Blazer Jimmy 4WD Questions
I just had both front bearing assembies replaced and now the ABS brakes are activating on most every stop. What can be wrong ? Also; I pulled the fuse for the ABS brakes temporarily to avoid the ABS activating and when I pulled the ABS fuse the Cruise control quit working. There are separate fuses for the ABS and for the cruise. Will pulling the ABS fuse dis-able the cruise? Is it supposed to work that way?
Back to the dealership. They called and said my battery wasn't good enough to engage the motor (my volt meter never wavered...seemed to hold a charge ok). I said go ahead and replace it. They called back and said there was another problem with the encoder motor.....they are in the process of replacing that now. Seems to me diagnostics would have shown that right away. I questioned the need for a new battery but not having tested it myself have to succumb.
Autotrac np 236 case is different and front driveshaft always on. For 4Hi you have a firewall solenoid that the TCCM energizes to supply vac to the front actuator and the encoder only steps for 4LO.
Would look at TCCM,dash switch, 3port or firewall solenoid (by type) or a cut wire/loose connector. First I hope they tried to reset the TCCM by removing power for 30 minutes.
Kenagirl. :confuse:
If thats not it check the front diff fluid and transfer case fluid.
So, tune it up - cap/rotor/plugs/wires/air filter and clean the MAF sensor in the intake (if you use a K&N oiled filter that is common problem as owners over oil and get sucked onto sensor and milegae drops). Any brakes dragging (like the rears if a recent brake job that did not replace the rear calipers). Something easy is wrong.
However, my 2001 blazer just stands still even when the engine is cold (and idles faster). On pushing the accelerator slowly, the engine revs up to 1500 - 1600 rpm and only then +- half a second later you feel the torque convertrer doing its job and the car starts moving.
does this indicate a problem or is it normal for blazers?
thank you
Basics is you have to go thru the vac system and 3 port vac switch on the transfer case, the encoder motor on the case, the vac actuator under the battery, the front axle coupler, and the TCCM (4wd PC) to resolve. Vac lines and 3 port switch are where to start - see if all good and not rotted/split.
The truck feels like I'm towing a trailer all the time, however the odd time it seems to lighten up. All the bumps on the road are very hard, very rough ride and when I go over bumps it bounces all over. Now when I put it in 4WD and hit the gas, I hear a cluck from the front left wheel. It almost sounds like a CV joint on a FWD car. But louder and harder.
I feel like these problems are all related to the same thing, but I can't find it. I've checked if any of the brakes are draging there all good. It possibly needs an alignment. If anyone can help, please do before I sell this thing!
Keith
the dash for 4WD it lights up but it dont feel like its in 4WD
and its not. What may be wrong and how would i fix it? im
thinking maybe the vaccume sensor may be bad...
Also i would like to raise it up a bit but since the leaf springs
are under the axle its more dificult. all i need is some
sugestions on the cheeper better stuff to get to get the
height up the most.
Charlie Armstrong
fixed that and it still dont work any other sugestions
please?
Charlie
Any help nailing this down is appreciated since I have the flu and don't have much energy to trouble shoot every single point if I don't have to.
all my babbling comes to this...
i got this truck from a relative. was told the 4wd never worked, and they had it for approx. 9 yrs. i took a couple hours of my time, traced every possible vac line, elec. connector, got dirty,
but my daughter has a 4wd that actually has 4wd.
my complaints were consistent with everyone elses
but by taking the time to read everything i could find here, it helped me cut hours and possibly dollars off the whole project.
as an old timer once told me, "If you don't learn something new everyday, your not paying attention in life" :shades:
