Suzuki SX4 70 mph , 4000 rpm, is it normal?
I bought a new SX4 auto gear 2.0L, when I drive 70mph , it goes 4000rpm, is normal?
I also smell some plastic burning smell from front engine side, is it normal at new car ?
chris
Top Gear 1.000 AT 0.815 MT
Final Gear 4.380 AT 4.411 MT
Tire Dia 25.7"
RPM=(MPH*FG*(336/TD))*TG
let me check it again on my own the next day
My Saturn SL2 is like that, revs like crazy in cruise, so I thought the SX4 would do the same, she is very tame on the SX4, I like it, and only changes a little on the revs.
Debric
I test drove an SX4 (automatic) sedan today, and 28 MPH per 1000 RPM sounds about right in top gear.
If the revs climb going up a hill it's either kicking out of OD or kicking down to 3rd gear. If there's enough torque to pull the hill, there should not be an RPM increase.
A tranny should not blow climbing hills. Hills are a normal part of life for most vehicles. I guess the exception would be the flatlands, but for those of us who deal with hills all the time, our trannies don't tend to blow regularly. Could have been another issue with the trans, such as low fluid, abuse, or a junk design.
Is there something I can do about it ( ie increase tire deameter, etc)?
Is it normal for this engine? From reading this posts on the topic, it is as if different people have different SX4s.
Any advice will help. Thnx.
I believe the AT SX4 runs about 27 MPH/1000 RPM in top gear. That's one of the first things I check in a test drive.
When I test drove the Suzuki, I also drove the Hyundai and KIA competitors. They are all geared about the same, all run about 27 MPH/1000 RPM in top gear.
That gives you about 3000 RPM @80 MPH in top gear.
The manual is geared tighter, so it will run more RPM at any given speed. In top gear.
Make sure you're in top gear and not stuck in 3rd, or 4th with OD locked out.
I have a KIA Spectra, it is not loud at 80, running at 3000.
While you can address the issue to some degree via different tires, a 3-6% difference is the most you will probably find practical. Then you enter into wheelwell clearance, appearance, and altered center of gravity issues which you may find are also compromises you might not want to make.
last time i checked that if i accidentally switched to gear 3 and run 65mph, the rpm will be higher and engine is noiser. because gear 3 is just left from D gear and just 1 click.
@70mph is 2600 rpm. engine sound is not loud.
mine sx4 is AT, 2.0 Liter
I love this car!!
-Sean
Typically 5th (or top) gear is considered the "overdrive" gear. There is no separate overdrive switch/system as was found on cars from the 40s, 50s and 60s.
Lockup is the "overdrive" in 4th gear, in the automatic. Again, there is no overdrive system distinct from the lockup in the automatic.
Overdrive is a term that has evolved to mean taller/longer than a 1:1 ratio. It doesn't mean what it used to, but the intent and end results are similar.
BTW, the SX4 is one of the few modern cars I've checked specs on that does not have an "overdrive" top gear, but rather a 1:1 top in the auto trans.
Quite unusual, most cars have about a .7:1. Wonder what guided their thinking on this?
60 = 2650, 70 = 3000, 80 = 3750 rpm. For comparison, are automatics about the same ?
That means they run 3,000 RPM @ 81 MPH. Which equals appx. 2600 @ 70, and 2200 @ 60.
Easy if you have a calculator.
By comparison, your manual runs 23.3 MPH/1000 RPM in top gear, doing the math on your numbers.
