2001 Volkswagen Beetle Electrical & Lighting Problems
rickz713
Member Posts: 4
2001 Beetle. oil light and buzzer go on every time i stop. just had oil changed too. also, cold temp indicator stays on all the time. any ideas?
Getting everything back together takes a lot of patience tho. You need to make sure everything lines back up correctly (very tought) pull the lever back up and hook up the clamp again.
Best thing to do, is probably pick-up a Haynes manual at the local auto-parts store. It probably covers it.
And usually, the headlights themselves will probably be out of alignment, so you should check that.
It's not fun... but I have a lot of practice.
http://www.midsouthvw.com/TechTips/tech_tip_NuBeeHdlitRR.htm
Search around and you'll find one with pictures. It's very easy, just don't force that little lever. It moves only a little, and it seems easy to break.
Thnx from Texas!
thanks!
I am having problems with my signal lights not working. This problem is also effecting my hazard lights. When I use the turn signal nothing happens. Sometimes I can slap the dash board and it may click a couple of times but that is it. Then there is nothing. It has gotten so bad now that even when slapping they don't work. :sick: My husband and I recently received a recall message in the mail about the brake lights but I am not sure if this could be a part of that issue. Is there anyway for me to fix this issue on my own? I have looked into opening the steering column but it is impossible to see the screws holding it together because they are way up. Help me,please. Thank you!
I wanted to let you know that I found out what was going on with my signal lights. I had to take my car to the dealer for a recall and had them check the signal light issue too. I was told that the hazard light switch had gone bad and to replace it would be $95.00 with the cost of labor. I wish I knew how to do that because at this dealership that would make the part only $10.00 because labor is approx. $85.00/hour.
Hope that helps you!
Signed frustrated!!!
I've seen reference online to a computer memory saver (15-20 bucks) that plugs into the cigarette lighter. Supposed to keep current flowing in the system as you change the battery, and will ensure that your idling values/etc stay put!
The few times I've had to replace a battery, my car has "relearned" all the lost info. Resetting all my radio presets was really the bigger hassle.
Any VW owners have an special info on this??
make sure that you disconnect the negative (black) lead on the batterty first.
Then when you hook up the car replace the negative (black) terminal last.
Question......does this sound right to you guys? Is there a short-cut or "trick of the trade" to do this at home? I will have to tow this thing 100miles if not. As always...any and all help is greatly appreciated.....
Have a 2000 beetle, this thing has been a nightmare. so far this is whats been going on over the past 3 weeks.
Week 1 - A/C comp only getting 8 volts, so now A/c doesnt work.
Week 2 - Drivers side power window quit working
Week 3 - now the high temp light goes on and off - even when cold???...
This car is driving me nuts, along with my wife harping at me all the time saying "when are you going to fix this". Problem is, I keep trying but cant get anywhere. The 8 volts on the Compressor I think might be a ground issue? The high temp light on/off might be a bad sensing device? and as far as the window not working-I havnt even got to looking at it. This car is starting to make my stomach hurt...
PLEASE HELP ME!!!
The heat light is an easy one (I hope). Add some coolant to your coolant bottle. The contacts inside must be covered!
Can't help with the window but hope other info helps.
Electrical system components stopped working:
Horn, Turn Signals, AC & Blower, Vent controls, Winshild wipers & Fluid controls, Head Lights.
Here are the electrical systems still operating correctly:
Radio, Brake Lights, Running Lights, Pwr Windows, Pwr locks, Pwr Moon roof, Pwr trunk, Pwr gas door release, Car starts and runs normal !
Pleaee Note - The hazard flashers work, the momentary bright lights when you pull back on the turn singal works.
I have verified all fuses next to the battery are OK, All fuses in the fuse box are OK, I have removed the covers to access the relay panel. I removed all relays and checked all relay coils with a VM and everything looks OK. There were no contacts welded.
No sure where to go from here. Any suggestions.
My right daytime running light is dimmer than the left headlight, and is noticable when the headlights are on at night. I will take it in to the dealer, since they replaced the headlight cover on the right side. However i wanted to ask if anyone had similar issues.
Also, the remote lock button locks the passenger door but doesn't lock the driver side consistently. In fact, it didn't work for the past 8 months but just recently began working as did the locking mechanism once the car reached 10mph. Also, I used to be able to close the windows and the sunroof by turning my key in the door lock. This no longer works.
I also noticed last week that lit icons appear when I engage/disengage the spoiler and when I unlock the back hatch. That stopped the next day, but I thought it was unusual that these light indicators appeared after a year and a half of not working. My spoiler that enganges at 45mph makes a loud, abrupt noise when it closes once I slow down below 45 mph. Do other beetle owners notice this loud problem too?
Finally, though this is purely aesthetic, the interior parts of my beetle show wear and tear easily. I am very careful with my car's interior and keep it very clean, However, I noticed the black finish on the radio and especially the cup holders, have begun to rub off and bubble and peel (this occurred on the plastic surrounding the cup holders.) The interior door handles also show scratches and erosion of the black finish. I am seeing more of these problems on my dash and on the rubber and plastic components around the glove compartment. Any advice on these finish problems because I am not sure what to do but know it will only get worse!
Do you have any suggestions?
thanks.
I know what you are going through if you haven't seen the inside of the headlight system. If your headlight has popped out enough (it should when you move the lever)to get you finger tips under it, have someone pull and wiggle the assembly while you push from the rear. The assembly is accessable and open in the rear.
I think the wiggle while pushing and pulling is the answer. Once you get it out, I advise you to lube all moving parts for future removal. After you see how it works, you will be an expert headlight mechanic.
I think this system was really a good setup when it was new and clean. However, the dirt and filth that get into the mechanism is the culprit.
Try to remove as much as you can. I used a dry spray but I guess about any slick product will work. The secret to getting the unit back in is about the same as removal.
While your pushing up? on the lever bump the front of the light with the palm of your hand rapidly. Your trying to vibrate the track system while pushing in on the light.
Hope this helps!
I would drive far to a VW Dealer who could fix my car! I love my 2001 Beetle and it only has 58,000 on it! I am suprised that the Beetles have so many problems with this and VW has done nothing to correct this issue! Help!
Converting to 12V is a hassle too.
Why can't I put in an 12 volt batt.(under-charged at 'say'at 6-9 volts.Will not the generator maintain the batt.at the gen. output volts of (8.2 v)?I'm tempted to try it. What's your thoughts?
TIA al
I searched this forum but found no information, so have to ask, "How do I replace the tail light bulb?" The AutoZone salesperson had an older Beetle, and said I may have to remove one of the body panels to access the tail light. Is that true?
Thanks for sharing the light replacement procedure with me.
Jerry
Radio, Brake Lights, Running Lights, Pwr Windows, Pwr locks, Pwr trunk, Pwr gas door release, Car starts and runs normal !
BUT ... The hazard flashers work, the momentary bright lights when you pull back on the turn singal works.
HELP?!?!
good luck!
