, been too busy, and gas filter is a year old. New spark plugs about 8 months back. Spark plug wires OEM from day 1, got a CEL but no ideas yet as to what it is. Going to autozone to use their reader)
It seems as though the compressor is turning on there is a slight drop in rpms when I turn it on.
Thank, Ben
You might also try posting your question in our Answers section here: http://answers.edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
